Towing in overdrive
/ Towing in overdrive #61
Even though I am a Ford HD guy you did good buy buying a larger truck. The big gas engine will suit you fine for your occasional towing.
I can tell you still have a love for GM. You said "HD" instead of "SD".
When should you change the tranny fluid? Now. If it got over 200 deg you need to change it. The rule of thumb is 200 deg max on the tranny temp.
Chris
If I had to change the fluid everytime I hit 200*, I'd be broke. :D
200* is nothing.
/ Towing in overdrive #62
200* is nothing.
No love for GM and maybe you just need to buy a better truck!:D You will be broke sooner or later with all them Government Motors things you own.
Back to the OP. If it says 260 then that what it is. 200 is just what I have always heard as a rule of thumb.
Chris
/ Towing in overdrive #63
Chris
No, no, no, no, no. Tell everybody to buy GM. I lost enough money from that freakin' bankrupt company that they owe me a free truck. For buying their products and buying their stock over the years they have most definitely cost me more than any possible breakdowns from any number of vehicles could have cost me. I need more people with blinders on like "Builder" out there banging the 'buy GM' drum!! Hopefully there will be enough people buy from the bankrupt Government Motors to drive up their stock from "junk" status to at least "poor" status.
/ Towing in overdrive #64
Maybe you're the one with "blinders" on???? :rolleyes:
Builder said:
It is going to be REAL interesting to see what shakes out in the next 2 years. I won't be a guinea pig for Ford's new taco diesel, so they're out till at least '11-'12. GM is being rather hushed about the future, although what I have seen looks promising. If Dodge gets the 6.7L settled down, with the Aisin & exhaust brake, that very well might be my next truck.
If the Ford turns out to be a winner, they get an exhaust brake and the others don't match up to Ford, I guess I'll be driving a (removed) again. No problem with that.
Just buy the best truck you can when you're buying. :)
http://www.tractorbynet.com/forums/1759484-post33.html
/ Towing in overdrive #65
Buy the best at the time you purchase the truck as builder has put it. In 2002 when I ordered a new truck I ordered a truck with solid axles dana 60 upfront and dana 80 in the back with a 5spd manual and 5.9L with knowledge the clutch was junk and would replace it in 6months with a aftermarket(which I did). It happened to have a dodge body on the set-up. Would I buy a dodge/ford/chevy today if I ordered one???? I truely like the the 7.3IH but currently the best truck depends on what you want it to do.
If I needed a new crewcab heavy hauler I would by a sport Chassis Freightliner.
/ Towing in overdrive #66
Yeah, riiiiight. About as likely as having monkeys flying outta my rear! :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: !
/ Towing in overdrive #67
Thanks, bud. That's exactly right and all we need to know. :)
/ Towing in overdrive #68
Hey, I know it's being lazy and not looking it up myself, but what is the last year GM diesel pickups were made without DPF stuff? Business is picking up in areas I didn't expect and dropping in others. As you know, I'm pleased with my '06 PSD but most likely need to add another truck and trailer. I had the Dodge for 10 years and now have the Ford. I figure I ought to drive the latest offering from GM and maybe go that way this time if they drive okay.
/ Towing in overdrive #69
I agree with Builder on the fan issue. I'm thinking the truck was sensing the need for extra cooling and the fan kicked in. I'm not familiar with the GM 8.1/Allison set up but my 7.3 PSD/6 speed set up has a very noticeable fan when the temps get right.
Jay
We've had a motorhome with the 454 and this pickup with the 8.1L/Ally and when they kick in the fan, you know it. Roar of a prop plane comes close to describing it. Only when the engine is cold or on the I-77 grade does it make itself known. And even if you know it will do it, you still look down at the speedometer and the tach just to make sure.
/ Towing in overdrive #70
I just returned from an atv riding trip in Logan WV {Hatfield McCoy trails}. I rode with a friend who has basicaly the same truck as me, other than the fact that his truck has the 8100 gas engine with an Allison and 4:10s, 2wd, mine is a DMax Allison, 3:73, 4WD. Both trucks have 265's, are reg. cab long beds, and relatively close miles, mine 97k, his high 80's, his is a 2002 2500HD, mine is a 2003 2500HD.
