GC2310 wood chipper.
/ GC2310 wood chipper. #1
66chevelle
Member
Guysborough, Nova Scotia
MF1635 TBL,
I'm considering purchasing a Jinma Model 6 Wood Chipper. Has anyone had any experiences with these? Will the 2310 have enough power to run a chipper at all? Having never tried to engage the PTO without being seated does the tractor have tis capability?
Thanks
/ GC2310 wood chipper. #2
Thanks
I'm not familiar with the Jinma chippers, but I have an old WW Grinder, Super Apache chipper (3-4" max) that works fine on my 2310. I can engage the PTO standing beside the chipper. However, I'd suggest starting with the RPMs low because it engages with a snap, then you can increase the RPMs to whatever you need. I usually run the engine at ~ 2,600 when chipping.
Jay
Jay
I'm not sure what I'm doing wrong. I can't get the PTO engaged with out some one on the seat. I have tried having both the mid and rear PTO in neutral, then engage the drive.. The kill switch gets activated no matter what combinations I try? :confused:
/ GC2310 wood chipper. #4
If your 2310 is like my 790, you tip the seat forward and raise the plunger/seat switch.
/ GC2310 wood chipper. #5
Or, you can bypass the safety switch with a jumper wire and then it also won't shut off the engine if you lift your butt out of the seat when it's in gear.
Of course, defeating such an essential safety item would also subject you to the wrath of the safety police if you ever admitted to it on this forum.
Or so I hear....
I wouldn't know anything about how easy it is to do, either.
;):D
Thank you for your replies.. I guess I'll just have to enlist my 11 year old son but.. Well that's not going to work for long..
/ GC2310 wood chipper. #7
That is why we bypassed ours, with a jumper.
Problem (for us anyway, may be good for others.) solved.
/ GC2310 wood chipper. #8
I have a clone of that chipper. Once you check all the adjustments and tightness of the fasteners, the heavy flywheel is the only problem you will have. It kills my 2310's engine when I engage the PTO no matter what RPM it's running at. The problem is, you can't sneak up on engaging the PTO, it goes from completely off to completely on. So, I rev it up and engage briefly, briefly again, and then on. I hate doing it, it has to put some banging on the parts, so once it's running, I leave it engaged until I'm done chipping.
It makes chips real good!
/ GC2310 wood chipper. #9
I have the same problem with my 1533 if someone isn't sitting on the seat it shuts down.
So, I set the seat to the lightest adjustment for wieght and put a fair sized hunk of wood on it and away it goes.
Works great, if i need to shut it down fast i can knock the wood off and I never forget to reattach the safety device.
Happy chipping!;)
Well I have decided to bite the bullet, Picking up the Jinma 6" chipper Friday.. A days assembly, and will see what happens.. :rolleyes:
I know that North American chippers are more sturdy but can justify over twice the cost, Maybe if I was in the business of cutting trees for others.
Pictures to come..
/ GC2310 wood chipper. #12
While you are there, what size and model of snowblower do you have? Would you get the same thing if you would have to buy another one tomorrow?
Don't forget the pictures of you chipper :)
Max
/ GC2310 wood chipper. #13
For the PTO isues I use a couple of old sandbags made from lenghts of worn out blue jean legs. I toss them on the seat when I want to engage the pto while off the tractor. My tractor has both 540, and 960 rpm pto speeds, and works at 540 while off the seat by tipping the seat ahead, but when in 960rpm mode the mid pto turns too, so they chose to require weight on the seat for that.
/ GC2310 wood chipper. #14
66chevelle,
Did you get that chipper assembled and working yet? I'm also curious as I have a 2300 and have been eyeballing those jinma's. Most of my brush is sage and scrub oak of 2" and less..
Sorry for the delay in responding.. After spending full day un-crating , assembling and adjusting the chipper. All I can say is wow.. I had wished I purchased 2 years ago.. No more shoving 2" branches into a yard machine.
The only thing that makes me nervous it the speed I have to engage the PTO at. (or risk stalling the tractor) IMG_1388.jpg
As far as the snowblower it's a Argo trend C-54. Yes I would purchase again, With just a few more sear pins this time..
2022 CATERPILLAR D3 CRAWLER DOZER (A65053)
2022 CATERPILLAR...
Cub Cadet XT2 Riding Mower (A66408)
Cub Cadet XT2...
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
John Deere 2755 Tractor w/ Boom Mower (A66285)
John Deere 2755...
6ft. 3pt. Blade (A65640)
6ft. 3pt. Blade...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
