Dump trailer wooden sides
/ Dump trailer wooden sides #1
GreatWhitehunter
Eastern CT
JD 110 TLB
I've been wanting to make some wooden sides for my dump trailer. I've got the stake pockets but I'm not sure if I should but the boards on the inside of the stake pockets or the outsides. Does anyone have pics of their's that they'd care to share? I'm going to make them out of PT for sure.
Matt:cool:
/ Dump trailer wooden sides #2
I would put the vertical boards that go in the stake pockets outside the horizontal boards.
Chris
/ Dump trailer wooden sides #3
Chris
X2, this will let the dumped material slide out along a smooth surface without any verticle ridges to trap mulch, firewood, gravel, mud ,etc.
/ Dump trailer wooden sides #4
I put my 'stakes' on the inside, just because I thought it looked better. I've never had a problem dumping anything with the boards this way.
/ Dump trailer wooden sides #5
I agree with Ryan03 Diamondpilot. I put my boards on the inside so that soil clay etc.. would not get stuck. I have hauled a lot of clay{well over 100loads} and am very glad I did the boards this way. Some soils will stick to just about anything so why make it worse?
Ductape: I like your trailer and also notice your sides are metal part way up maybe that's why yours doesn't have issues with sticking material???
Thanks to ductape for the visual. Does anyone have a pic of the boards on the inside?
Matt
/ Dump trailer wooden sides #7
Put the verticals on the outside if you can. Not only will the inside of the wooden sides shed dirt easier, but when you really load the trailer up high & tight with packed material, the horizontal members won't pop off the vertical supports.
/ Dump trailer wooden sides #8
that what i was thinking when i was reading this thread.
Ok, so does anone have a pic of the horizontal boards on the inside?
Matt
/ Dump trailer wooden sides #10
Greatwhitehunter, not being smart but if you if you will pull into a parking lot with dump trucks that are used you probably will see their set up or farmer's grain trucks. I think you will only find the vertical stakes on the outside for reasons given. This way you can see it fully.
/ Dump trailer wooden sides #11
Safety first. Doesn't matter what it looks like. Vertical boards on the inside to keep them from popping off when pressure is applied from material inside the dump. If your concerned about looks, put the horizonatal boards on both sides.
2002 MITSUBISHI FG40K FORKLIFT (A66091)
2002 MITSUBISHI...
2016 CATERPILLAR 304E2 CR EXCAVATOR (A65056)
2016 CATERPILLAR...
2015 CAT 730 (A68134)
John Deere LX5 5ft. Rotary Brush Cutter Tractor Attachment (A61572)
John Deere LX5...
2015 Kubota M6-131 131HP 4WD Agricultural Tractor (A66734)
2015 Kubota M6-131...
2017 KENWORTH T880 (A67714)
2017 KENWORTH T880...
