Type of fluid for the transmission for M21D?
/ Type of fluid for the transmission for M21D? #1
peimitsu
Out in the country P.E.I. Can.
Mitsubishi M21D
What type of fluid does the transmission take in a M21D? It was that watery when we drained it, I can't tell if it's gear oil/transmission fluid or hydraulic fliud.TIA
Larry
/ Type of fluid for the transmission for M21D? #2
While some manuals call for gear oil, all tractors that have hydraulic FEL's need to use universal hydraulic fluid.
Either way universal fluid is easier on the system in colder climates and lubes just as well.
Rice paddy countries never get that cold so gear oil stays fluid but in our climates it would be much too thick and really tax the system.
Also universal is cheaper and you do need to buy in gals and not pts.
Probably your gear case holds as much as 2.5 gals of oil.
Have fun, and good luck.
I'm assuming that the trans/rearend/hydraulics are all combined and using the same fliud?
2016 Ford F-150 Ext. Cab Pickup Truck (A61568)
2016 Ford F-150...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60352)
2012 International...
2019 FORD F-150 STX CREW CAB TRUCK (A63276)
2019 FORD F-150...
2016 Volkswagen Jetta (A61569)
2016 Volkswagen...
2025 Unused SDLGC80 60v Electric Golf Cart (A60352)
2025 Unused...
10 X6 MANIFOLD (A58214)
10 X6 MANIFOLD...
