Richard
Super Member
- Joined
- Apr 6, 2000
- Messages
- 5,046
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
Maybe I should have said vibrator...
Scenario: Been laying down flagstone. As it has been put down, I've been adding sand as mortar between the stones. It's irregular shaped stones so some of my gaps are very narrow (like 1/8") and some areas are much larger, simply depending on the lay of the stones.
Found out about polymeric sand
Polymeric Sand
Seems this stuff is made to be swept into the grout lines, compacted via using a vibrator/compactor and then you dampen it and it will harden up.
This sounds perfect for our situation....except.... I don't have and don't really want to rent a compactor again.
So.... how might something be fabricated that could be used to help vibrate the stones and let this stuff settle between them?
Some items I have on hand that come to my mind are:
1. compressor
2. chisel gun for compressor (could I hammer the chisel into a rubber pad or something that is sitting on a stone to help settle the sand?)
3. Other items for compressor, impact gun, grinder, 12" linear sander (4" wide and 12" long, sands/vibrates forward/backward)
4. Various power tools (circular saw, sawzall, jigsaw, drills, right angle drill, grinder, chainsaw, backpack blower, string trimmer)
I know the 'right' answer might be to rent a compactor/vibrator but.... I really really reall reallyyyyyyyyyyyyyy don't want to deal with that if I can make something else work that I have on hand.
surely the creative mindset here can some up with something that might work for me?
Right now, (prior to wife discovering this polymeric sand exists) I've been simply using water to help get the grout sand to settle. Adding more sand after it settles down. This polymeric sand however, seems to preclude me using water as a tool to help it settle.
I was thinking of some kind of wooden platform, perhaps a rubber platform, set upon the joint(s) and trying to somehow use the force of the air chisel gun to help the sand settle. Not wanting to chisel anything like the stones, I was thinking I might need a second layer on top of the wood to help absorbe the chisel action yet allow the secondary force of the vibrations to carry through to the rocks.
Thoughts?
Polymeric Sand
1. compressor
Thoughts?
