telco technology rant
/ telco technology rant #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
So here we are.. 21st century.. space flight technology is hitting 60ys old ( almost retirement age! ) and where is the telco at?
ever notice if you dial a 12 digit number (1+ac+prefix+4) and you are in an extended calling area that only requires 7 digits, that the lil recorded message comes on and tells you you don't need the 1/0 or the area code and to waste your time redialing...
If the darn computer is so smart that it knows you don't need it.. why doesn't it just 'drop' the extra and connect the darn call?!?
soundguy
/ telco technology rant #2
Back when our area code was running out of # the powers at bee overlayed 2 area codes now with cells we have three and still going to run out of numbers
I asked a TELCO rep one time why they didn't go to 4 digits in area code and 4 for the prefix and they would have enough # to last a while she said their soft ware at that time had to have a one in the middle of the area code or it would be rejected! so now we have the over laps and more confusion.
tom
yep.. just keep patching that old broke stuff telco guys.. that's why usa has the least advanced telco system of any modernized country.. :)
soundguy
/ telco technology rant #4
Soundguy, I would expect the call to go through if you dialed 10-digits (Area code + prefix + 4) to a non-toll area, works here anyway. If you really did dial 1+area code + prefix + 4, then the 1 is probably what is confusing it.
BTW, check you math: 12 digit number (1+ac+prefix+4) is really 11 ;-)
RavensRoost
/ telco technology rant #5
That's what I get..
" It is not necessary to dial a 1 when making this call, please try your call again"
/ telco technology rant #6
soundguy[/QUOTE]
Ahh the computer is saving you a toll charge. The transaltions are set to fail if you dial an EAS areas using a toll kick. The switch did what it was told.
If it did'nt you would receive a toll bill for the call. Translations are set to fail or complete based on set parameters of a human. No upgrade in the world will solve this issue. There is a set policy by your local carrier to fail the call.
Now if you were on my switch we would route the call and delete the toll kick. This is easy as we only have a small EAS areas. In a big areas this woudl require a very complex set of translations to look at called number and originating TN. Then start matching to IF Then statemeants.
Who told you we have bad telecom here in the USA? Just too many legacy issues and fairness doctrines to move forward. IF we make it work for soundguy then it won't work for billbob. So you can't fix it. Well tell Billy bob it is the new centruy . get with the plan. We might hurt blly Bob feelings. Ok we will keep a full blown dial-up shelf workign so billy bob can have internet.
That's my point.. if it 'KNOWS" that it is saving you the toll call.. then it should be possible to drop the extra digit and complete the call with no toll.
As for who told me.. no one had to.. you point out the main issue.. legacy problems.
many other modernized country developed their good telco systems way after ours.. and had better technology to build up on.. we are stuck with some areas that can't even get good dialup service past 9600bps due to old twisted copper.
where I live, the community was put in and wired in the 70's.. it wasn't until 2ys ago that they ripped all the junk up and put in new service so we could come intot he modern age and get 1.5meg dsl.
It's an aging patchwork network... and I assure you, if it was rpiied out and started anew.. it would benefit billy-bob JUST AS MUCH as soundguy.
And i expected a 'no it's working perfectly' answer from a telco guy. No companies ever willingly own up to their own major shortcomings... :(
wanna see good telcom setups.. look at japan....
soundguy
soundguy
Who told you we have bad telecom here in the USA? Just too many legacy issues and fairness doctrines to move forward. IF we make it work for soundguy then it won't work for billbob. So you can't fix it. Well tell Billy bob it is the new centruy . get with the plan. We might hurt blly Bob feelings. Ok we will keep a full blown dial-up shelf workign so billy bob can have internet.[/QUOTE]
RavensRoost
Maths working fine.. it's the darn micro laptop keyboard that is the problem!
soundguy
/ telco technology rant #9
A Telco Rant, I'm in !!! :)
It depends on how theTelco builds their routing tables for the switch. most modern switches could be programmed to avoid this annoyance, older switches couldn't.
on my cell phone I don't need to dial 1 for "long distance" because all US numbers are "local". on my landline, I live in an area where you have to dial area code for local numbers, and if you don't dial 1 for a long distance number, you get the famous recording. With the demise of landlines, they should remove the whole long distance thing, and make all calls within the country a "local" call. It's long distance for me to call my kids school just down the road, but I can call 20 miles past it as a local call, makes no sense.
/ telco technology rant #10
It's never made any sense. Always these arbitrary long distance boundaries, usually having nothing to do with where people work or shop. Where my Mom lives in Ohio, you have to dial as you described. In Maine the state legeslature passed a law requiring all calls in-state be dialed with only seven digits. We only have one area code; 207. Somehow, with the pressure put on them, the telco is able to satisfy that law.
