How to rig a home made compactor?
   / How to rig a home made compactor? #1
Richard
Super Member
Knoxville, TN
International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
Maybe I should have said vibrator...
Scenario: Been laying down flagstone. As it has been put down, I've been adding sand as mortar between the stones. It's irregular shaped stones so some of my gaps are very narrow (like 1/8") and some areas are much larger, simply depending on the lay of the stones.
Found out about polymeric sand
Polymeric Sand
Seems this stuff is made to be swept into the grout lines, compacted via using a vibrator/compactor and then you dampen it and it will harden up.
This sounds perfect for our situation....except.... I don't have and don't really want to rent a compactor again.
So.... how might something be fabricated that could be used to help vibrate the stones and let this stuff settle between them?
Some items I have on hand that come to my mind are:
1. compressor
2. chisel gun for compressor (could I hammer the chisel into a rubber pad or something that is sitting on a stone to help settle the sand?)
3. Other items for compressor, impact gun, grinder, 12" linear sander (4" wide and 12" long, sands/vibrates forward/backward)
4. Various power tools (circular saw, sawzall, jigsaw, drills, right angle drill, grinder, chainsaw, backpack blower, string trimmer)
I know the 'right' answer might be to rent a compactor/vibrator but.... I really really reall reallyyyyyyyyyyyyyy don't want to deal with that if I can make something else work that I have on hand.
surely the creative mindset here can some up with something that might work for me?
Right now, (prior to wife discovering this polymeric sand exists) I've been simply using water to help get the grout sand to settle. Adding more sand after it settles down. This polymeric sand however, seems to preclude me using water as a tool to help it settle.
I was thinking of some kind of wooden platform, perhaps a rubber platform, set upon the joint(s) and trying to somehow use the force of the air chisel gun to help the sand settle. Not wanting to chisel anything like the stones, I was thinking I might need a second layer on top of the wood to help absorbe the chisel action yet allow the secondary force of the vibrations to carry through to the rocks.
Thoughts?
   / How to rig a home made compactor? #2
I have a project that will take most of next summer and I would need to rent a compactor two or three times at $230 - $275 per week. I spent a few months on Craig's list and found a Wacker 1550 in great shape for sale and paid $650 for it. After buying it I contacted several landscapers and pool companies and found one who agreed to buy it from me for $500 when I'm through. Now I have a machine at my disposal when I need it. Luck was definitely involved
The same thing might work for you.
   / How to rig a home made compactor? #3
Make one!
Sandwich some 3/4" plywood to form ,say 16 X 24 X 2 1/4 thick base.
Glue and bolt together.
Mount 2 pillow bearings maybe 6-8" apart with an 'unbalanced' weight in the center and terminate with a pulley at one end.
Mount the largest pulley that will fit on the shaft (perhaps even blocks to raise the pillow bearings) and drive this 'unbalanced shaft & weight' with a 1750RPM 1/2 hp electric motor.
You might even want to use a second pillow block setup to furthur reduce the unbalanced shaft RPM's as you really want the unbalanced weight to rotate real slow.
Crude, will wear out the ply fairly fast but will do the job, but then you could always add some steel flat plate stock to the bottom as a wear plate.
Total, some plywood, couple of shafts, 4 pillow block bearings and 3 pullies.
Presuming you 'borrow' an electric motor from one of your power tools for the duration.
For a handle, use an old lawn mower handle.
Have fun!
After all, what I describe is basically all a vibrating plate is except factory made and fancy.
   / How to rig a home made compactor? #4
id just keep my eyes out for a used one. You can always get what you paid for it.
Probably , id just rent one. Sometimes you just need the right tool for the job. With the cost of materials you have in this project, the rental of the correct tamper will be minor.Last time i rented one i think it was only round $100 for the weekend.
   / How to rig a home made compactor? #5
Now is the time! With the current economic situation, used equipment $$ are at an all time low.
I would look for a used one. Chances are you can probably sell it for almost as much as you paid for it.
   / How to rig a home made compactor? #6
I'm sure it varys from place to place, but in my area plate compactors are at a premium.
I've been looking for a year now and in general the prices are quite high.
Every time I see one in my price range I'm ether a day late or a dollar short!:eek:
   / How to rig a home made compactor? #7
Typically you DO NOT vibrate flag stone. Depending on the thickness and size, most likely you'll crack it. Tamping is meant for small pavers that you set "high", then compact to grade. You use the vibrator to help get the sand between the joints, since in the case of pavers the joints are so small.
Here are some pictures of a small flag stone path that I helped a friend do. We used polymeric sand for the joints. All I did was hand push it into the joints (with a dowel or brick mortar tool), sweep it off the stone! (or it will stain it), then wet per directions. Make sure you purchase polymeric sand intended for larger joints and you should be all set.
Forgot to add - I'm in Ottawa Canada, the walkway has stood up to a few winters without any problems. So as long as you have a good base and follow the directions on using the polymeric sand I think you should be good.
   / How to rig a home made compactor? #8
I agree with Greg, do not vibrate the flagstones -- to much chance of cracking them.
Just tamp the polymeric sand into the cracks by hand with an appropriate-shaped tool.
I have a plate compactor I got from HF a few years ago. Wait until it goes on sale and then use a 20% off coupon and it will end up costing about $400.
Mine was even better, since I bought the service contract and when the starter cord broke HF could only find two outfits in my state who would work on a plate compactor, both more than 300 miles away. I pointed out to their legal department that the ads for the service contract claimed "more than 2000 service centers nationwide", which implied an average of 40 or so per state. They bought the service contract back from me for ~$500 and I fixed the cord myself.
   / How to rig a home made compactor? #9
Make one! ... Mount 2 pillow bearings maybe 6-8" apart with an 'unbalanced' weight in the center and terminate with a pulley at one end. ... quote]
Crank shaft & block from lawnmower/snowblower engine with piston & rod removed makes a fine unbalanced weight with bearings & mounting base with bolt holes. Use tywrap on the journal for an oil slinger. Made a power screed for concrete with a vertical shaft motor. Works great. MikeD74T
   / How to rig a home made compactor? #10
Interesting Idea!
2017 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A58017)
2017 FREIGHTLINER...
2012 Kenworth T800 T/A Sleeper Cab Truck Tractor (A55973)
2012 Kenworth T800...
2006 Ford F-250 Service Truck (A56858)
2006 Ford F-250...
1977 Gleaner A630 Corn Head (A56436)
1977 Gleaner A630...
2015 Peterbilt 367 National Crane NBT55 5-Mast 128ft. 55 Ton Quint Axle Crane Truck (A55973)
2015 Peterbilt 367...
2021 Deere 331G (A53317)
2021 Deere 331G...
