Hydraulic motor specs
/ Hydraulic motor specs #1
Truckerdad
Hello all..any know what the minimum reguirements/specs would be for a hydraulic motor that would be capable of powering a 38"(2 blade) or 48" (3 blade) mowing deck? Thanks
/ Hydraulic motor specs #2
I believe the hyd motors on the Power-Tracs 48 in deck, are 3 cu in. If true, at 8 GPM's, the rpm will be 616, and the torque at 3000 psi will be 1433 in lbs.
I am not sure of the pulley ratio, but if known, you could work out blade tip speed.
OK thanks a bunch...it's a good place to start. Any and all info from any and everyone is appreciated!
72in. Land Plane (A65640)
72in. Land Plane...
Bomag Roller (A63689)
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A64194)
2018 Freightliner...
2022 FORD F-450XL FLATBED TRUCK (A64277)
2022 FORD F-450XL...
2005 International 9200 Semi Truck (A66285)
2005 International...
2022 CATERPILLAR 272D3 SKID STEER (A65053)
2022 CATERPILLAR...
