Backhoe Which backhoe do you recommend?
/ Which backhoe do you recommend? #1
eebuckeye4life
Heath Ohio
Case IH JX90U
Hi everyone. I have a Case IH JX90U and I'm in the market for a backhoe for it. Was wondering what everyone's thoughts were. I have heard the cons of 3pt attachments, are their any positives? Also, I'm unsure as to the model I should purchase. I left a message with Kelley Ind. but they never returned my call. So far I've looked at a used Kelley B70 and I was going to look at a Long 1200. Anyone have any opinions about either one or know what a fair price for them would be?
Thanks
Todd
/ Which backhoe do you recommend? #2
If you do a search you will see lots of past discussion on this topic. I am planning on getting a woods frame mount BH for my tractor (someday).
Go Buckeyes!!
/ Which backhoe do you recommend? #3
With a tractor that size you can run straight off the 3pt with no problems. I like the Woods backhoe with a hydrauic thumb myself. Are you going to be using it alot or just for the odd job here and there?
/ Which backhoe do you recommend? #4
Go Buckeyes!!
Likewise. The Woods subframe mount is a very nice back hoe.
/ Which backhoe do you recommend? #5
Thanks
Todd
Just a couple thoughts. What does a backhoe attachment of that size cost? Have you considered a used full size hoe instead? They are selling for peanuts right now.
/ Which backhoe do you recommend? #6
Having had both I will share this with you. Backhoes with a sub frame work and handle much, much better. They are firm and stable. BUT a pain to remove so if you need to use the 3pt for other implements best go with a 3pt mount. Still a pain attaching and removing and they are not stable - lots of twisting and rocking while you work. I sold my last frame mount with my ford 3600 and now have a Kelley 3pt mount with my 3430. Works out better for me since I have to rotate implements so often. I have two tractors and that helps over just one but still have to swap out a lot. I have been around the Woods, Long and Kelley backhoes a lot and really have no preference of one over the other as far as brand and lots of models look interchangeable. Kelley/LandPride is slow to deal with for parts compared to the others but they come through in the end.
/ Which backhoe do you recommend? #7
Cedarranch, Sorry, but I don't understand what you are trying to say about subframe vs 3-pt hitch. I have a Woods BH90-X backhoe with thumb and subframe mounting on my NH 45DA tractor. Putting the backhoe on and taking it off is very straight forward, if never much fun; there is a qucik attach type engagement of hoe and subframe. I do remove the stabilizer arms when the hoe is on, but that is a quick switch. Once the hoe is off, there is no interference of the subframe and 3-point hitch aattachments. Perhaps I am misunderstanding something, if so I apologize, but at least with the Woods hoe and subframe changing things isn't much more effort than hooking up a 3 point attachment.
/ Which backhoe do you recommend? #8
Then you must have a much better setup than I have ever worked with. Of course working on level ground would help. All the ones I have worked with FRAME or 3PT have been a pain to attach/remove. Wrestling with lining things up and all. They were never any type of quick attach. Bolts, plates and brackets to install/remove each time.
I merely stated my opinion from my years of experience that the frame mounts make them much more stable but on all 3 of the frame mounts units I have worked with it took me about 30 minutes to attach and about 20 to remove. I have worked with two sizes of Kelley 3pt mounts and although still aggravating to attach only takes me about 5 minutes. But they are not as stable as the frame mount. The wiggle around and twist too much.
Sorry if I offended anyone with my opinion. I will shut up now!
2013 KUBOTA RTV500 UTV (A62130)
2013 KUBOTA RTV500...
Bobcat 435 FastTrack (A60462)
Bobcat 435...
2005 John Deere 7320 (A60462)
2005 John Deere...
2023 Bobcat T770 (A60462)
2023 Bobcat T770...
TSURUM HSZ3-755 PUMP-1 PHASE INDUCTION PUMP (A62131)
TSURUM HSZ3-755...
2019 Kuhn GMD3151TL Disk Mower (A63116)
2019 Kuhn...
