Home Generators
   / Home Generators #11
When my power goes out and I decide, after determining the problem, that I want to use the generator I go to the outside breaker box and cut off the main house circuit breaker. This is the 120 volt. I leave the water heater breaker on and the A/C/Heater on and the oven. This way I know when the power comes back on because the air will come back on or the light on the oven will catch my attention.
I then take the gererator outside, crank it up and plug it to a heavy duty cord with male plugs on both ends. The other end goes into a plug in my shop. This gets power to the entire house.
I don't get this part... how do you turn off your mains but still have your A/C come on when line power is restored? Does your entire house run off a sub panel with the exception of the A/C, stove etc. that you leave 'on'?
My bummer is my well if off a separate transformer at the other end of the property so I would have to have two generators :(
   / Home Generators #12
Yep, that's a drag. I have a Champion travel trailer for my camper that I use for the pole-barn/well. Then, one of those big, loud, annoying Briggs 5500 watt generators for the house.
This thread reminds me of something... I probably need to get some fuel stabilizer added pretty soon, they've been sitting all summer.
   / Home Generators
You can put disconnect boxes on anything or everything if you have enough generator. These disconnect boxes have a pigtail wired in to them. When you pull the bar on the disconnect box this isolates this circuit from the rest of the house wiring. Then the generator is plugged in to the pigtail. If the power comes back on it doesn't matter to what's on the disconnect and the pigtail to the generator. It is isolated from the house wiring. This the cheapest and safest way to go with out an expensive power management system. This is the set up I use. My 220V well pump is on a disconnect with a pigtail. When the power goes out I pull the bar on the disconnect and plug the generator in the pigtail. The pump is powered directly from the generator. I researched back feeding a house. That's a very ugly thing that I want no part of. The power management systems are the way to go but they are expensive. Honda makes an awesome power management system that I priced at $1,400 installed. We don't have that many power outages here. I've already got $2,500 invested in my generator. But we do have to have a generator here in the country. No well pump means no toilets flushed and no water for the livestock.
   / Home Generators #14
some could. but thats likely a standalone "transfer pannel"
those are the only circuts on the gen power. then when the power comes back on the rest of the lights come back on and you know to switch back over to grid for the other circuts.
but for the "back feed a 220v breaker" setups then no you generally kill the entire house to run it off the generator. and just have to rely on seeing your neighborhood lights are back on etc.
   / Home Generators #15
backfeed a 14470 pot with a generator and you will make 14470. A step down transformer works both directions. Isolate completely.
Our power company provides isolation switchs at every meter set.
   / Home Generators
This is a power management system. Best thing going. $1,400 installed here at home. So like I am going to shell out $2,500 for a generator and another $1,400 for a power management system? I think not.
   / Home Generators #17
OK, that makes more sense... I didn't pick up from your original post that you have some type of disconnects on certain circuits.
   / Home Generators #18
The electrcian who put in my wiring used a mechanical lockout in the main panel. This is a special main disconnect breaker/switch. As long as the lockout is in normal position, you can't turn on the breaker that connects generator power to the panel.
To flip generator 220v breaker on, you have to turn off the main disconnect breaker, then slide the lockout plate, which allows you to flip the generator breaker on.
This is safe and not expensive, and pretty fool proof - no fancy gizmos to breakdown. Plus you have generator power to every circuit in the panel, it is up to you to manage the current draw on the generator by deciding what to run or not. You can also turn on/off circuits using their breaker in the panel.
I have a Honda 6500W generator, bought it in 1996 and it is still giving good service. It provided the power to build our current house and garage while waiting a couple months for the power company.
   / Home Generators #19
You can always buy a 40k diesel generator in it's own sound attenuated housing, put it behind your barn, give it a feed line to your 550 gallon diesel tank, feed power to your home breaker box via 0000 copper wiring laid underground in it's own conduit and then have all auto switches installed, including a generator 'exerciser'. Or, you could always use that same money on a new Mercedes... :eek:
   / Home Generators #20
I just finished building my place a few months ago and wired my panel for this exact thing.... I actually found out about it on another post on TBN. It's called a generator interlock kit and it's UL listed. Generator InterLock Kit - Introduction
At $150 it's certainly worth the cost for me to manage the power load myself versus having a transfer switch that's sized for the generator.
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A60429)
2021 CATERPILLAR...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
Preliminary Listing / Full Catalog Coming Soon! (A53317)
Preliminary...
SCAN TO RECEIVE TEXT UPDATES (A60430)
SCAN TO RECEIVE...
Year: 2015 Make: Ram Model: 5500 Chassis Vehicle Type: Truck Mileage: Plate: Body Type: 2 Door Cab; (A55852)
Year: 2015 Make...
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
