homemade dual axel trailer
   / homemade dual axel trailer #31
This was one I built from scrounged materials about twenty years ago with the exception of cylinder and hoses. It's four by six and dumps to about 50 degrees. It is way over built as far as the frame goes (2" X 6" channel). I've had as much as two ton on it. One thing I will say is that the best thing I ever did was put tubes in the tires so they rarely ever go down on air, I think I've only put air in them 5 or 6 times in 15 years. I've also been throwing around the idea of a dually for the purpose of making it road worthy for local trips.
Steve
Why is it not road worthy as is? How would a dually make it road worthy?
   / homemade dual axel trailer #32
No suspension, no lights, no brakes, need I go on. My intention was to build a new road worthy trailer, not rebuild this one.
Steve
   / homemade dual axel trailer #34
Here's a variant on the same idea. I used lawn tractor front axles that have the frame of a Home Depot garden cart sitting on top. I then fabbed up linkages to make it 4WS.........
It's still a work in progress.......
Very nice! I see you added shocks too.
   / homemade dual axel trailer #36
I'm not really pleased with the shocks I ended up using. This project had a very tight budget so I ended up using gas scooter shocks and in this case, they really aren't compliant (read - have the travel I needed or wanted and are way too stiff). But they were cheap and they do stabilize it. I'll probably end up using snowmobile shocks (oil filled) in the rear.
Despite those limitations, It has been able to crawl over small logs with a load, so that I'm pleased with.
My needs required a trailer/cart to be light & small yet be able to negotiate some rough terrain. So far so good. I pull this with my old Wheel Horse and it seems to be a good combination........
Mini Excavator 9 Piece Attachments (New/Unused) (A59225)
Mini Excavator 9...
2017 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2017 Ford F-550...
2013 Peterbilt 367 QMC 7060S 35 Ton Tri Axle All-Terrain Crane Truck (A55973)
2013 Peterbilt 367...
2003 FORD F150 HARLEY DAVIDSON TRUCK (A58018)
2003 FORD F150...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2008 INTERNATIONAL...
2014 Sakai SV540T Pad Roller, Chassis# 3SV53-10137, PMC Power Motive, Cummins Turbo Diesel Engine, (A59076)
2014 Sakai SV540T...
