SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 12,557
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
A tubeless tire that gets soft can debead and flatten in an instant - - sideslopeFWJ says he has no problem pulling the 2715's using a tractor weighing 8200 lbs. Your 8540 should already weigh at least 8200 lbs (5400lbs base weight for 4wd rops, 7 front weights and front bumper 700+ lbs, loader 1800 lbs, wheel weights ???).
Do you have cast rear wheels, add on rear wheel weights or both? You said you have radials, which size?
Since you said you have steep hills I think you should load the rear tires, use the front weight bumper and front weights, and remove the loader. If you find you want or need more weight you could put the loader on or add rear wheel weights.
larry
