Building permits required???
/ Building permits required??? #21
1*Now I would like electricty brought 700' down our drive to supply this shed for lighting and power for tools such as a welder.
2*Obviously, this is probably going to need a permit.
3*I was also curious as to what fees power companies charge to run overhead power lines to a new meter at a shed? Obviously this varies from region to region.
4*Before I pursue the channels of government bureaucracy.
5* My past experience with local code enforcement agencies leaves me a little fearful.
1*Where would the elect line be starting at ?
2*Shouldn't be any permit as this is an issue of elictric co policy and their approval rather than a gov. agency requirement.
3*And company to company.
4*I'm glad we don't have such government bureaucracy here in my county .
There is no building code or building permits so no need of a building department.
Hain't freedom wonderful!
5* What were they about?
6*you DID need a permit for something that size. anything over 10x12 or anchored to concrete you need a blueprint drawing (sometimes they will take a nicely done and to scale drawing)
7*have it okayed by your building department give them a copy and pay for the permit.
8* i would hate to pay for them to put poles in and run that much line
9*i would look into running a heave line from the house up to it just to run the lights and radio
10*if code enforcement comes you will get fined and have to tear it down ( my friend had a small shop and was adding on to it when code enforcement came he got a fine of something like 300 bux and was told to tear it down.
11*another thing you might be able to do -
if it looks old enough you could say that it has been there for along time and is grandfathered in witch means before they passed that law.
6*-7* How do you know ?
Do you live in the same area?
8*Me 2.
9*There is no house there.
10*I'm glad I don't live in a dictatorship like that.
11*Or it was on the place when he bought it.
In my community anything that cannot be moved or drug around has to have a building permit, Electricty, water or sewer or whatever.
12*Mostly its a way to keep the property updated for tax purposes.
13*.We constantly have people that sneak building projects to beat the county out of property tax. I am sure that is not your intention sir, but be careful and not get socked with some back taxes.
12*-13*Building code enforcement and real estate law and enforcement are 2 different matters.
14*At this point, you're at their mercy.
15*Keep in mind that by not telling them about the building, in their eyes, you have ROBBED them of tax revenue.
Additional improvements on your property drive up your property assessment and increase your taxes. Some counties routinely have their GIS department analyze aerial photography to identify structures, etc, but
16* I've never heard of one using this to identify people that didn't get permits.
Keith
14*Are you sure about that?
15*It's not about taxes its about construction specs.
16*That's because it's not about building codes or permits.
17*I am sure what everyone is saying is true for their area but this is a county by county thing.
My county you have to permit a barn.
The next county over, my property line, you do not on ag zoned land but do if the land is zoned residential. Many places in the country if you have over 10 acres the only thing you have to permit is a septic system.
18*Just depends on your given county.
I would do as blueriver suggests and call the power company for an estimate.
19*They will let you know if you need a permit or certificate of occupancy, know as a CO, from the building department before they can hook you up.
MarkV
17* & 18* We don't have a building code and the only permit reqired is for a septic tank from the county health dept.
19*The elect co here requires their approval but there is no gov permit needed.
If you are installing a new meter,the utility will require a UL inspectors sticker with signature on the panel before they turn the power on.
20*So you will have to pull a permit for the electric.
If your coming off an existing meter,you can do as you please .
20*This is a power co policy rather than a gov regulation isn't it?
/ Building permits required??? #22
I live in a very agriculture friendly county
When I checked about 10 years ago to see if I needed a permit to build an 8x10 tool shed I also asked what I could do with out a permit.
I could build a huge pole barn, no walls (cannot remember the size but was big), dig a pond, put up a fence & gates, dig a well, clear the land, including trees.
1*However, a tool shed did require a permit, but I could not get one for vacant land.
I live on the land now, zoning is poorly and arbitrary enforced around here.
1*Then just tell them it's an AG building then.
/ Building permits required??? #25
I can't imagine anywhere in the US that would allow installation of electric service without a permit. I have put electric service in before and the electric company would not do it without a permit and inspection by the governing unit, be that state, county or city. A meter box needs to be installed and a breaker box connected to it, it must meet all code and inspected before the utility will connect it. In fact in my case, you had to purchase the meter box from the utility company and show a permit to buy it from them.
/ Building permits required??? #26
1*Codes change constantly. 20 years ago I built a 24x24 storage shed and when I asked the town about a permit they said they didn't have any rules to contact the state. I did and was told any agricultural storage building didn't need a permit so I built it.
4 years ago I put up a 8x10 shed and the now building inspector stopped and told me that new rules were in effect and I needed a permit unless I made the shed movable and if it was movable it wouldn't be assessed for tax purposes.
2* I built it on 3 treated 6x6's, no permit and no tax assessment.
1*Did you live within the city limits?
2*I have 2 buildings on skids like that so I don't have to pay real estate taxes on them .
3*In NY the zoning codes are enforced on a town by town basis--not county wide.
3*And if your property is not inside the town thay have no say in what you can or can't do with /on your property.
4*Then it is a matter of paying the fine,
5*paying back property taxes which you owe like everyone else.
6*Then get your permits from now on and sleep better.
4*Why does he owe any fines?
5*Who says he owes any?
6*Are we sure he needed a permit?
Kind of confused as to why.... "When I called the building department, they seemed not to care". The following clearly states that permits are required. Maybe back when you buit they weren't.
7*Are you being taxed on the structure?
7*Good question.
/ Building permits required??? #27
These days most every place in the U.S. require permits. It may not require inspections, but I can almost garentte 'ya permits are required. AG or not.
