BX2200 Starting Problem
   / BX2200 Starting Problem #1
justsailin
Purcellville, VA
Kubota BX2200
Hi Everyone,
I am having a problem with my BX2200 starting. My tractor does start but only when I turn the ignition switch the whole way to the on position. When it is fully turned to on nothing happens but when I release the pressure a little bit I hear a click and the engine tries to turn over and DOES start. It does not crank like it should when I turn the starter switch fully to on position. Last week, this method did not work (it had been raining the previous day) however the following day the above method worked.
I guess my question is the following:
1. Do you think this is the starter switch ?
2. Or Is this the actual starter mechanism ?
3. Or Is this way over my head ....
I am not electrically inclined but I could replace a starter switch I think.
Any suggestion appreciated !!!!!
Thanks Alot,
Tom
   / BX2200 Starting Problem #2
Based on what you've posted, that would be my guess.
If the switch is acting differently in weather, might just be dirty or corroded. Spraying contact cleaner through it first shouldn't hurt anything. Maybe worth a try.
Thanks for the response, I will try that today and let you know the result.
Tom
   / BX2200 Starting Problem #4
the switch is about $55 and it is plug and play- very easy to replace.
Mine started having issues where it would run the glow plugs but not the fuel pump.
Replacement took 5 minutes.
   / BX2200 Starting Problem #5
You mentioned rain. Was the tractor outside in the rain? It can take water quite awhile to dry completely if it gets down inside an electrical switch. Just a little corrosion can also cause circuits not to open and close cleanly.
Was the tractor covered during the rain? If there already is dried corrosion in a switch, high humidity can cause the oxidized compounds to absorb some water vapor, expand a little and partially block or short a circuit.
I removed the cover screen under the dash to look at the starter switch but I could not figure out how to get to the starter switch. I think I need to be able to remove it so I can see if it is corroded. What is the best way to get to and remove the starter switch. Do I get at it from underneath the dash or do I take the dash apart (and how do I do that).
I saw on another post that the starter solenoid could be the problem too. Any ideas on that ?
Last time it rained heavy but mower sits under tree but it was very humid too.
Thanks,
Tom
   / BX2200 Starting Problem #7
If you find the starter switch shows signs of corrosion I would replace it and not try cleaning it. If you do clean it and it works OK; being coroded it will fail again before long.
   / BX2200 Starting Problem #8
The switch is held on with a ring on the outside of the panel. You may need to take a small screwdriver and a hammer to work it loose. Just place tip of screwdriver in one of the slots and tap it with a hammer.
Thanks 4Kings I will try to remove the starter switch this weekend.
Tom
   / BX2200 Starting Problem #10
Hold the starter switch under the dash and use offset pliers to grab the round ring on the outside and unscrew it. There is also a washer-like retaining ring that holds it in place. You will need to work that off.
   / BX2200 Starting Problem #11
A tree will not stop water from getting on things. It may for the first few moments, but the water is going to run to the underside of branches, needles, leaves, then drip. Some people successfully leave tractors outside. If I didn't have a garge, I'd cover mine with a waterproof cover, leaving some breathing room at the bottom. I imagine it is the switch.
All,
I finally got time to get back to my starter problem. I purchased a new starter and successfully installed it with the help of people responding to my posting. This did the trick. Now my engine cranks everytime I turn the key. I can't tell you what a relief that is. Thanks so much to everyone who chimed in. I am sure I will have other postings, now on to changing the oil project.
Thanks Again,
Tom
   / BX2200 Starting Problem #13
awesome! ;) just in time ffor winter!
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59228)
2006 iDrive...
2022 JOHN DEERE 744L WHEEL LOADER (A60429)
2022 JOHN DEERE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2008 KOBELCO SK210LC EXCAVATOR (A60429)
2008 KOBELCO...
2015 MACK CHU613 DAY CAB ROAD TRACTOR (A58375)
2015 MACK CHU613...
2023 JOHN DEERE 85G EXCAVATOR (A59823)
2023 JOHN DEERE...
