How much compost?
/ How much compost? #21
I don't think the cover crop is a good idea for this area.
It seems it would be best to leave the ground bare for the winter.
There are several good reasons to use cover crops. One is to hold the soil in place from erosion by wind and water. Another is a crop that puts nitrogen back in to the soil so you don't have to use as much fertilizer. And another is that when you till it back in it leaves organic matter in the soil, which improves the soil.
What are the advantages of leaving it bare for the winter?
/ How much compost?
What kind of cover can you plant now that will fix nitrogen?
Erosion isn't a big issue for me since it is fairly flat
Bp Fick explained it better than I can in another thread. I will look for it.
Cover crop in Wisconsin is a moot question at this time of year.:D
There are some farmers that just planted winter rye around here and it will probably grow, if not now it will in the early spring. But they plant it for early hay not for a cover crop.
You can plant grass in any month that ends in R. ;)
LOL We plant grass every month if the ground is open.
Well, you can, but that's not going to say it'll grow! :D
Even if it doesn't come up now it will come up much earlier than it will be dry enough to plant in the spring.
/ How much compost? #29
I planted some winter rye in the spring once. It grew to about 8 inches tall and stayed there for the rest of the year. Made the deer happy.:D
/ How much compost? #30
Hey Duffster, do you have to worry about wind erosion? Around here if a farmer tills a field in the fall you can see soil blown all over the snow in the next fields all spring.
/ How much compost?
No, not really.
If we have an extremely open winter you may see a little soil in the snow drifts along the road but even then it is only on the extreme ridges.
Around here the best crops are grown on fall chisel plowed fields.
139 (A63291)
139 (A63291)
2023  FREIGHTLINER M2 22FT NON CDL BOX TRUCK (A59905)
2023 FREIGHTLINER...
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A64279)
2023 JOHN DEERE...
150 GALLON FUEL TANKS WITH BRACKETS (A63569)
150 GALLON FUEL...
2019 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 KENWORTH T680...
2017 ISUZU NPR 18 FT  BOX TRUCK (A59905)
2017 ISUZU NPR 18...
