Source for Deere Quick tach mounts
/ Source for Deere Quick tach mounts #21
I've come across quite a few posts for the pins and hooks but I haven't seen what I'm looking for. Maybe I just don't know what they are called. Instead of the pins and hooks that attach to the buckets/forks or whatever else, I'm looking for the ends that attach to the loader itself which allows the for the quick-tach option. Any help locating these items would be greatly appreciated.
Are you talking about the skid-steer style (SSQA) or the JD style (JDQA) You have a Yanmar/CC correct?
/ Source for Deere Quick tach mounts #22
I'd be looking for JD style (JDQA) as I think my loader would be similar to the 200 series loaders. Maybe I'm wrong in thinking that there is a (QA) on the 200 series loaders. I was going to stop by a dealer Friday and see what they have.
Yes I have a Yanmar/CC.
I mentioned a quick-attach option to my dealer but he made the comment it would be to heavy. I've seen some aftermarket quick-attach options and from what I've seen they look to weigh around 80 pounds. So I figured if I could use the ones for the 200 series loader, I could possibly make them work on my loader. Although I'm probably wrong as the size for the 200 series loader is probably quite a bit different from my CL100 loader. If it isn't to far off, figure I might be able to fabricate something that would work for a quick-attach option. I haven't seen anything yet for the Sc2400 which someone might have made something and I just haven't found it, or is in the process but just hasn't come out yet.
/ Source for Deere Quick tach mounts #23
The loader side, or "Holder" as JDParts calls it, is available through JD for $87.00 each. #7 and #14 in the diagram below.
The part numbers are:
W50722 HOLDER (RH) ADD87.00 USD
W50723 HOLDER (LH) ADD87.00 USD
/ Source for Deere Quick tach mounts #24
I sure do appreciate the info. When I stop by the JD dealer tomorrow, I'm going to take some pictures and measure the size of the holders. That way I can get an idea of the size and see what I'm looking at to see if the holder will indeed fit on my loader. Again, I sure do appreciate the information.
/ Source for Deere Quick tach mounts #25
You are welcome...But I thought all the Yanmar/CC tractor came with a QA on the loaders? Maybe just the bigger ones?
This is one thing no other manufacturer but JD has...a simple, lightweight QA setup for ALL it's loaders!
/ Source for Deere Quick tach mounts #26
It's possible that the larger ones do. I know mine doesn't have one and like I mentioned earlier, when I asked the CCY dealer, he said it would be to heavy. So it might be that the QA is available for the larger tractors/loaders.
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
(4) Tires and Rims (A65640)
(4) Tires and Rims...
2020 CATERPILLAR 289D3 SKID STEER (A65053)
2020 CATERPILLAR...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
JOHN DEERE 5403 TRACTOR (A65643)
JOHN DEERE 5403...
2022 EZ-GO ELITE...