Dave.
/ telco technology rant #11
I'm thinking it comes down the the all (once) mighty dollar.
Seems it's a good set up to control who gets what long distance dollar and who doesn't. Same applies to the whole system as far as updating is concerned. It's only going to be done if it's "economically feasible", again, the All mighty dollar.
/ telco technology rant #12
You're right that this is not a technology issue... In Verizon Maryland you can dial a local call with 10 or 11 digits (with or without the leading 1), but a toll call requires 11 digits.
Mike
/ telco technology rant #13
Just try dealing with Fair point sometime. You'll find that its back to stone age.
Yep.. I live on the southern boundry of my county, and the next county is actually just a thin strip .. a couple blocks wide at that point.
I can literally toss a rock out my back door and whatever it hits is a long distance call for me. If I make a good drive with a golf ball out of my pasture I acan actually get it intot he 2nd county over!.. now.. as for north.. I can call something like 60 miles north and it's all local.. go figure!
soundguy
Mike
Whether it's cost prohibitive or not.. it's still a technology issue.
sad fact remains the technology is there to make the call go thru as dialed and let the computer sort out who gets what money.
remember back when you had to set dip switche\s on computer hardware to configure it before plugging it in to your computer?
then they moved on to software configuration setup..
then poof... plug and play and it just automatically gets figured out on the fly at bootup.
then fast forward a bit and you have hot swapable stuff.
soundguy
IMHO.. with broadband developing as fast as it is.. landline operators need to be getting their act together. I know plenty of areas that have wi-fi.. or get good broadband signal in places that is still on POTS and has no high speed access.. or even high speed dialup due to the 3-4 decades old copper pair and load coils every block...
soundguy
/ telco technology rant #17
Sometimes those clunky old computers work in our favour.
About 10 years ago we went from 7 digit local phone numbers to 8 digits, and 2 digits for area code. When the change came in they told us we didn't need to use the area code anymore if we were dialling within that area, you could still dial it, you just didn't need to.
Anyway, for about 6 months you could dial anywhere in the state and pay only the local call rate if you left the area code off - NO LONG DISTANCE CHARGES :)
Those still dialling the area code had to pay long distance, which is why I think it took the telco so long to catch on :D
/ telco technology rant #18
JMHO - but POTS will get eventually get upgraded to fiber (Verizon FiOS, etc) but us more "rural" folks will be on copper probably another 100 years :D
Fiber will go into the denser areas, but the problem comes in for areas where farmland is sold and carved into 3 + acre lot communities (like mine). A 100acre farm that only had one phone now has to support 30. Still not worth running fiber, so they cobble more stuff together on the antiquated, overloaded, POTS.
When we moved in -newly built house - had horrible phone service. Noisy static and even some party line action. Twelve service calls in two years and they could resolve it. Dial-up was useless (went satellite). Paying $50 month plus long distance.
Surprisingly, a couple years later, cable rolled in - so I switched to VOIP. Not the greatest, but better than the phone company and half as much
So my take is telco and all other broadband companies will essentially become the "phone companies". That's why Verizon has the big fiber push going and everyone is jumping on the VOIP bandwagon
What I am curious to see is how broadband carriers handle VOIP. I have Comcast cable broadband, but use Vonage for phone. Now Comcast offers VOIP and tries to get me to switch. Since they own the network, I am curios to see if they will try to "force" me to switch to theirs.
Should get interesting - could be very competitive, which should be good for all. But the concern will be for folks that don't get the broadband capability for a long time. It will create a serious gap.
Sorry for the ramble - just my uninformed perspective
Funny thing.. I have sprint broadband on my work pc ( NO DSL SERVICED from the stinkin telco available here! ).. and I get the same godo 1.5 meg speed as my wired dsl service at home.. voip works fine as well.. mind you this is signal dependent.. pull under a bridge/tunnle or thru thick trees and signal drops a bit and thruput drops..
soundguy
2025 XKH39 39in Hydraulic 4-Way Clamshell Bucket Mini Skid Steer Attachment (A66734)
2025 XKH39 39in...
2019 Chevrolet Tahoe SUV (A66738)
2019 Chevrolet...
Cub Cadet LT 1042 Riding Mower (A65579)
Cub Cadet LT 1042...
2013 MITSUBISHI FE 4X2 S/A 20FT BOX TRUCK (A69167)
2013 MITSUBISHI FE...
2007 PETERBILT FLAT TOP SLEEPER  385 (A67714)
2007 PETERBILT...
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
