Just added rear SCV & 3rd function to JD 3038e
/ Just added rear SCV & 3rd function to JD 3038e #1
4440
Member
Kentucky
JD 4440, JD 5303, JD 3038e, JD 250 skidsteer, Kubota L35, ASV 70, Bobcat 743
I just got done adding a Prince 2 spool with power beyond and a WR Long 3rd function valve to my little John Deere 3038e. Here are a few pictures.
Here are a couple of the 3rd function valve.
/ Just added rear SCV & 3rd function to JD 3038e #3
Looks like a nice clean install. Does all functions work as advertised.
/ Just added rear SCV & 3rd function to JD 3038e #4
Nice job 4440;)
Thanks...Yes everything works great.
I had a fairly busy week. I installed all this plus added a 3rd lift cylinder to a 14K dump trailer, reworked to tailgate, made ramps for it, and added a selector valve to a ASV 70. Maybe this weather will break so I can put some of this equipment back to use.
/ Just added rear SCV & 3rd function to JD 3038e #7
thanks for posting these great pics..looks slick... I am going through trying to get this work done at my dealer at the moment, on my new 4105.. you'd think it would be easy... however there seems to be some confusion around it.. i have a couple of questions if you don't mind..
Did you have to install a power beyond kit to to make your 3rd function work.. is that where your electrohydraulic valve is tied into.. ?
and..
can you do all three functions at the same time with your loader/grapple ie.. lift .. curl.. and open/close?
oh yeah and maybe one more question... understand completely if you prefer not to answer... how much did these mods cost you.. i am assuming you did them yourself...
Dave
/ Just added rear SCV & 3rd function to JD 3038e #8
Does anyone know who sells that bolt-on grapple for a JD 305 bucket as pictured by member 4440?
/ Just added rear SCV & 3rd function to JD 3038e #9
/ Just added rear SCV & 3rd function to JD 3038e #11
What model was the Prince valve, and did you have lines customer made? I am interested in installing a power beyond option for my 3038e, but trying to find good information about it has been tricky. Thanks, Pete.