W. H. Drane - Municipal Codes
Fortunately, there are some places left where you don't need permits. And in those areas, buildings aren't falling down, things aren't blowing up, things are still safe. Permits are just another tax under a different name. Unfortunately I don't live in one of them places, and because work is so slow right now, every permit is getting nit picked to death, because the permits department have the time to nit pick. It is very frustrating trying to get work done right now. You would think that with less work going on, things could get approved faster, ain't happening.
/ Building permits required??? #28
HCJ, I thought I had replied to this but I guess not as I don't see it. As a fellow South Carolinanian (Bamberg), I have done and been thru exactly what you're talking about. I built the initial part of my shop as a "lawnmower shed" in late '06. Came back in late '07 and early '08, added onto it and put a new roof on and all without a permit. After I got the new roof on and look at how nice it was, I then decided I needed power.
Wanted to run it off my house but it was 400 feet away; the cost of the wire made that unwise. I asked around about what was best to do, everyone came back with add a seperate service. Well, I knew that in order to get a power pole in SC, you must get an electrical permit from the County, and to get an elec permit, you must first get or have assigned a ''911'' address. Well, since this was not a part of my residence's service, even tho the same property, I had to apply for the "911" address. That meant "fessing up" to already having built the shop that I was now wanting power to.
So I fessed up, and no one cared about what I had done; what they really cared about and made sure I knew about was what had to be done. So, I did what I had to do to satisfy the building inspector on the electrical permit and hookup to include having a licenses electrical inspect my work and approve it, and paid the $50.00 and got power to my new "address."
Maybe I got lucky but I have learned a long time ago that "fessing up'' is better than 'covering up." I have not built anything since without a permit, which in these parts, the permit is just a formality anyway.
As a side note, even the farmers in these parts cannot get power to a pole in the field for irrigation without that power pole having a "911 address." That assumes it's a seperate pole and a seperate service for nothing else.
/ Building permits required??? #29
"4*I'm glad we don't have such government bureaucracy here in my county .
Hain't freedom wonderful!"
Just the type of person that calls the office all the time to turn the guy down the street in. They think it's all fine and dandy until someone puts up a building it the setbacks or build a POS, then they call a bitching and want us to march right out.
/ Building permits required??? #31
I live in a rural county in Missouri. You can build ANYTHING without a permit,including a house. The county wants to know only for property tax purposes. Call the electric company and see what their policy is. They might let you bury your own wire from the pole.
/ Building permits required??? #32
Kind of confused as to why.... "When I called the building department, they seemed not to care". The following clearly states that permits are required. Maybe back when you biult they weren't. Are you being taxed on the structure?
"A permit is required anytime that a new building is constructed, structural changes made within a building or additions to existing structures. Also, permits are required for electrical upgrades, meter changes, etc. Plumbing permits are required for new plumbing fixtures or for relocating plumbing fixtures. Mechanical permits are required for new equipment, change-outs, running a gas line, etc. For more information, contact the Codes Enforcement Division at (864) 467-7060."
Perhaps his county adopted a building code after he built his shed. He hasn't given us enough info.
/ Building permits required??? #33
Not sure about your part of Md., but Charles County has an exception to the code for barns. No permit required to erect a barn as long as the property consists of 5 or more acres. Trying to preserve/enhance the ag lifestyle. Otherwise, anything bigger than 10x12 gets permitted. Of course all utilities are permitted regardless of use.
Nitpicking or reluctant to make a decision. State and local always coming up with rules that they can't interpret. Trying to get approval on a commercial site, disturbed soils became an issue. They wanted to include the area being replanted in the disturbed soils allocation.
/ Building permits required??? #34
Most is the key word. Not every place requires permits. I know of counties and even municipalities that don't require permits other than for a septic. There are areas where only electrical work requires a permit.
Some places do require permits for certain work but they don't require inspections. Its usually siding, gutters, replacement windows, and roofing that fall into the permit required but no inspections required category. In cases like that permits are required for tax asessment reasons, not life safety reasons.
/ Building permits required??? #35
Yeah, I love having to repair stuff not built to code. Can't tell you how much fun it is.
I've made some good money bringing stuff others have done up to code! Its cheaper to do it right the first time than to redo it later.
/ Building permits required??? #37
This don't apply to Washington county .
The county and the city are 2 different entities.
Like I said Washington Co. don't have a building code and the only permit required is for a septic tank installation.
While the city is located within the county it is not the county so as such has no jurisdiction over the county or its residents.
/ Building permits required??? #40
But the County does.
LBrown, on this and on other threads you have repeatedly stated this. As someone who lived in So. Ohio for many years and did a considerable amount of building there, I take exception to your oft repeated claim that "we ain't got no stinkin' building permits here". Attached are the Washington County Building Permits forms. In the previous post, I provided the link to the Washington Building department, which subscribes to the (BBOC)State of Ohio Building Code 2002.
Heck, I've got free long distance on my cell phone. What say we just make a a quick call to Washington County and verify?
Kubota V3600-T-E2 Turbo Diesel Engine - 3.6L - 84 HP - 2018 - Tier 2 - Pump Takeout (A63689)
Kubota V3600-T-E2...
(1) 20 Yard Roll Off Dumpster and (1) 40 Yard Roll Off Dumpster (A65579)
(1) 20 Yard Roll...
2019 Toyota Tacoma Pickup Truck, VIN # 5TFSX5EN2kX065481 (A65563)
2019 Toyota Tacoma...
2014 Ford Transit Connect Handicap Van (A61573)
2014 Ford Transit...
Homemade Utility Trailer (A62613)
Homemade Utility...
2014 MACK PINNACLE DAYCAB (A59914)
2014 MACK PINNACLE...
