Help - lost my truck key
/ Help - lost my truck key #1
Alan L.
Elite Member
Grayson County, TX
Kubota B2710
I have a 1994 Ford F250 pickup and I have managed to lose the ignition key. Should I be able to get a key made if I show my title and identification to a Ford dealer?
/ Help - lost my truck key #2
Any dealer should be able to cut you a key with your VIN and proof of ownership. :)
/ Help - lost my truck key #3
One of the guys that work for me lost the key to his 95 Ford Ranger. It was a security chip key (did,nt think the line to steal Ford Rangers was that long).
We had to load the truck on a trailer and take it to Blake Utter Ford in Denison Tx. $100 later he drove it home. If you know the original selling dealer I think can look up the key code and make one, but with these "chip keys" maybe not.
Jack
/ Help - lost my truck key #4
Yes, but I don't know what it'll cost; probably a lot.
I am pretty sure its not a chip key although I could be wrong. It had a very small rubber handle and seems like any cheap blank you could have made. Should have done it while I had the key.
/ Help - lost my truck key #6
I have a 1995 Ford F250. It is not a chip key. When you get the truck new, they always come with a little tag with the key number. You are supposed to save the tag so you can order a new key cheaply by the number.
All my tags are in a special drawer. If I lose a key my only problem will be that I didn't mark which tag goes with which truck.:eek:
/ Help - lost my truck key #7
If your dealer won't make you a key, a good locksmith will come to you and make one.... though it won't be as cheap as the dealer cutting one. :(
/ Help - lost my truck key #8
Repo guys get them that way. Did it in the late 90's. Fun job.....
I don't have a key code. Got one key when I bought the truck a couple of years ago, and no code. Hope I can get it done.
/ Help - lost my truck key #10
Alan, all you need is the Vin #. If you have your title and ID you should be OK.
/ Help - lost my truck key #12
Sorry, but Ford will not have codes by VIN for any vehicles older than ten years...
A Licensed Locksmith is the best way to replace the key.
/ Help - lost my truck key #13
quote]
My 2004 Mazda b3000 has the security chip key, and I was thinking the same thing.
/ Help - lost my truck key #15
Even if the dealer had the key code it might not be the original lock in a 94. I've worn out and had to replace the ignition lock twice on my 96 Ford pickup.
The first time I carefully moved all the little tumblers or whatever they are called, over to the new lock to keep the same key. By the time that one wore out I had to use the new lock...PITA having a different door key from the ignition key.
But- :D I had a key copy made with the doors on one side and the new ig lock on the other...yes I have to insert the key the right way to get in or start the truck but it beats carrying two keys for one truck. Luckily Ford has the locks flipped...I know my franken-key looks much different on each side so I know the one side is always up whether in the door or the ig lock:)
The reason it looks different is Ford uses the first few teeth for the ig lock and the last few for the door lock. My franken-key only has the first few teeth on one side, and I know that side is always up.
Side note- I first figured out the key thing way back when we had a 98 Windstar as well as the 96 F350...had a key made that would work in both vehicles, depending on which way you inserted it. Even weirder I went to have a copy made of the franken-key at a well known respected locksmith in town once. He insisted what I was doing would not work and refused to copy the key, even after I told him I been using it for years. What a jerk he was, so I went to big box store and had it copied by a non-expert:p
/ Help - lost my truck key #16
Wherever you go to get the key, on the way home your wife will call to say she has found your old key. . . Murphy at work.:rolleyes:
/ Help - lost my truck key #17
we got a new plastic/metal engraver machine at work, I now have all new little plastic tags with my phone number on all my keys... I've also lost some sets in the past, never did find them but didnt have any way for people to reach ME onto the keys... NOW if someone finds them they can at least call me...
Mark
/ Help - lost my truck key #18
Or look up your address from your phone number and come steal whatever the key fits:eek:
I'm pretty sure if someone finds my key it will be in the process of rummaging through our drawers. It has to be here somewhere......
I called the nearest Ford dealer and they first said they could make a key from the VIN number on trucks older than 2000. But then took my VIN number anyway and called back and verified that they could not do it. Suggested I call a locksmith.
I wonder how big a deal it will be for the locksmith to make a key?
/ Help - lost my truck key #20
A good locksmith will come to you and make a key mostly by 'feel'. They insert the key, jiggle it, then grind where the tumblers make marks on the key. I haven't had it done in years, but I'm gonna guess it'll cost $100+ dollars during their regular business hours.
