Backhoe Post Holes with a backhoe?
/ Post Holes with a backhoe? #1
Jim Donahue
This may be one of the lamest questions to date! Has anyone
put in 4x4 PT posts for a fence with a small backhoe. I have
a BX25 and before I rent a posthole digger, just thought I would
throw it out there and see what happens. I have about 7 post
to put up.
/ Post Holes with a backhoe? #2
Never done it but pretty soon I'm gonna dig in a few posts with a backhoe.:D
/ Post Holes with a backhoe? #3
yep done it quite a bit. Sometimes I just don't feel like hooking the PHD, so I just use the mini ex. I've even tossed the idea around about getting rid of the PHD?????? just hate to let go of equipment.
/ Post Holes with a backhoe? #4
I have. With the rocks we have here, an augur would be a waste of money and machinery.
Dave.
/ Post Holes with a backhoe? #5
Have done it several times -- usually when digging just one or two holes for a project. If digging a lot of holes, I use a PHD.
/ Post Holes with a backhoe? #6
to put up.
I built a small rear deck & dug all 4 post holes with my BX23 BH.
The thought of a PHD never occured to me /I had a BH !
/ Post Holes with a backhoe? #7
While you can certainly dig the hole with backhoe, you'll get a much tighter fit with Post hole digger. I've done both and, all things equal, I'd do PHD every time.
Mike
/ Post Holes with a backhoe? #8
You will obviously end up with a large hole with a BH, just use a sono tube and fill around the tube with dirt. If you don't you will be using alot more cement.
Shane
/ Post Holes with a backhoe? #9
BH for holes - posts or pole barn construction - it is what I have used.
I use my bigger tractor for sinking new posts now by pushing them in after rains with the FEL.
But I really can't see the benefit of a PHD when you spent the cash on the BH.
The tube trick someone else posted works great too if you are using concrete.
/ Post Holes with a backhoe? #10
I think it may be a viable solution using BH when you have a lot of rocks. but as previously mentioned you will get better results using PHD. Primary benefit is that all the ground except what you are auguring out is compacted. Using eh PHD you will have pretty good size hole that will need compaction. I am afraid settling that will occur will not be best for your fence. also if using cement for any of the holes you will have a challenge.
/ Post Holes with a backhoe? #11
Doesn't sound lame to me at all. Although I have been actively looking for a PHD for my tractor I have recently decided that an investment in a 9 inch bucket for my BH76 makes more sense. I have to make a fenced in area for our dogs, mostly in the woods. The FEL made quick work of all the brush & small trees & now I need about 500 feet of fence to run. I also need to trench several hundrd feet for wiring for outdoor lighting. Can't do that with a PHD.
/ Post Holes with a backhoe? #12
I used the mini excavator that I rented to dig away the dirt and expose the bedrock that I had to go through. The excavator would not bust up the rock so I used a jack hammer for that. There were some holes that I dug with it that did not have the rock problem and I thought it was harder to set the posts than when the PHD was used.
/ Post Holes with a backhoe? #13
BH away ! if you do it right, you will only end up with a elognated hole and slightly larger then a PHD hole. for the price , you cant beat it.
/ Post Holes with a backhoe? #14
Just how are you intending to use the backhoe...digging the hole ...or pounding them in.
I have a 4 in 1 CX300 loader on my 3320 tractor and have installed 280 post 4 to 6 " in wet weather and in middle of summer's worest heat and dry season.
I pound them in with the back edge of my bucket - using about 4" blows.
Now I'm a pile driving crane operator and have the timing down very good.
I was told it can't be done this way and yet, like I say 280 post mostly 5" or better and there all in 2ft or better,these are 8foot post's.
One thing - once there in ,leave them alone for a day or so to set ,before you add boards etc to the post.
If your backhoe bucket can reach the top of the post try it! One won't hurt anything.
I have a friend hold it till I get the bucket on it he keeps it straight one way and I eyeball it the other ... I set the bucket on the top ,press down till it won't go any more and then jerk the lever to allow the bucket to come up about 4 to 6 " and slam back into the top of the post.
Try it you might like it!
But that's just me.
/ Post Holes with a backhoe? #15
Actually I prefer a backhoe over a post hole digger. I sold my Post hole digger last summer from lack of use.
Backhoe will remove rocks with no problem. Just dig a hole put in sono tube in the center line, backfill with dirt. Cement post in.
I used the post hole digger once 10 years ago and it worked great where there were no rocks. Any rocks would auger the front tires up in the air and I would have to take a large pipe wrench and unscrew the digger auger.
/ Post Holes with a backhoe? #16
i put in about 15 post for the fence around my pool using mostly my backhoe and the only hard part was packind the dirt back in around the post ,after the first one i filled the hole half way with dirt ,i didnt use any cement filled the hole with a 5 gallon bucket of water and let it pack in until the next day and finished filling the hole with dirt and my fence doesnt move at all and it is a 6 foot high with 4 feet in the ground
/ Post Holes with a backhoe? #17
I'm with bluetc30. Dug the holes, which were slightly elongated, partially filled with soil around the post, watered the dirt, tamped it, repeat till the hole is filled. Packs great.
Have fun.
/ Post Holes with a backhoe? #18
I use the bucket to hammer down cedar fence posts... first I do a starter hole with a shale bar, then I shove in the post in the hole and hammer away. just make sure that you start them plumb and hit it with the bucket on a flat spot.
/ Post Holes with a backhoe? #19
That's how I put in T-Bar posts - just set the post and then push it in with the loader. I don't hammer things, just push gently.
Check out the video: Snow can now blow Part 1
Of course you need a big enough tractor to do that - my BX24 never could mash things in like that!
/ Post Holes with a backhoe? #20
I have filled the bucket with a full load of dirt to get more weight. That helps to push the stubborn ones in. I would imagine if you sharpened the 4x4's, they would go in OK. I have never tried doing a 4x4, though.
Broderson Crane (A64047)
Broderson Crane...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2001 Peterbilt 379 Tri-Axle Dump Truck (A59230)
2001 Peterbilt 379...
Bobcat Skidsteer (A60352)
Bobcat Skidsteer...
2017 FORD F-150 FOOD TRANSPORT TRUCK (A63569)
2017 FORD F-150...
2013 FORD F350 SUPER DUTY 4x4 CREW CAB PICKUP TRUCK (A59910)
2013 FORD F350...
