Tractor Shed Expansion
/ Tractor Shed Expansion #11
I Like the look of it, I had the same Question re anchoring to the ground. Up here in near north ontario, It wouldnt take long for that to shift or get blown over (despite its weight).
Any concerns with Snow Load on that roof ?, not sure if i see any Trusses in there. Would the added surface area of the new roof give you any concern for collapse ?
Again, in Ajax, you're snow load wil be less than mine (typically), but Id worry about the "big one" especially that heavy wet stuff.
Hi,
The first part I have had up for about 10 years with no shifting problems. I may have mentioned that it is well sheltered by a hillside (One pic may show it). Adding the other 2 bays, I didn't see a shifting problem. If it was in a totally open area I may have anhored more securely. No there are no trusses, 2"x6"'s in this case extend to the back. I could have used 2"x8" or bigger to beef it up but it has not had any issues. As far as the snow goes, it is located closer to Bancroft where like many areas has recieved a lot of snow lately. On the original, with the metal roof, the snow never really accumulated and then on a warmer or sunny days would slide offf the back. I am not worried about collapse as the main post and beams are all solid cedar posts ( almost like 12"x12" beams). I hope I don't have to report back on the big collapse down the road!
Dave
/ Tractor Shed Expansion #15
We don't have no county or township.
building inspectors here.
Nice to know there are still some areas of freedom in the country.
I wish we still had freedom here as well. We can't even drive under the influence here anymore without being pulled over and arrested. :mad:
KENWORTH T/A DAY CAB ROAD TRACTOR (A57192)
KENWORTH T/A DAY...
Kubota MX5400 land mgmt package
Kubota MX5400 land...
Bogballe L20W Plus (A53317)
Bogballe L20W Plus...
1449 (A57192)
1449 (A57192)
iDrive TDS-2010H...
2019 Kubota SVL75-2 (A60462)
2019 Kubota...
