Differences between L seris and M series
/ Differences between L seris and M series #1
sqdqo
Marquette Michigan
Massey Ferguson 492 w/Quicke Q750 loader
What are the differences between the L series and M series tractors? Are M series more robust? Are M's more of an AG than L?
/ Differences between L seris and M series #2
"M" are stronger all the way round. PTO,frame, lift capacity etc.
Are M's available with mid PTO?
/ Differences between L seris and M series #4
I dont think the M's have mid pto but im not 100% sure about that.
/ Differences between L seris and M series #5
Kubota Tractor Corporation - M Series - Utility/Ag Tractors and Specialty/Ag Tractors
Just guessing here, but your question about a mid PTO suggests you are thinking Mid Mount Mower deck? The M isn't really pointed toward mowing with a belly mower. Additionally, the size and weight of this rather LARGE machine would make a surreal sight on anybody's lawn, even the lawn the size of the White House. Kinda like taking an 18 wheeler over to the mall to pick up your wife's shopping bags. :)
Have you ever stopped by a Kubota dealer and just sort of looked around? You might want to visually appreciate the size differences between a B, an L and an M. It's fairly dramatic. Just sayin.
/ Differences between L seris and M series #6
I went from a B to an L which was significant. I think a similar jump would happen when going from an L to an M. I agree with bp, ten minutes walking around a big dealer lot will answer more questions than all the posts you'll get here. Once you find your niche, talk to a salesman. After you've educated your self and still have questions, come on here and ask Messick's, they are a great source of detailed answers.
/ Differences between L seris and M series #7
all good advice. I would think your intended use and how much money you want to spend would impact your decision also. I have a an L series and for my needs 100-200 hours a year hauling cut wood, digging occasional hole, clearing snow, cleaning corral, lifting misc things as needed, etc. it works fine for me. Also I live in heavy trees and the size works well negotiating the thick trees in places
/ Differences between L seris and M series #8
The "M" series also is not available with the hydrostatic transmission, if that is important to you.
MarkV
My use is heavy wood hauling, lifting heavy logs and heavy snow removal. I life in far norther michigan, annual snow here is easily 200 plus inches per year.
/ Differences between L seris and M series #10
Well, if you are below the bridge, I would highly suggest you stop by Ginop Sales. They have three locations, Williamsburg (Torch Lake), Alanson, and I forget the third, oh yeah, Hillman. Great folks. Honest as the day is long. If you go to Williamsburg, ask to speak to John. Tell him Fred sent ya! :)
/ Differences between L seris and M series #11
in looking at a lot full of tractors, sometimes you can't get a sense of scale with all that orange machinery around. go to the website and print out specs for the models you're looking at in L & M as well. including fel capacity I learned the expensive way starting w/ L trading back till I got the right one in M series). My lesson was that it's not just about HP.....the M series is more robust in about every way: frame size, construction, weight, tire size, etc. that all have a bearing on performance in addition to straight HP...but the B, L, & M models fit perfectly in the niches for which they are designed..If you had hoped for a mid mount, maybe look smaller than M..rule of thumb? study your needs (furute too) choose a model, then go one size up. you won't be sorry bb
/ Differences between L seris and M series #12
I have an M7040.
The dealer I bought off of has a row of tractors, under a roof, from the BX through the MX. Brings the size difference into focus pretty well that way. You see that the front tire on the MX is the same as the rear on (IIRC) an L and that the front tire of the M40 series is nearly as tall as a B's.
What was the inquiry about a mid PTO? They do not come with one. What implement were you wanting to use?
Mid PTO for front mount snowblower. We get alot of snow.
/ Differences between L seris and M series #14
Look for some posts by a guy named 4shorts. He has a tractor with a rear snowblower and a plow blade on the front adapted to the skidsteer QA. I believe his rear mounted blower works going forward. He used it to clear some parking lots. He lives in Canada I imagine they get some snow also. I guess you need to also figure out Cab versus no Cab. It would be good for blowing snow. Not so good for being in the woods I would assume.
/ Differences between L seris and M series #15
Actually, after the Kubota Dealer Meeting last weekend, there will be two "M" models (MX4700HST & MX5100HST) coming that will be available with a HST transmission.
/ Differences between L seris and M series #16
Cool!:cool:
/ Differences between L seris and M series #17
Erskine builds a blower that runs of the rear PTO of a tractor. The only draw back to it is that when on the tractor it is low and hangs out the back of the tractor a couple of foot. With it being built this way you could have trouble with it on irreglar terrain.
Depending on what else your needs are like with the logs as far as weight and the heights a L-series might do fine for you.
/ Differences between L seris and M series #18
Might be able to fit a hydraulic powered blower up front. Skid steer style.
Although, you might need a PTO pump to get the GPM's.
/ Differences between L seris and M series #19
The Kubota dealer around here says that the M series are designated as "agriculture" tractors and are exempt from some of the silly California requirements.
The L series and smaller are "hobby farm" tractors and are burdened by having to jump through more government hoops.
/ Differences between L seris and M series #20
Even the big Mxx40 (e.g. M8540 and 9540) series have added turbos to meet Tier 4 emissions requirements. Only added about 1 hp :mad: at a lot of expense.
I got a flier this week from Quick Attachments, they have a forward operating rear mounted snow blower. I don't know if that's a good idea or not.
Ken
Pull-Behind Spreader Tractor Attachment (A61572)
Pull-Behind...
2019 Jeep Grand Cherokee SUV (A61574)
2019 Jeep Grand...
Lift cylinder for model 48 john deere loader
Lift cylinder for...
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2001 Ford F-150 4x4 Pickup Truck (A59230)
2001 Ford F-150...
2007 International 4400 S/A Dump Truck (A61573)
2007 International...
