NH930B finish mower
/ NH930B finish mower #2
I need A pully for A NH 930B finish mower. NH will only sell the entire assembly. If you have one or can help me find one please email me at denniswarner151@sbcglobal.net thank you dwarner151
Take the old pulley to your local bearing supply place. They can often match your pulley. It will be much cheaper if you can do it that way.
/ NH930B finish mower #3
Has anyone found an aftermarket pulley that works as a replacement for the original 930B drive pulleys that fit on a tapered shaft ? I understand the new spindles have eliminated the taper and as noted above, New Holland no longer sells parts for the old style. My mower was new in 1998 and I had to rebuild a spindle back in 2004 when pulleys were still available. I'm not having any luck at my local bearing service places. One could give no advice. The second is looking at machining an off the shelf pulley to fit.
LOAD OUT AND SHIPPING (A65579)
LOAD OUT AND...
2016 Deere 180G (A60462)
2016 Deere 180G...
Kubota M4700 (A60462)
UNUSED SDLANCH SDLL60 STAND ON SKID STEER (A64280)
UNUSED SDLANCH...
2014 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2014 Chevrolet...
Wacker Neuson PT2 Water Pump (A59228)
Wacker Neuson PT2...
