Building permits required???
/ Building permits required??? #1
HCJ
upstate South Carolina
Kubota M6800 4WD
Several years ago, I built a 40' x 40' pole shed on a 300 acre wooded tract for tractor storage. I realize laws vary in each state or county, (I am in Greenville Co., S.C.) but was curious if you guys obtained permits for similar work. I operated under the premise that since this was not a residence, had no electricity or plumbing, a permit was not necessary. When I called the building department, they seemed not to care (or not know) so I just went ahead and built it. No problem has ever arisen.
Now I would like electricty brought 700' down our drive to supply this shed for lighting and power for tools such as a welder. Obviously, this is probably going to need a permit. My fear is that by drawing attention to this, am I openning a "can of worms" drawing attention to my already built pole barn? Note my shed has no floor or walls, and no one lives on this property. I was also curious as to what fees power companies charge to run overhead power lines to a new meter at a shed? Obviously this varies from region to region. Before I pursue the channels of government bureaucracy, I just wanted to see if anyone else had any knowledge of similar issues, especially in S.C. My past experience with local code enforcement agencies leaves me a little fearful.
/ Building permits required??? #3
If you truly believed no permit was necessary, why are you worried about "openning a "can of worms"" ??
What "past experience with local code enforcement" did you have ?
/ Building permits required??? #4
In my community anything that cannot be moved or drug around has to have a building permit, Electricty, water or sewer or whatever. Mostly its a way to keep the property updated for tax purposes.
We constantly have people that sneak building projects to beat the county out of property tax. I am sure that is not your intention sir, but be careful and not get socked with some back taxes.
/ Building permits required??? #5
At this point, you're at their mercy. Call your counties department that issues permits and tell them you're considering building a barn and ask what requires a permit. About five years ago, I built a shed in my back yard. I was told that anything above 10'x12' (or was it 12'x12') required a building permit.
Keep in mind that by not telling them about the building, in their eyes, you have ROBBED them of tax revenue. Additional improvements on your property drive up your property assessment and increase your taxes. Some counties routinely have their GIS department analyze aerial photography to identify structures, etc, but I've never heard of one using this to identify people that didn't get permits.
Keith
/ Building permits required??? #6
Don't ask about permits, just call the electric company ... they will tell you what they can and can not do. Then go from there.
/ Building permits required??? #7
I am sure what everyone is saying is true for their area but this is a county by county thing. My county you have to permit a barn. The next county over, my property line, you do not on ag zoned land but do if the land is zoned residential. Many places in the country if you have over 10 acres the only thing you have to permit is a septic system. Just depends on your given county.
I would do as blueriver suggests and call the power company for an estimate. They will let you know if you need a permit or certificate of occupancy, know as a CO, from the building department before they can hook you up.
MarkV
/ Building permits required??? #8
.... Note my shed has no floor or walls, and no one lives on this property.
I dunno, it doesn't even sound like a shed to me if it has no floor and no walls. What is it, just a roof on poles? If you went with out electricity for 4 years, maybe you can still do without it? Can you just build a simple little shelter and put in a portable generator for when you may need some power?
/ Building permits required??? #9
If you are installing a new meter,the utility will require a UL inspectors sticker with signature on the panel before the turn the power on.So you will have to pull a permit for the electric.If your coming off an existing meter,you can do as you like.Remember that you are liable for the work,and any damage improperly installed electric may do.SO an electrical permit,and inspection is the way to go IMO,irreguardless of if you get a building permit,around here,one has nothing to do with the other.
One other thing,around here the utility company is priced very competite with local contractors for buying,setting the poles,and the hookups.We used them,because by giving them some work,we got it all finished turned on faster at the panel in the end. To go 700 ft your gloing to need another transformer down there or very large wire off your existing utility to combat voltage drop.My rough guess is the poles and wiring to the panel will cost you 4-6000 dollars.Id get a local electrician to quote you a heavy underground aluminum low voltage run if its possible,youd save buying another meter and the monthly fees that go with it(30.00) a month here just to have a meter.
/ Building permits required??? #10
I went through this not long ago here in Michigan. I dont know what was worse---dealing with the county or dealing with the electric company. Alot of hoops to jump thru. If your electric company is like the one here you will need an address on your building which you have to get from the county ($50.00 in Michigan) The electric company had varying rates they charge for running the service, setting the pole, ect, based on how much electricity they think you are going to use. The more you use per month the lower the hook up fee. I have heard of some people who have their local electric company run a temporary pole to their structure (secluded pole barn, hunting cabin, getaway) and dont pay the high fees of a regular service to get hooked on. I guess its a loophole in the system. I heard of a hunting cabin thats been on a temporary pole over 10 years. Seems the electric company does not want the expense of running a regular service a couple of miles through rough terrain. The new owner made a visit to the electric company and they were well aware of the temp pole. Go figure
/ Building permits required??? #11
I live in a very agriculture friendly county
When I checked about 10 years ago to see if I needed a permit to build an 8x10 tool shed I also asked what I could do with out a permit.
