ta 250 new owner
/ ta 250 new owner #1
63spyder
Member
oregon
iseki ta250,case vao,case 420b backhoe,agricat tracklayer w/front loader
hi i just got a ta250/landleader255 with cab.im looking for a service manual for this tractor. i dont know what year this tractor is but i would like to know how to check injector pump oil level.i found a plug on top of this pump that is marked oil .i also found a plug on the tack drive side of the pump.is this the oil level check hole? this tractor runs great my plan is to put a front loader on it next
/ ta 250 new owner #2
I Just ran across this thread 63spyder . I wished I,d of seen it before . You have the only other 255 i,ve heard of allthough Mine does not have a cab . Can You share some pics .
I,m not real sure on the pump oil , I,ll have to look at mine , It the first time I,ve had the engine covers off in a long time :eek: . But I can tell You Your gonna love that tractor , Its a real workhorse . Must be nice to have a cab though :( :D . Bob
/ ta 250 new owner #3
Oil level and drain plugs are usually 10mm bolt heads with a screw driver slot. One will be the level/fill the other the drain. The same as bleeders on the fuel system.
/ ta 250 new owner
I found out that the injection pump is fed off of the engine oil .I really enjoy this tractor ,it has lots of power and turns on a dime.Im pulling a box drag behind it now,and plan on putting a front loader on this spring.Ill try and put pictures on as soon as I figure out how.
/ ta 250 new owner #5
Looking forward to seeing the pics 63spyder . I,m still fighting trying to find the correct filters , But I,m getting it narrowed down :eek: .
I,m also trying to figure out about the injector pump & if its supplyed by Engine oil or not . Can you tell by looking at a few pics ? :confused: I,ll attach a few here .
As far as how to post them , In a new thread Or if You hit the reply button you can scroll down to the Manage attachments button , Click on that & it will open up a new window where You can browse the photos & Upload them from wherever You keep them stored on your puter , You might need to resize them so there not to big for the forum , I just have My camera set to make them forum friendlly . Hope that helps . Bob
/ ta 250 new owner
HI ,on mine the injecter pump has an oil line that runs from the oil filter area to behind the injecter pump you have to use a mirror to see its conection to the pump.I shure hope thats what it is because i tryed to put oil in mine and could not find a drain plug and what oil i put in it went right on through.Still runs good though.:)
The filter numbers are
air-6497 ( around 60 dollars )
oil-1348
hydraulic-1664 this is a 25 micron filter,I read on here that 10 micron was too fine and would restrict the intake to the pump(around 30 dollars)
On my tractor the fuel filter is cleanable and I did not find another filter for fuel on the tractor.I thought about installing a screw on style someday.
If yours has four wheel drive as mine does then to change the front axle fluid I found that if you pull the top plugs in the steering knukles when putting fluid back in it allows air to escape and makes it easier ,also when putting oil back in the engine put a funnel in the dipstick hole on the side of the engine and put oil in there ,its almost impossable to pour oil in the vent on top of the valve cover due to baffling in there I still havent got the picture thing worked out guess I'll have to ask the kid
/ ta 250 new owner #7
Thanks for the info 63spyder , I,ll check the oil line you mentioned . As far as the filters I,m having a hard time finding those #,s . I,m not saying there not the right ones .
But according to the info I,ve found the air filter is a Napa 6496 & The Measurements & looks , seem to be just like mine . Seems its only 1 # off . But according to this link its almost half the price . NAPA Farming Air Filters - Global Fleet Filtration
I,m not really concerned about price with any of them , I just want to make sure there the right ones . Same way with the Oil filter , Compared to the ones I,ve been told is suposed to fit , They are larger then the one I have on now . Pics would be a great help & if it would be easier for you to post them through Email I can send you a pm with my Email addy . I,m just curious to see the same model with a cab on it . :D . Thanks again , Bob
/ ta 250 new owner
Let me know if that air filter works for you.Im all for saving a little money.Go ahead and pm me an address and I'll try to send pictures.What attatchments are you using on your tractor.Have you figured out the little black box with all the knobs and switches? I have a neihbor that is japanese and she said she would translate for me.Now I just have to get it down there for translation.
/ ta 250 new owner #9
PM sent :D . If your talking about the black box on top of the right fender its to control the 3 point system . Mine has a cylinder on the lift arm that it controled by the toggle switch in the middle that allows it to tilt . The 2 knobs are settings on how fast it goes up I beleive . I also have a box under the seat but I still have no clue what thats for .
I have a Koyker 155 front loader on the front . I use a 6 foot finish mower , 5 foot box blade & had a post hole digger but sold it recentlly . Thanks again . Bob
/ ta 250 new owner #10
Hi Cowboy.....I'm gonna' try uploadin' a pic of THE BEAST as it looks now after a not so complete Repaint "Ugg" JD green from the old flat white it came with.........Ampa....:thumbsup:
/ ta 250 new owner #11
What do you know! I done did it.....thanks Cowboy for the info....sorry to hear about your trans problems....did you find the needed parts yet? those gears look in bad shape.....take care.....Ampa :thumbsup:
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
2011 TRAIL KING TK70MG-523- 52' LOWBOY TRAILER (A65054)
2011 TRAIL KING...
CAT 980C GP Bucket (A68134)
CAT 980C GP Bucket...
2022 WESTERNSTAR DAYCAB 4700 CONCRETE MIXER TRUCK (A67714)
2022 WESTERNSTAR...
2012 Ford Taurus Sedan (A66738)
2012 Ford Taurus...
POULAN 44" VINTAGE 2 MAN CHAINSAW (A64276)
POULAN 44" VINTAGE...
