Is this trailer wide enough?
/ Is this trailer wide enough? #11
I would use 4 chains like mentioned by Farm Boy. Not only to keep the load from shifting but if something fails you have a back-up. I also like to criss cross the chains.
Guys are right, 102" is max without over width in most states.
Chris
/ Is this trailer wide enough? #12
In Europe your trailer can be 2.55 meter wide without special permit. Except for the 11 ton model, all our payloaders are wider than the trailer. On the road, i've never seen a trackhoe being hauled on a trailer that was as wide as the 3ft wide LGP tracks which are standard in Holland.
/ Is this trailer wide enough? #14
That's what we do, but since you're over a hanging off a little, I'd say maybe try for two at the back, and two at the front. Like I said, in this situation, overkill is very good. Better safe than sorry. How far are you going with it?
This is not optional but required.
I have a piece of equipment that is as wide as my flatbed trailer. I use 2 chains in front and 2 chains in back and I cinch them really tight. I run the chains diagonally so the equipment can't move sideways. If you run your chains lengthwise it would be much easier for your tractor to bounce off the trailer.
It's the law.
/ Is this trailer wide enough? #16
That's what we do, but since you're over a hanging off a little, I'd say maybe try for two at the back, and two at the front. Like I said, in this situation, overkill is very good. Better safe than sorry. How far are you going with it. Kyle
One on each corner - it's the law.
/ Is this trailer wide enough? #18
It's the law.
LB-
It actually isn't the law in most states. Because one chain can give pull to both sides. So, it is close to the same strength as two chains together. That's what we do even when we haul an 8.5k tractor. But, we are 6" from the edge. He is less than 2" it looks like, which is why I suggested using one on each corner. I also like Chris' idea of crossing, say taking front left corner to the rear right, then vice versa for each other. Then maybe an extra going across to be safe and to hold it down more.
Kyle
/ Is this trailer wide enough? #19
NO IT'S NOT
Only if the tractor/vehicle/heavy machinery is over 10,000lbs
under 10,000lbs all you need is 2.
§393.128 What are the rules for securing automobiles, light trucks and vans?
(a) Applicability. The rules in this section apply to the transportation of automobiles, light trucks, and vans which individually weigh 4,536 kg. (10,000 lb) or less. Vehicles which individually are heavier than 4,536 kg (10,000 lb) must be secured in accordance with the provisions of §393.130 of this part.
(b) Securement of automobiles, light trucks, and vans.
(b)(1) Automobiles, light trucks, and vans must be restrained at both the front and rear to prevent lateral, forward, rearward, and vertical movement using a minimum of two tiedowns.
§393.130 What are the rules for securing heavy vehicles, equipment and machinery?
(a) Applicability. The rules in this section apply to the transportation of heavy vehicles, equipment and machinery which operate on wheels or tracks, such as front end loaders, bulldozers, tractors, and power shovels and which individually weigh 4,536 kg (10,000 lb.) or more. Vehicles, equipment and machinery which is lighter than 4,536 kg (10,000 lb.) may also be secured in accordance with the provisions of this section, with §393.128, or in accordance with the provisions of §§393.100 through 393.114.
(b) Preparation of equipment being transported. (1) Accessory equipment, such as hydraulic shovels, must be completely lowered and secured to the vehicle.
(b)(2) Articulated vehicles shall be restrained in a manner that prevents articulation while in transit.
(c) Securement of heavy vehicles, equipment or machinery with crawler tracks or wheels. (1) In addition to the requirements of paragraph (b) of this section, heavy equipment or machinery with crawler tracks or wheels must be restrained against movement in the lateral, forward, rearward, and vertical direction using a minimum of four tiedowns.
/ Is this trailer wide enough? #20
Can you point out where it says that?
Thanks.
ァ393.87 Warning flags on projecting loads.
(a) Any commercial motor vehicle transporting a load which extends beyond the sides by more than 102 mm (4 inches) or more than 1,219 mm (4 feet) beyond the rear must have the extremities of the load marked with red or orange fluorescent warning flags. Each warning flag must be at least 457 mm (18 inches) square.
I'm actually wrong, you get 4" total (I always made it 2" both sides, but that's not correct)
that's a dead copy from FMCSA website current rules, so 4" is correct
EXCAVATOR JACKHAMMER (A58214)
EXCAVATOR...
2019 GALYEAN...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A61307)
PENDING SELLER...
43023 (A59228)
43023 (A59228)
2015 Ford F-150 Pickup Truck, (A60352)
2015 Ford F-150...
36"x12' Stacks of Sheet Metal (A60463)
36"x12' Stacks of...
