Will this valve work for me?
/ Will this valve work for me? #1
DWW68
Western NY
B7800
I am looking at installing rear remotes on my B7800. Specs on tractor say total pump output is 9.5. For now, all I will be using them for is to operate the shoot rotation on my snowblower. I figure if I am adding a valve it may as well be a two spool valve (t&t may be in the future). After looking at the many threads on here about rear remotes nobody seems to say why the went with the valve that they used, other than they already had the valve. Seeing that I have to buy the valve, I want to make sure that I get the correct one from the begining. I have a loader, so I will be running off the power beyond to new valve. This is the valve I am thinking of getting from surplus center. I think that it will work and appears to some what of a small foot print, and fair price. What do you think? Is there a better valve for my needs? If so let me know. Thanks in advance.
https://www.surpluscenter.com/item.asp?UID=2009110816181360&item=9-7862&catname=hydraulic
Home > Hydraulic > Sort > Item
Item# 9-7862
Our Price $139.95
2 SPOOL 8 GPM PRINCE MB21BB5C1 DA VALVE
10 In Stock
About Our Products
QTY
Calculate Domestic Shipping & Handling Estimate
Ship Method Zip Code
Priority Mail UPS Ground UPS 3-Day UPS 2-Day UPS Next Day
COMPACT 2 SPOOL DOUBLE ACTING DIRECTIONAL CONTROL VALVE
Brand New PRINCE MB series directional control valve for operating double acting cylinders. Ideal for small tractor and other low flow applications requiring a compact control valve. Features include monoblock construction, load check, built-in adjustable pressure relief valve, spring centering spool action, open center with enclosed plug to convert to power beyond or closed center, side or top inlet/outlet ports and vertical or horizontal handle mounting.
SPECIFICATIONS Open Center Convertible to power beyond or closed center
Spools Two
Flow 8 GPM max.
Pressure 3500 PSI max.
Relief Valve 2000 PSI, adj. 2000-3500 PSI
Reqd. Filtration ISO 4406 19/17/14
In/Out Ports SAE 8
Work Ports SAE 8
Mount 3 hole base
Size 7-5/8" x 5-7/16" x 2-1/4"
Shpg. 12 lbs.
Spool Details:
Spool 1 DA cylinder spool, spring to center
Spool 2 DA cylinder spool, spring to center
/ Will this valve work for me? #2
That should work just fine. The only "hitch" is the 8 GPM flow and your rated 9.5 GPM. But I think some of that flow is diverted to the steering...does it have a spec for "implement" GPM?
Edit: Be sure to get the PB plug when you order the valve.
/ Will this valve work for me? #3
I know that the B7800 output is split between steering and other hydraulic - yielding something like 6.5 GMP so the 8GPM valve should be fine.
Mike
Attached is the spec sheet that I was looking at.
  • b7800_Specs[1].pdf
OK thanks guys. Unless somebody has a better option for a valve, I will order this one.
Good heads up on the PB plug, I would have not thaught to order that with the valve.
/ Will this valve work for me? #7
Just for the record - according to my B7800 manual, steering is 3.1GPM and other (listed as 3Point)is 6.4GPM. Same spec for B2710 & B2910.
Mike
/ Will this valve work for me? #8
What is a PB plug, and what does it do?
/ Will this valve work for me? #9
A PB plug is used to plug the PB port . A PB sleeve is installed where the plug was, and is used to send fluid out to other circuits, like rear remotes.
/ Will this valve work for me? #10
OK, I think I understand, Thanks.
/ Will this valve work for me? #11
__________________
J.J.
This is the same valve I used on my little JD 3038. You actually use a 1/4-18 BSPT high pressure carry over plug whenever used in power beyond application. It comes setup for open center, however can be used as PB, or closed center also. The plug and enough instruction come along with the valve.
Massey Ferguson 8200 Flex Grain Platform (A66285)
Massey Ferguson...
International 806 Wheatland Tractor (A66285)
International 806...
8ft. Metal Drag (A65640)
8ft. Metal Drag...
2011 Tri Axle Frac Blender Trailer (A64194)
2011 Tri Axle Frac...
40ft 10 Door Shipping Container (A64194)
40ft 10 Door...
(2) FIFTH WHEEL PLATES (A65643)
(2) FIFTH WHEEL...
