Dump Truck Stalls
/ Dump Truck Stalls #1
Village Idiot
Northern NH
Kubota 4240; Deere 4020
Geez this site is addictive.
I bought a '94 GMC 3500 with a dump bed. The dump hydraulics are run by an electric motor (not PTO) and even when the bed is empty the truck nearly stalls when lifting (hey it was cheap!). If I rev the engine the lift works fine. Since I've never had an electric hydraulic pump I'm not sure if this is normal or indicates a problem with the pump/alternator.
At first I figured it was just a bad (or undersized) alternator but after reading a different thread on dump trucks I'm starting to think it may be the pump itself. Part of me wants to ignore it until something breaks and then fix what's wrong, but the other part of me wants to fix it before I have 3 yards of crushed rock in the back with no way to lift it.
Any wisdom on how I should tackle this?
/ Dump Truck Stalls #2
I would test the battery and alternator, if it is an electric hydraulic system then those should be the only affected items on the truck.
/ Dump Truck Stalls #3
Take and clean up any and all connections to the pump motor. That thing is going to want some good current to drive it. Any corrosion on the connections can affect it. Especially if it has been splashed with road salt. Is there a fluid filter for it? Check that if there is one. Unloading that by hand would be a drag if you had a nice dump bed that was supposed to be working. I want a dump bed for when I have a load of wood chips after doing a tree job...
/ Dump Truck Stalls #4
Check to see that the wire is heavy enough going to the motor from the battery and you have a good connection if the ground side uses the chaise run a heavy wire from the pump to the battery as over time you loose the ground.I use 00 welding wire, also check the condition of the bushings in the lift I had a unit that would not lift until the body was lifted up a few inches then it would lift fine made new bushings and it worked like it should.
I would also put a gauge between the pump and the piston and check pressure.
/ Dump Truck Stalls #5
Letting the truck run at idle, is not putting a lot of juice in the battery. If the hyd pump motor runs good above, then do so. Have you measured current draw on the hyd pump motor, and is the alternator putting out 13.5 to 14.2 v when charging? How old is the battery. Do the cables to the motor get hot?
/ Dump Truck Stalls
Jeez you guys are great!
I'll start with the wiring, and work back from there. So far everyone seems to be suggesting electrical issues "upstream" from the pump. Give me a week or so to run some trials.
Thanks again.
JC
/ Dump Truck Stalls #7
Thanks again.
JC
A week! :eek: We can't wait that long! :D I do have to add that you said when you start to lift the bed it starts to stall the engine. That might indicate the electric motor is gritted up and pulling a lot of current. If it has brushes you might check those. Also clean and lubricate bearings or bushings. If you can uncouple the motor from the pump then see if it still pulls down your engine. That would help to isolate the hydraulic side.
/ Dump Truck Stalls
Just a quick follow-up here.
I checked the wiring and nothing was corroded. Jumping the ground with a jumper cable made no difference. I couldn't find a hydraulic filter (although it may be tucked away somewhere I didn't see).
I have found that once the hydraulic fluid gets warm it is MUCH easier to lift the bed up. It still needs a little gas, but my foot is barely on the pedal. It really struggles when I have a few tons of rock in the back, so now I run it up and down empty once before I take my first load of the day. I have found that I just can't haul as much rock as I thought.
Thanks for all the suggestions.
/ Dump Truck Stalls #9
I don't know what you have for oil in it, But I sold and installed a few and they came from the factory with ATF,and that is what the manual specified.
/ Dump Truck Stalls #10
It is hard to see where a 12 v motor would stall a large truck. I think there is some wiring problem, or the 12 v motor is drawing to much current. How hot does the motor get after raising and lowering several times? Have you checked the pressure on the pump?
2018 Cat D6T LGP VPAT Dozer (A62679)
2018 Cat D6T LGP...
1999 CHEVROLET 3500HD SERVICE TRUCK (A64277)
1999 CHEVROLET...
2014 Ford F-150 4x4 Ext Cab Pickup Truck (A64194)
2014 Ford F-150...
14in Bucket w/ Teeth Excavator Attachment (A64194)
14in Bucket w/...
Used Landpride GR1525 Stump Grinder
Used Landpride...
2022 CATERPILLAR 272D3 SKID STEER (A65053)
2022 CATERPILLAR...
