Shop Tricks
   / Shop Tricks #142
if you used paint thinner or gas to clean up up your paint job, save the left used thinner tainted with paint. let it sit for a few days in a container to let heavy paint settle to bottom and then drian into another recyled container. the result is usable paint thinner to dip your rag in to clean the oil gunked work bench or tractor parts. after you get most the gunk off, you can use a clean dry rag to do a final wipe and it works great. I did this on my wooden work bench that was covered in oil from drill press from drilling metal. the result was I had a clean bench again that not black anoymore!
   / Shop Tricks #143
I actually remember seeing plans on mineral spirits separator. It was a piece of black plumbing pipe with the bottom for sediments and clean spirits to be taken from the middle - it worked on the very same principle.
   / Shop Tricks #144
With all of the guys building their own buildings on here, I thought this tip I learned from my grandpa' years ago might help.
Driving larger nails, wood screws, and lag screws can be made easier, by applying just a dab of Bee's Wax to the end of what ever you're driving. Just dipping in 1/8 of an inch will do. Maybe a little more on the lag screws. I use my electric impact wrench to drive lags. Sure beats wrenching them in..!!
Most toilet bowl rings are made of bee's wax, and are cheap. Even cheaper, are the ones that are deformed, and on the clearance rack.
I drill a 3/8" hole in the end of my fiberglass hammer handles, approx. 1 1/2" deep, and pack these holes with bee's wax. Your container is always with you when driving nails..
When driving screws, I cut the rings in chunks, and melt them in a metal coffee can, with a formed pour spout. Just kinda' squeeze one side of the can with your hand.. I do this on the cook stove, over a low fire. It doesn't take much to melt it. Just be cautious.. Don't want someone burning down their house..!! If you have a camp stove, you may want to use that, outside.
I pour this into various sized pill bottles, vitamin pill bottles, etc. What ever size that I need. It cools, and sets in a few minutes, and you have a handy, sealable container to use out of.
I have also poured it in to the hammer handles ( I have like 6 hammers) when doing larger projects. It's lots faster than packing it in with a knife, or screwdriver. Just grab another hammer...
You may get a dab on the face of the hammer, and cause it to glance off though... I'm usually wearing my Bibs, and a quick swipe on the pantleg, and it's clean.
   / Shop Tricks #145
Ok Guys, here's a product that ive used so many times, I love this stuff. its a 2 part mix, has the viscosity of water, but hardens in minutes like plastic.
I use this stuff to repair wood,
I use it instead of fiberglass resin (it penetrates the old repair panels on Fiber glass really well). when i do Fiberglass repair, i can take a grinder to this stuff after 10 minutes.
Repairs wood in minutes, PolyAll 2000
i will not be without some of this stuff, its truly amazing.
   / Shop Tricks #146
Looks like it would be good for repairing some punky wood where it is difficult to replace the piece.
   / Shop Tricks #147
I have used regular Bondo for that. It worked perfectly well on a wooden door frame for an outside door.
Ken
   / Shop Tricks #149
I was thinking more of something that would saturate dry rotted wood similar to Git Rot. How thick do is your Bondo?
BoatLife Git-Rot : Cabela's
It's been many years since I did that. I dug out all the bad wood and just filled it back in with Bondo. It held up perfect for the ten years that we stayed in the house.
   / Shop Tricks #150
Apperently it does work well for Rotted wood.
My Main use has been Fiberglass - it whicks well and gets into the old glass where regualr resin cannot....the repair is much stronger.
Ive used it on Wood where a bit of strength is required.
ive also ised it to Make/shape parts for my Vintage snowmobile hoods/cowls etc. you can use kid's Plasterseen (modeling clay) as a mould, pour this stuff in and bingo...peel away the clay and you have a shaped part that, while still needing some sandig and final shaping, takes much less time that trying to build it up with glass matt and resin.
2004 Mack CV713 Granite Fuel and Lube Truck (A59230)
2004 Mack CV713...
1991 International 4900 Box Truck (A55315)
1991 International...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
48in Forks and Frame Skid Steer Attachment (A56857)
48in Forks and...
PALLET OF 11 BARBED WIRE ROLLS (A58214)
PALLET OF 11...
2008 CAT D6T DOZER (A58214)
2008 CAT D6T DOZER...
