Position of bucket when parked?
   / Position of bucket when parked? #1
jwease
Member
Fulton (Central), NY
2017 Kioti/CK3510CHSE
I have my tractor outside. What is the proper position of the bucket? I currently have the bucket fully retracted. My thought is that the cylinders are then fully retracted therefore protected from the elements and possible rusting. I was told that I should have the bucket extended at least enough to prevent water from accumulating in it. I'm also wondering if its common for the paint to peel off of the inside of the bucket? In large flakes sometimes.
   / Position of bucket when parked? #2
Yes paint will peel.
Yes you should have your cyls. retracted to protect them from damage.
Ideally you'd have a tarp or something on the machine so that it does not sit totally exposed to the elements.
I'd not let the bucket sit with water in it if it was me.
I'd either tarp or start regularly and dump out water.
Joel
   / Position of bucket when parked? #3
I like bucket flat when park inside,outside tip just enough for water to run out..I agree about the tarp or any cover.
   / Position of bucket when parked? #4
I have all kinds of different equipment and don't worry about the cylinder rods being exposed UNLESS they sit longer than 30 days. Most equipment is made to handle the extremes of the outdoors, but if it's not being used on a regular basis, the rods can rust because the thin layer of oil will break down over time from not being used and then you will have seal leaks. I park my machine inside over the winter and leave the rods exposed and have never had a problem.
   / Position of bucket when parked? #5
When I take my backhoe off and store it under a leanto, I spray any exposed cylinder rods with fluid film. FF stays in place for a long long time. But, it's not cheap. So, I only use it for "storage", when I know the equipment isn't going to be used for long periods of time.
Thank you for the responses. I should add that my tractor is only outside temporarily. Its normally kept inside when not being used.
   / Position of bucket when parked? #7
If you don't plan to carry liquid in the bucket, you could drill a couple of 1/2" holes in the curved portion that sits on the ground when it is retracted. That's what I did and If I do carry any liquid ( I think I did It once) I just plugged the holes with some plumbers puddy.
   / Position of bucket when parked? #8
I do what the others do and leave the bucket curled in resting on a 4x4 to keep it off the ground. The one thing I was told is after turning the engine off was to push the control through all the positions to release any pressure in the lines. You'll hear a little pressure release and the bucket will only move a tiny amount.
2015 GENIE S-65 TELESCOPIC BOOM LIFT (A52709)
2015 GENIE S-65...
FIMCO 60 GALLON SKID MOUNT SPRAYER (A52708)
FIMCO 60 GALLON...
SULLIVAN PATEK AIR COMPRESSOR (A55745)
SULLIVAN PATEK AIR...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A56436)
PENDING SELLER...
72" General Purpose Skid Steer Bucket (A59076)
72" General...
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2011 INTERNATIONAL...
