moeh1
Gold Member
The torque arrestor can be adjusted for diameter as you put it on, the position of the one end as you tighten it on the pipe determines the fianl diameter - it gets adjusted so the pump will just slide down the well. Since it is right above the pump, this keeps the pump centered as it starts.
On flexibility of the pipe, I've had to help pull the neighbors in about 10 degree weather, it came out of the hole OK at 45, but was pretty inflexible when we put it back in (so was I by that point). Unless you need a wellhouse for another reason, I'd pass.
