Tips on keeping top link from backing off
/ Tips on keeping top link from backing off #21
I've looped a tension cord around the arm on the top link and hooked the ends of the tension cord back to the tractor. This worked the one time I tried it.
The lock nut works, too, but is a nuisance to unlock.
Ralph
/ Tips on keeping top link from backing off #23
Weld a stud on the jam nut and tap with a hammer.
/ Tips on keeping top link from backing off #24
I've never heard of such a thing...in more than 30 yrs. of seat time I truly have never had a problem with the top link on a ford jubilee, JD - 3020 or NH TC-29..I must be blessed. What are you folks doing to cause the locking nut to move ? Mine never do
Greese on the top link???
/ Tips on keeping top link from backing off #25
Ralph
I have the problem with my bush hog. I use a bungie cord. Come up from under the top link and loop over the T handles then crossing back down to lift arms. Works everytime. It does move a little but using a shorter cord would fix that.
/ Tips on keeping top link from backing off #26
My locknut holds tight, but the little teardrop lock on a JD 750 definitely will work loose. My BIL nearly dropped his shredder because the 3rd link screwed almost completely out. The tail wheel was almost dragging the ground when I noticed it and flagged him down.
/ Tips on keeping top link from backing off #27
Check out the top links at TSC. They have a few where a foldable "handle" folds out to help you turn the toplink, once length is set where you want it you fold the handle back down and it folds over a retainer piece of some sort that keeps everything from rotating. Bad explanation but looks like a nice solution, you'll understand it if you see a pic. No locknut required.
/ Tips on keeping top link from backing off #28
cant say ive ever had mine move on me.
I grease mine and while i cant just spin it with 2 fingers, its certainly not HARD to turn either.
/ Tips on keeping top link from backing off #29
I'm thinking that a hydraulic top link would be a really nice solution to this problem. ;)
/ Tips on keeping top link from backing off #30
What timely post.. Just yesterday I hooked up the LX4 and noticed that the top link ends were not extended the same length and I swore that they were previously.. I thought maybe I hadnt actually adjusted them to the same length previously - but now I bet i did and it worked loose..
brian
/ Tips on keeping top link from backing off #31
not if it was attached with equal ends ...they stay equal when attached, whether they back out or in
/ Tips on keeping top link from backing off #32
That is my thought too. I use my old toplink to capture dust in the back corner of the garage. Made my own TnT, and never looked back... :D
/ Tips on keeping top link from backing off #33
/ Tips on keeping top link from backing off #35
brian
This happens when you do not have the link hooked to an implement. One end can move by itself.
/ Tips on keeping top link from backing off #36
So you use another nut on the same side.:D
no need.. the threaded sleave of the toplink -IS- the other nut.. just jamb the first nut to the sleave and tighten.. no need for a 'third' one.
soundguy
/ Tips on keeping top link from backing off #37
Have you tried it?:D
There may be a good reason for the second Nut!:D:D
/ Tips on keeping top link from backing off #38
Yes.. I have used toplinks in projects using them as turnbuckles to adjust slack and my 10' mower uses them to adjust rear wheel height. single lock nut torqued to the sleave lockes em tight. adding another nut just means you need more tools and time..
soundguy
/ Tips on keeping top link from backing off #39
You mean there is something out there other than a hydraulic top link? That's ridiculous, I thought tractors had hydraulic pumps for this sort of thing and now I'm hearing some folks use some kind of a threaded rod contraption. Why not just replace the engine with pedals while your at it. :D....
/ Tips on keeping top link from backing off #40
My suggestion was for two nuts on the same side -- it will not come loose -- it cannot -- yes you need two wrenches in the tool box but I usually have that anyway:eek: -- JMHO
2018 Volvo VNL Truck, VIN # 4V4NC9EH6JN894692 (A61573)
2018 Volvo VNL...
2005 LEDWELL LW40ADC - 40' ALUMINUM FEED TRAILER (A63290)
2005 LEDWELL...
2007 FRAC TANK 500BBL WHEELED (A63569)
2007 FRAC TANK...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A61307)
2-Row Peanut...
Komatsu PC138USLC Excavator (A64047)
Komatsu PC138USLC...
2019 CATERPILLAR 299D2 XHP SKID STEER (A64279)
2019 CATERPILLAR...
