Another DIY Cab...MF GC2600
/ Another DIY Cab...MF GC2600 #1
Jaylegger
Massey Ferguson GC2600L
Getting ready for snowblowing this winter I figured I'd be well served to take a few hints from the veterans, ie: get a friggin cab. I recently purchased a Massey Ferguson GC2600 but couldn't justify the approx 5K for an aftermarket cab so began scouring for methods and materials for a diy build. After a few days I stumbled across an aluminum tube product which doesn't require welds or bolts to put together, it relies solely on compression connectors for fabrication of the tubing which served me perfectly as I don't have a welder and with my desire to complete build the myself out-sourcing the welding was not an option either. A significant added bonus to the aluminum product is that it can be ordered with a variety of different flanges or fins built in to hold glass inserts which obviously is beneficial for the intended product. (the fins also act as gussets which strengthen the tubes considerably)
All materials required for the project are off-the-shelf materials requiring no tools other than a grinder, reciprocating saw, hacksaw, and drill and other hand tools to fabricate and assemble.
The primary materials list is:
Black anodized aluminum tubing and connector from: EZ Tube Boltless Construction System, Aluminum Tube, Steel Tube, Storage Products.
Brackets to connect cab to tractor frame are galvanized dock corner brackets. A combination of plexi and safety glass used for glazing. Two 12VDC heaters, a $6 rear utility light and a hand operated wiper fill out the opulant comforts for snow-blowing only afforded with the addition of a cab.
I'm not yet quite finished but here's a few photos of the cab in near done mode. It's a little boxy due to the availability of 90 degree connector only but I think it looks ok none-the-less for between quarter or third of the cost of a dealer sourced aftermarket cab such as Sims or Curtis Cab while providing me with another invaluable project. The sub-compact Massey's are not the easiest to build a cab around, the rear handles require about 6 inches wider than I wanted and the bucket joystick plastic covering was removed to keep the cab as narrow as possible. As is, the joystick movement is curtailed somewhat to the right which prevents quick bucket dumping but I'm only using the cab for snow blowing so this isn't an issue. If I were using the fel with the cab the joystick controls would need to moved which would be as easy as added a few shims where the controls bolt to the frame.
/ Another DIY Cab...MF GC2600 #2
Nice job! Nice first post too!
Sure looks boxy as you said but certainly better than my cab that look like this:
Thanks. That's a nice suit you got there, far too oem looking to be diy. I was gearing up to go that route but glad I took the other road. Just finished the roof today, half solid opaque and the front half plexi for good above head views. Still remaining is to cut one piece to fit above the rear left wheel fender, seal up the front lower plexi at the hydraulic connections and complete the door latch and pulls. I also need to fabricate a rad intake air restrictor to prevent all the warm cab air being sucked out through the rad.
/ Another DIY Cab...MF GC2600 #4
Nice job! Sure, it is a little boxy, but I doubt you'll notice it at speeds under 100 mph.:D
Interesting, I had a few goals when I began the project. Try to keep the cab weight at under 100 pounds, spend no more than 1k, no welding and obtain peak aerodynamic efficiency at 100 mph. After my test ride this afternoon in a stiff breeze it's safe to announce I've failed on all but one of the goals. I caught a gust as I approached upwards of 15mph and with the front is so large the tractor blew over backwards. In reality the cab look quite good, the pictures seem to make it look bigger than it really is plus with the loader or blower on the front the overall proportions look much better. You can't see from the pictures but the anodized tubing I used I was able to obtain a very clean oem quality finish to the structure so I'll have to hang my hat on that for awhile.
/ Another DIY Cab...MF GC2600 #6
Jaylegger, at least you have a cab, personally I do not and there are a few times I really wished I did, like trying to keep up with a blizzard before the snow gets too deep, see I don't have a blower either :( Besides you could name it something cute, like the phone booth on wheels :)
A phone booth on wheels, ouch, that was uncalled for.:D This cab can realitvely easily be taken apart so I'm hoping in the not too distant future connectors will be available which provide angles other than 90 degrees I can incorporate into the design.
/ Another DIY Cab...MF GC2600 #8
So how much did it cost? It makes it seem posible to put a cab on my yanmar for snow removal.
/ Another DIY Cab...MF GC2600 #9
I wouldnt mind having something like this.... The bars over the hood would be to save the hood from logs or falling branches.
