Kubota BX accessory model numbers
   / Kubota BX accessory model numbers #1
Jeff H
South Jersey
Kubota BX25D
When you look at the Kubota website and I look at the available implements available for my BX25, they don't show the part number / model numbers of the implements.
Sure one can hunt around here on TBN or the internet and come up with them, but it would be nice to have a complete list of all of the model numbers of the available implements that fit my BX25.
It would certainly help when shopping for used implements like grass catchers or front quick attach accessories.
   / Kubota BX accessory model numbers #2
click on the BX24 instead. when clicking implements there are part numbers there that you want. Also click other implements will show you the landpride stuff.
   / Kubota BX accessory model numbers #3
Radioman is right it will show you most of it but not all. I am still looking for the quick hitch part number for a BX24. But the large attachments will be listed.
   / Kubota BX accessory model numbers #4
you are lookig for a BX2751 quick attach sub-frame
Thank you for the BX24 tip. I guess we can assume whatever fits a BX24 fits a BX25, but we know sometimes assuming can get you in trouble!
I like my tractor, it would just be nice if Kubota was a bit better in the information sharing department.
I am not fond of the "go ask your dealer" answer that they often give.
   / Kubota BX accessory model numbers #6
AFAIK, Kubota makes the QC identical for all BXs, which makes sense. The implements are the same for all. Sweeper, snow blades, snow throwers, etc.
Can anyone tell me the proper Kubota brand rear snowblower part number?
Will the 60" BL2660 fit a BX25 or is it too big?
Thanks
Jeff
   / Kubota BX accessory model numbers #8
BPflick, You said they are all the same. Are you refering to the BX22-BX23-BX24-BX25 or every BX model?? Just curious as I have seen some snowblowers from older BX's but the model numbers are different from what Kubota currently lists. Same with the quick hitch. Saw one from a BX18XX but they said it would not fit a BX24. Just want to check.
   / Kubota BX accessory model numbers #9
I actually just found one of the listings. It is a model BX2711 from a BX1500. Anyone know if this will fit a BX24?? The seller said no but from what I read it may fit.
   / Kubota BX accessory model numbers #10
Thanks
Jeff
Hey Jeff,
I just bought a 51" B2789 3pt Snowblower as recommended from Kubota for "B & BX series tractors". (I have a BX24)
Now where's the snow...
Cheers
Rob
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52748)
2007 Freightliner...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
Kubota SVL95-2 High Flow Cab Skid Steer (A55218)
Kubota SVL95-2...
1999 CLEMENT END DUMP (A53843)
1999 CLEMENT END...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A54811)
Miller Trailblazer...
2013 CAT 950K WHEEL LOADER (A52472)
2013 CAT 950K...
