adding a 3rd function valve to a 755 john deere HELP!
/ adding a 3rd function valve to a 755 john deere HELP! #1
Kevin M
Gold Member
goshen NY
48" bobcat walk behind , 60" Dixie Chopper Classic , 755 John Deere 4x4 70 ldr belly mower etc etc , 7610 Ford 4x4 7412 ldr and 10 ft rhino hogg
I want to add a valve to raise and lower a cylinder on my custom dump cart, right now im using the loader valve. Thats a pain to plug and unplug lines! My question is can i " Tee" the pressure line coming out of the pump ' run it into the valve then run a return line to the return side of the pump ( making sure theres a relief built into valve of course ) Would this work ?? my dealer acted like i had six heads ? They also told me a power beyond kit was no longer available , but that only constant flow or could i use that if i found one ???? HELP OH GODS OF THE TRACTOR!
Kenny D can you help me, the newbie?
/ adding a 3rd function valve to a 755 john deere HELP! #3
Sometimes we need more than 18 minutes to get to you;)
Welcome to TBN:D
You cannot "Tee" any high pressure hydraulic lines-period. The hydraulic fluid, like electricity will "take the path of least resistance" and never get to your new valve.
Since the PB kit is NLA, then you will have to homebrew your setup...are you up to the task? Estimated cost will be about $300-$500 by the time you get all the stuff, and you will have to fabricate a mount for the new valve.
The PB kit is pictured below, you will basically have to build that and use lines to feed the new valve, will need to know the S/N of your machine to help with more detail-JDParts show different setups.
Do you have a shop manual by chance? Are you ready to procede?
/ adding a 3rd function valve to a 755 john deere HELP! #4
I installed the 3rd SCV kit on my 4600 last night. I will test run and check for leaks today. Pretty easy install.The kit is NLA from John Deere. I had looked for the past 3 months for one. I found this one at Koenig Equipment, Inc in Botkins OH for $235. jddealer.deere.com/koenig/ GREAT CUSTOMER SERVICE. They were offering a PB kit for the 4600 on Ebay. I e-mailed them and ask if they had the 3rd SCV kit I was looking for and sure enough they did. There are a lot of dealers selling on Ebay and they may have a kit to fit for you if you don't want to build one yourself. Koenig was about the 15th dealer I had emailed so don't give up if you get a bunch of no's before you find what you are looking for.
Thanks Kenny I appreciate your help , I am trying to find a New old stock PB kit first , found out that would work after reading another thread you commented on ( note to self, read first then ask for help). I'm up for the task and the $$$ I will post my serial # shortly
Thanks Mitch I have that image of the P/B kit from my Dealer , The piece according to the parts list there calling the hydraulic cylinder cap ,[ valve body] where does that mount too ?? The back of the loader valve ? I'm not near the tractor but owners manual says 100001 - I have this # from the bill of sale LV077D180465 ?? I will post more later!
You guys are the best! My dealer said no the kit was not available , then asked if I could buy the part separate no not available ! Thanks to Mitch I called Koenig in ohio , asked Brian the same ? , no kit but the parts are available! All to piece the P/B system together , from Deere YES! Now the bad is its almost 700 bucks! ??? Is there a cheaper way Kenny?? Otherwise I'm going to get it cause I'm to lazy to keep moving lines back and forth !
/ adding a 3rd function valve to a 755 john deere HELP! #8
You only need a few of the pieces, NOT the whole kit.
Need the S/N first.
How many spools do you want to add so I can suggest a valve?
OK Kenny heres the PIN# under the hydraulic pump / above the hitch PIN # LVO755D180465 , heres some #s i found on the pump itself, pressure 160kfg/cm2, discharge 7cc/rev thats all i saw, unless there is some where else i should be looking???
/ adding a 3rd function valve to a 755 john deere HELP! #10
Kevin M- I beleive KennyD was looking for your Tractor Serial # !!
scotty thanks but that is the only (PIN) product identification number i found was a plate above the hitch / below the pump on the back of the tractor is there some where else i should be looking Scott ???? I can go look if some one tells me now, that im home.
Kenny D looking for one or two spools , should just go for two while im at it !
just saw something in owners manual , maybe there is another serial # i missed ! Going to look now
I only could find one plate on the tractor , it is under the PTO shaft , it has a bar code and the PIN# i mentioned before, the owners manual has a 6 digit serial # that covers 100001- ?? Im guessing mine is # 180465 which is part of the PIN #
/ adding a 3rd function valve to a 755 john deere HELP! #15
OK, Just did more research in JDParts (you are registered right?) It is not the S/N number I need like I thought-but rather the "transaxle S/N", here is what is says:
TRANSAXLE SERIAL NUMBER IS STAMPED ON TOP OF THE CASE, BELOW LEFT SIDE ROCKSHAFT ARM
It should begin with 82......
The reason is they list two different kits, the older one is the picture I posted above and I think you need that big part #4 and possibly the line #16
The new kit (pictured below) just needs the diverter plug #15 and the fittings and hose that you can source locally from any hydraulic shop or online.
Going back out to look , stay tuned
I believe i have a later tractor , unsure of year ? The # i found was between the hydraulic return to the tank/ pump and the rock arm, you ment part of upper 3pth pivot i think THE# ( 843575 )
Found this in owners manual- hydraulic 5.6 gpm , working pressure 2050psi
/ adding a 3rd function valve to a 755 john deere HELP! #20
I believe i have a later tractor , unsure of year ? The # i found was between the return to the tank and the rock arm, you ment part of upper 3pth pivot i think THE# ( 843575 ) A couple of numbers on the pump, 160kgf/ cm2 and discharge 7cc/rev ??? I m unsure GPM
I only know what I quoted above from JDparts (you are registered right?)
If you have the later # above 820001-and it looks like you do, then all I would order from JD is the diverter plug P/N PT13744.
You also might want to find a FSM (factory service manual) on eBay also...
Basically, when you install this plug, it diverts the fluid OUT of one of the ports, through the new valve then back IN the other port whenever the tractor is running.
I would pick a valve, then devise a mounting for it while you are researching everything else...
2021 WEILER K560 KNUCKLEBOOM LOADER (A65057)
2021 WEILER K560...
2016 Land Rover Discovery Sport SUV (A61574)
2016 Land Rover...
2017 FREIGHTLINER SPRINTER 2500 4X2 S/A CARGO VAN (A69167)
2017 FREIGHTLINER...
TORO SGR-13 STUMP GRINDER (A67714)
TORO SGR-13 STUMP...
2007 INTERNATIONAL 9900I (A67714)
2007 INTERNATIONAL...
2014 PETERBILT 579 MID-ROOF SLEEPER (A67714)
2014 PETERBILT 579...
