1958 Case model 320 backhoe
/ 1958 Case model 320 backhoe #1
bgarrison54
I need the hydraulic cylinder for the bucket on a 1958 Case 320. 4" x 32 " I think. Does anyone know of any ? Thanks, Bob Garrison
/ 1958 Case model 320 backhoe #3
Hello Bob and welcome to TBN.
Here is your best bet. You need to measure the stroke of your cylinder. Then, make your best guestimate as to the bore. Measure the OD of the cylinder and subtract about a quarter inch, close enough. Find a new cylinder close to this, maybe you will find one with the proper ends. Probably not. What you can do is have your ends cut off the old cylinder and welded on the new one. Hopefully, your old cylinder is nothing fancy. If you go that route, take it to a good shop to have it done, not some nutjob with a welder and a 30 pack in the fridge next to it.
Andy
/ 1958 Case model 320 backhoe #4
Andy
Guess that lets me off the hook then:D
Bgarrison: What is wrong with the cylinder you have?
2012 SOUTHERN 130 BBL VACUUM TRAILER (A65643)
2012 SOUTHERN 130...
2015 Kenworth T880 QMC 8060R 40 Ton Tri Axle Straight Boom Crane Truck (A64194)
2015 Kenworth T880...
2007 Allmand Max-Lite ML20 20KW Towable Light Tower (A64194)
2007 Allmand...
KIVEL PALLET FORK ATTACHMENT FOR MINI SKID STEER (A64553)
KIVEL PALLET FORK...
2013 Polaris Ranger 400HO (A66408)
2013 Polaris...
2012 TROXELL 200BBL CRUDE TANKER (A65643)
2012 TROXELL...
