Changing Hyd Fluid (log splitter)
/ Changing Hyd Fluid (log splitter) #1
Kubota 2350
Michigan, In The Thumb
2016 JD 3046R Cab ...................... Mower: 2016 Scag Tiger Cat II ZTM
I want to change the hyd oil in my log splitter, how do I get the oil to come out of the hyd cylinder?
There is no drain plug in the tank, but I have a vacuum pump on a tank to remove it from the top side.
I just want to get as much of the old oil out as possible.
I was thinking I could put the splitter in the vertical position and with the ram all the way up it would drain, I'm I right here?
/ Changing Hyd Fluid (log splitter) #2
It will depend where the rod is, retracted or extended. If it is retracted, and the splitter is vertical, then, remove the hose to the rod end and the fluid will drain. There will not be very much fluid in the base end.
If I have the cylinder in the vertical position all the fluid will be at the bottom part of the cylinder, so can I leave the valve in the neutral position and manually pull the piston out and force the fluid out?
/ Changing Hyd Fluid (log splitter) #4
You are correct about removing all the fluid from the cylinder. To drain the tank most have the feed to the pump low in the reservoir so you could remove the hose to get most of it out along with using your pressure extractor to get what is left.
Chris
/ Changing Hyd Fluid (log splitter) #5
In neutral, the cylinder ports on the valve are blocked off. I don't think you will be able to pull the rod out with the hoses connected. If you take the hoses off, you might be able to pull the rod out, Just take the cyl off and turn it so the port you want to drain is at the bottom.
2016 John Deere 6155R (A64119)
2016 John Deere...
200 GALLON FUEL TANK W/ 120V PUMP (A64277)
200 GALLON FUEL...
Farm King 300-bushel Gravity Wagon (A66408)
Farm King...
Man Basket (A65640)
Man Basket (A65640)
2005 Little Wonder High Output Walk-Behind Blower (A64553)
2005 Little Wonder...
Ag Leader PF Advantage Monitor (A65640)
Ag Leader PF...