We were towing a 22ft tailgator camper/toy hauler with 2 4wd utility quads inside, and gear and food for four adults, the water and waste tanks were empty, we estimate the weight of the camper to be around 6500lbs as towed. We were also using a cab top air deflector. The best hand calculated MPG we got was 7.1mpg, the rest of the time we were between 6.4mpg and 6.8mpg. It was 392 miles each way, and it took almost 3 tanks of fuel to get there and about 2 and a half to get home[ had a little left]. The Rig also spent lots of time in second gear at 4000+ rpm's climbing the hills on the freeway, it did however maintain 65mph the entire time, regardless of the terrain.
It would have been cheaper to drive my Duramax down there by myself {towing the same load], rather than splitting fuel with my 8100 buddy. I also doubt that it would have come out of overdrive on any highway grade that we encountered, [it is chipped though] based on past mountain towing experience in it. I sure am glad I spent the extra money 6 years ago for a diesel. The 8100 did the job, but I prefer the diesel.
I always tow in overdrive, and use Tow/Haul when towing and NEVER exceed 60hp setting on the chip when towing. Rarely have I seen trans temps in excess of 200 degrees, only a couple times when towing in heavy stop and go highway traffic. My buddy with the 8100 towed all the way down and all the way back in tow haul overdrive with no issues. That being said, If I did not have a Allison, Torqueshift, or Aisen, I would play it safe and keep it out of overdrive when towing, as none of the older auto OD's [E4od, 4l80 etc.] were realy made to be towing in OD.
Something sounds wrong with his truck. With loads in the 15K to 17K CGW range mine stays in 4th or 5th 99.9% of the time. 3rd is where 4K on the tach is seen and rarely goes there unless it is grade braking at 65. Was his one of the early 2002s that was recalled for the flexplate failures and did it get a tranny spring change? He might try backing off on the throttle and letting it run at 3200 RPM upgrade and let the engine run where its torque is better. It might then stay in 4th which should help with the MPGs. Were you on 52 or 119?
/ Towing in overdrive #71
This has been an interesting and informative thread. I just got into camping (at my wife's insistence) this year and bought a 28' travel trailer (32' bumber to tongue). How little did I know about towing, pulled it home with my 2001 Silverado 5.3L truck, found out right away that the TT was too much weight.
Went shopping for a good used 3/4 ton used truck, found out diesels with low mileage and reasonable priced are two different things; they all had either high miles/lower price or low miles/higher price. So ran across a 2002 Sierra 2500HD with the 8.1L gas and Allison tranny and only 37,000 miles, at $12k.
Truck pulls camper great but I can't figure out which gear/mode that I should cruise in. I made a trip to the mountains in VA and was in tow/haul mode until I got to a very steep and long grade (going up). Truck downshifted and even tho turning 4500 rpm's, it would not do over 45 mph. That plus a horrendous loud roaring noises. I pulled over, took off town/haul, and proceeded on. I found out that in the "D" selection and without tow/haul, I could pretty much maintain 2000 rpm's and 60 mph except on very steep hills. There I just built up speed going down and usually pushed up to 3000 rpm's near the top of the hills. Seemed like much less strain on the engine and tranny that way.
Now I am totally confused on how I should tow on flatter land. Tried towing in tow/haul and "D" on a recent coastal trip. The truck did ok cruising but on minor grades, it would shift down and run up the rpm's while taking what I thought was too long to come out of it. Then, in town, as I approached my stops, the trans would downshift heavily and really sounded like it was in a strain.
Back on the road, cruising without the tow/haul, I did not have these problems. So, my question is, is this normal operations for the Allison? Is this downshifting of the tranny and up powering of the engine to the 4000+ range ok? What about the "rough shifting" at times?
Even tho this is an '02 model, the previous owner did not service the Allison since he was nowhere near the 50,000 mile mark. I thought I might go ahead and get it service although the fluid looks and smells normal.
One other thing, on the trip in the mountains, I was running around 190-200 degrees on the trans. On the coastal trip recently, I ran as high as 211 degrees (it was 100 degrees day tho).
Since I am a novice at this towing thing, any help or advice will be greatly appreciated.
Check the service history on the tranny. Rough shifting was a sign of the flexplate failure on my 2001 8.1. It just got a fluid/filter change on the tranny as the repairs were 50K ago.
