B7800 Headlight repair/replace?
   / B7800 Headlight repair/replace? #1
bigboyga
Augusta, GA
Kubota L4600
Help! I noticed that one of my headlight bulbs was out so I opened the hood and here the bulb was still burning, it had just fallen out. So I figured it just needed to be twisted back in. Couldn't get the plastic ears/clips to catch and since it was dark I just decided to twist the other bulb out and see what the ears should look like. Bad idea! :( The plastic ears are dry rotten and broken off. Now bith bulbs are rattling around under the hood! Can I buy these as a replacement somewhere or what should I do? I know I can just glue them on but what do I do when the bulb burns out later? Is there a good led fix, but I still have the problem that my plastic ears are gone so can I just buy the new bulb socket and 12" extension that plugs in then to the underhood wiring? :confused:
   / B7800 Headlight repair/replace? #3
I would do the same as the other guy said take pigtail to dealer my 7800 is almost 6yrs old 700hrs I just changed a burnt bulb and my plastic ears are still good
CATERPILLAR 48" QUICK ATTACH FORKS (A51242)
CATERPILLAR 48"...
1049 (A50459)
1049 (A50459)
2012 FREIGHTLINER M2 TANDEM AXLE DUMP TRUCK WITH A SNOW PLOW (A51222)
2012 FREIGHTLINER...
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
2019 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A51242)
2019 CATERPILLAR...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2018 FREIGHTLINER...