I could build a huge pole barn, no walls (cannot remember the size but was big), dig a pond, put up a fence & gates, dig a well, clear the land, including trees.
However, a tool shed did require a permit, but I could not get one for vacant land.
I live on the land now, zoning is poorly and arbitrary enforced around here.
/ Building permits required??? #12
Definitely a county by county deal. In my county you have to have a permit, engineered drawings etc. to build a pole barn. You can't even take an existing structure down and move it without engineered drawings and a 'move' permit. In another county I looked at property in a pole barn is an 'Ag' structure and no permit required. It seems to follow how developed your county is.
As far was permits to run electrical usually the contractor hired to do the work pulls whatever permits they need. I would start with a call to the electric company.
/ Building permits required??? #13
Codes change constantly. 20 years ago I built a 24x24 storage shed and when I asked the town about a permit they said they didn't have any rules to contact the state. I did and was told any agricultural storage building didn't need a permit so I built it.
4 years ago I put up a 8x10 shed and the now building inspector stopped and told me that new rules were in effect and I needed a permit unless I made the shed movable and if it was movable it wouldn't be assessed for tax purposes. I built it on 3 treated 6x6's, no permit and no tax assessment.
I guess this is a long winded way to say that you need to check what the rules are at the time you build.
/ Building permits required??? #14
In NY the zoning codes are enforced on a town by town basis--not county wide--just make sure you get the answer from the correct governing body for your area.
/ Building permits required??? #15
Maybe just call any local electricians and ask them what it would take. Don't give them a particular road or street name. They might be able to give you a reasonably accurate answer. And if you look into getting power if you have a backhoe rather than setting poles see if you can run underground power. It might cost a few more bucks. You would draw less attention with out power poles running to your building. I would think with no walls on the building the requirement might be for GFI type circuits because of exposure to rain or moisture. Now if you enclosed the building that might change that picture. Who knows it is such a can of worms as you have mentioned. Keep us posted.
/ Building permits required??? #16
I wouldn't bother with the poles. I would rent a ditch witch and trench it to bury the line. Quick and propbably alot cheaper considering you can do it on your own. Just maybe need a electrian to do the tie in
/ Building permits required??? #17
Looks to me that greenville county has adoped the ICC codes. The only building that I am aware of that would be exempt would be less than 200 sf under the 2006 IRC.
/ Building permits required??? #18
Codes and permit requirements are different in different locations. The county where I live requires a permit for any construction or repair valued at $1000 or more. The permit requirement is $500 or more in some area towns. No jurisdiction in my area goes by building size when determining if a permit is needed. Its all figured on the value of the improvement here. My county requires permits for improvements valued at $1000 or more, but does not charge for permits if the property is zoned ag. One area town waives the permit fee for not-for-profit owned properties. I own property in another county that doesn't require any building permits other than for a septic system, and thats only because the state requires them to do so.
I agree with the person that said to call the power company. They'll tell you what you need. They may say you need a permit. They might sat you don't.
/ Building permits required??? #19
Kind of confused as to why.... "When I called the building department, they seemed not to care". The following clearly states that permits are required. Maybe back when you biult they weren't. Are you being taxed on the structure?
"A permit is required anytime that a new building is constructed, structural changes made within a building or additions to existing structures. Also, permits are required for electrical upgrades, meter changes, etc. Plumbing permits are required for new plumbing fixtures or for relocating plumbing fixtures. Mechanical permits are required for new equipment, change-outs, running a gas line, etc. For more information, contact the Codes Enforcement Division at (864) 467-7060."
/ Building permits required??? #20
Well, I think it is time to get it legal, before you add electric. Explain your problem. I don't think they can make you tear it down, but they may make you prove it meets code, like exposing how deep you put the poles and how much concrete you put under the poles. Digging a hole next to one ought to prove it. Everything else is easily inspected because it is totaly exposed.
Then it is a matter of paying the fine, paying back property taxes which you owe like everyone else. Then get your permits from now on and sleep better.
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
Black Widow 2 Seater GoKart (A62613)
Black Widow 2...
Massey Ferguson 8200 Flex Grain Platform (A66285)
Massey Ferguson...
5ft 3in Wagon Wheel Table (A65583)
5ft 3in Wagon...
Bulk Lot - Atlas Copco Pump End Components (3) Pallets - Selling as One Lot (A63689)
Bulk Lot - Atlas...
2008 PETERBILT 365 (A65643)
2008 PETERBILT 365...