/ Towing in overdrive #72
You ever get that vomit taste in your mouth? It just happened to me. Why not just get another F-350 6.0 Ford and be done with it. Then you will have 2 real trucks.
Now to answer your question it was the 2007 model year. The change over came half way through the year. The first half with no DPF was in the Classic Body Style like Builder has. The new body style with the snow plow front bumper and later have the DPF.
Ok, off to brush my teeth with bleach!
Chris
/ Towing in overdrive #73
I needed some time to think about this because I had to go back and research how you view GM.
After reading several of your previous comments, because of your extreme negative bias towards GM, buy another Ford since you like them so much. Judging by your own typewritten previous comments about how much you hate GM, you would probably be throwing fits as soon as the first minor thing went wrong.
Here's an example:
dargo said:
]No, no, no, no, no. Tell everybody to buy GM. I lost enough money from that freakin' bankrupt company that they owe me a free truck. For buying their products and buying their stock over the years they have most definitely cost me more than any possible breakdowns from any number of vehicles could have cost me. I need more people with blinders on like "Builder" out there banging the 'buy GM' drum!! Hopefully there will be enough people buy from the bankrupt Government Motors to drive up their stock from "junk" status to at least "poor" status.
Quite to my surprise (and everyone elses that have PM'd me) is that the very next post the next day, you actually say you want to buy another new truck & trailer, but the real shocker is that you're talking about buying a GM now: :confused::confused::confused:
HUH? :eek::confused:
I guess it's your inconsistent, indecisive, 180 degree turnaround style posts that are the most entertaining aspect of all this.
I like to buy the best truck available at the time I purchase. If everyone did that, they'd get the best truck for their hard earned money and not have to worry about what anyone thinks!
/ Towing in overdrive #74
How does one go about checking the service history on his truck's tranny? Is this something I can do on the internet or would I have to take it in to a dealer? tks
/ Towing in overdrive #75
Chris
Thanks Chris. I see that he can dish it out but clearly can't take it in return. LOL!
/ Towing in overdrive #76
You can do either one. If it were my truck, I would take it to an Allison authorized service center and have a tech check it out. You'll just waste a lot of time on the computer. Sure, you'll find TSB's on them, but what good will it do you until you have it checked out.
Look for a GM dealer with an Allison tech and they'll tell you what's going on. Good luck and let us know what you find out!
/ Towing in overdrive #77
Is it just me or are people scared to use the truck as it was made to be used??? 4,000 rpm is not near red line. When hauling big loads up grades you will need to keep the truck in the power band which with most gas burners is over 4,500 rpms.
I would say most of my trucks get near red line on a regular on ramp. Thats how they are built if you treat it like a little old grandma and pamper it and dogging the engine I feel that does more harm than good. I feel everything should be ran wide open, it keeps the coolent flowing and the fan pulling more air and in the lower gear it is easier for the truck engine and tranny(IE more leverage). I say run it like you rented it.:D
/ Towing in overdrive #78
I agree with you to for the most part, as I drive all of my vehicles on the agressive side. That being said, I would not want to spin that 496 cube engine with its 4.250 stroke at 4500 rpms for 3 miles up a mountain when it gets some miles on it, say 140 or 150k. It would not bother me a bit with a 40k mi truck though, other than having to listen to it scream for an extended period of time.
/ Towing in overdrive #79
No need to beat up on an engine when the peak torque is at 3200 RPM. Or 65 MPH in 4th gear unlocked. If the load doesn't require it, the Ally will drop down to 2800 locked and RUN up the hill at 65 MPH. But I do go thru the gears at the points where it goes from peak HP to peak Torque at each shift. The HP point is 4500 RPM, Torque is 3200. Factory redline on the 8.1L/496 is 5000 RPM.
Longest life on an engine comes when they are run at about 3/4 load-3/4factory redline.
2001 CHAPPARAL B/STOCK TRAILER (A62130)
2001 CHAPPARAL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2017 Chevrolet Equinox SUV (A61569)
2017 Chevrolet...
207274 (A52708)
207274 (A52708)
2017 Bad Boy Outlaw XP 61in. Zero Turn Commercial Mower (A61567)
2017 Bad Boy...
2017 Ford Escape SUV (A61569)
2017 Ford Escape...