The aluminum tubing and connectors was around $700 USD, safety glass and plexi about the same. The final pricing for glazing caught me by surprise, I had originally ball parked that cost at around $400, then they saw me coming.
Ordering the tubing in 8' lengths and using more value oriented windows I'm fairly certain you could complete the cab at around 1k. I took a risk with this product as it's strength in this application is yet untested but it's easy no welding DIY fabrication coupled with a clean finish was exactly what I was looking for therefore the risk was acceptable.
/ Another DIY Cab...MF GC2600 #11
Jaylegger, nice job! I wonder, might it be possible to remove the joysitck lever and bend just enough to regain the full movement for the uncurl function? Just a thought there. Also, have you tried running both heaters already? I just wonder if the electrical system will support both of them? I'm sure the current draw will be substantial.
Hi and thanks, yes the lever could be bent to the left to regain full control. I personally would prefer to avoid that route purely for resale purposes therefore felt the shim idea was a good reversible option. I have run both heaters but only for an hour or so with no problems, each heater/fan draws about 12.5 amps, the tractors alternator is rated at 40 therefore there's good headroom even with lights running assuming you've got the rpm's up a bit. I like the flexibility of going with two heaters as opposed to one more powerfull as it gives more options of where you want the heat and air circulation. I still don't know how effective these things will be in cold temperatures but with outside temperature at 3 celcius (high 30's) they keep the cab plenty warm.
Here's a link to the type of heaters I purchased, pretty much just cheap junk but thought I'd start with the very basic first to help determine unfullfilled heating requirements if necessary.
http://www.heartlandamerica.com/browse/item.asp?product=2-in-1-ceramic-heater--fan&PIN=56902&GUID=&DL=IVU8
Primarily because I have nothing more interesting to do right now I've been working on ideas to reduce the boxy look of the cab. I've changed the paint above the glass which breaks up the length of the cab a bit and, as evidenced by the tape, temporily added an idea above the rear wheel. How does that work with the tractor? Not that I'll spend a lot of time on this cosmetic endevour but the tractor does have nice easy curves and smooth flowing lines and the Yugo cab could use some improvement in those areas.
/ Another DIY Cab...MF GC2600 #14
looks nice- i see youoo have same issue as I ddo with the fender handle bars. I have been trying to figure out how to build mine cheaply and easy and work with the handles that stick out.
/ Another DIY Cab...MF GC2600 #15
did you use Bosch or 80/20 type aluminum tubing ? at work we use it too guard assembly machines and is easy to put plexi glass panels in and can assemble it all with out welding.
At first I was going to remove them but after a quick look it appeared I couldn't get at one bolt on each without removing the fuel tank, I then quickly realized I actually like having the handles to put weight on when moving around. It all worked out anyway because the plane outside the handle is pretty much bang on the plane outside the joystick controls. The cab side comes within an inch or two of the handle so I can't grab around it as intended but I can still use it for supporting by weight when necessary. I was contemplating, and still am, using a heat gun to mold the plexi out and away from the handle giving another inch or two but don't think I'll bother. I did use the heat gun to mold the lower portion of the rear window around the two ROPS pillars so it can be done.
I'm not sure which I used but the product sounds very similar to what you have at work. The link to the product I used is in the first post which has the specs, the company is Eztube.
/ Another DIY Cab...MF GC2600 #18
Jaylegger,
Sorry meant no offense with the phone booth comment. just continuing the path of your jokes about failing the 100mph test. I do wish I had on on my tractor in the Winter so you can have last laugh :) and BTW the DIY cab is one of the nicest I have seen here
/ Another DIY Cab...MF GC2600 #19
Maybe some forward facing lights would break up the top some?
Jaylegger,
No worries, no offense taken, it was quite funny obviously you were implying it was a "Super man cab":). I buddy of mine called it the Yugo cab yesterday which I take in good humor as well. Appreciate the compliment
2013 Dodge Challenger Sedan (A60352)
2013 Dodge...
2018 CATERPILLAR 236D SKID STEER (A62129)
2018 CATERPILLAR...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2000 PETERBILT 379 MID-ROOF SLEEPER (A58214)
2000 PETERBILT 379...
2012 GALLEGOS 130 BBL STEEL VACUUM TRAILER (A60736)
2012 GALLEGOS 130...
2012 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR1CJ453408 (A61165)
2012 International...
