Kubota BX accessory model numbers
/ Kubota BX accessory model numbers #1
Jeff H
Gold Member
South Jersey
Kubota BX25D
When you look at the Kubota website and I look at the available implements available for my BX25, they don't show the part number / model numbers of the implements.
Sure one can hunt around here on TBN or the internet and come up with them, but it would be nice to have a complete list of all of the model numbers of the available implements that fit my BX25.
It would certainly help when shopping for used implements like grass catchers or front quick attach accessories.
/ Kubota BX accessory model numbers #2
click on the BX24 instead. when clicking implements there are part numbers there that you want. Also click other implements will show you the landpride stuff.
/ Kubota BX accessory model numbers #3
Radioman is right it will show you most of it but not all. I am still looking for the quick hitch part number for a BX24. But the large attachments will be listed.
/ Kubota BX accessory model numbers #4
you are lookig for a BX2751 quick attach sub-frame
Thank you for the BX24 tip. I guess we can assume whatever fits a BX24 fits a BX25, but we know sometimes assuming can get you in trouble!
I like my tractor, it would just be nice if Kubota was a bit better in the information sharing department.
I am not fond of the "go ask your dealer" answer that they often give.
/ Kubota BX accessory model numbers #6
AFAIK, Kubota makes the QC identical for all BXs, which makes sense. The implements are the same for all. Sweeper, snow blades, snow throwers, etc.
Can anyone tell me the proper Kubota brand rear snowblower part number?
Will the 60" BL2660 fit a BX25 or is it too big?
Thanks
Jeff
/ Kubota BX accessory model numbers #8
BPflick, You said they are all the same. Are you refering to the BX22-BX23-BX24-BX25 or every BX model?? Just curious as I have seen some snowblowers from older BX's but the model numbers are different from what Kubota currently lists. Same with the quick hitch. Saw one from a BX18XX but they said it would not fit a BX24. Just want to check.
/ Kubota BX accessory model numbers #9
I actually just found one of the listings. It is a model BX2711 from a BX1500. Anyone know if this will fit a BX24?? The seller said no but from what I read it may fit.
/ Kubota BX accessory model numbers #10
Thanks
Jeff
Hey Jeff,
I just bought a 51" B2789 3pt Snowblower as recommended from Kubota for "B & BX series tractors". (I have a BX24)
Now where's the snow...
Cheers
Rob
I finally found what I was looking for! A nice list of all of the BX accessory numbers and MSRP pricing.
Use Google and search for BX8064A and it should be the only hit that comes up.
The BX section starts on page 75.
/ Kubota BX accessory model numbers #12
Great .pdf someone compiled with some really good information. Saved it to my laptop for future use. Thanks Jeff.
Hi thavil
Yes it is what I was looking for. It amazes me that Kubota does such a poor job advertising the accessories. You would think they would all be in the color sales brochure from the dealership and on the main Kubota web site.
You can tell how poorly they are advertised by the fact that that part number for the suitcase weight bracket only brought up one lonely hit on the whole internet! Now that I posted another question about it on TBN now there are two hits!
I see two different canopies on this list, they are also not advertised very well.
They would sell allot more stuff if people knew it was available!
/ Kubota BX accessory model numbers #14
Are you committed to buying only Kubota brand attachements? I mention this because there are a number of 3PH blowers out there for a whole lot less money. Because they are 3PH, compatibility usually isn't an issue for hooking them up.
FWIW, I have a 60" 3PH blower for my BX2350 and it really is nice having that extra width so my tires don't have to get so close to the drop offs on the edges of the driveway. Plus if you're making any turns while blowing there is less chance of the front tires running over the unblown snow. On a couple of occasions I've hit drifts big enough to fill the entire opening of the blower and the engine seemed to handle it well. If it was a problem I'd just go a little slower.
Hello fish
Not at all opposed to other brands. I was just looking for more info on the Kubota accessories in case I run across some good deals on used items.
/ Kubota BX accessory model numbers #16
umm is th link removed or something ?
/ Kubota BX accessory model numbers #17
The BX2751 (quick hitch) & BX2752 (Mid PTO drive kit) is listed to fit BX 18's, 22's 23's. The BX2711 (quick hitch) & BX2712 (Mid PTO drive kit) is listed to fit BX1500 only.
I am not sure of BX24 fit as it is not listed on the sheet I have for the BX series.
I am looking for the BX2711 & BX2712 and have a BX2751 & BX2752 that I need to part with.
The link changes each time ....., any link posted up here will not work a second time..... so just use Google and search for BX8064A and it will be one of the 2 links........ the other is a post by me here on TBN
/ Kubota BX accessory model numbers #20
hey strongj i have the hitch you need and i need the hitch you have, call me 616-551-0440
2025 IREV Electric Scooter (A64194)
2025 IREV Electric...
Kubota V3600-E3-EG60 Diesel Engine - 3.6L - Tier 4i - Irrigation Pump Takeout (A63689)
Kubota...
UNUSED ATS POWER ATS-PC90 HEAVY DUTY PLATE COMPACT (A64281)
UNUSED ATS POWER...
2016 MACK CXU613 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2016 MACK CXU613...
2014 Ford Escape SUV (A61574)
2014 Ford Escape...
John Deere R15 Rotary Cutter (A64047)
John Deere R15...
