Diesel fueling system for CUT owners
   / Diesel fueling system for CUT owners #51
In regards to the fuel-nozzles, providing they are genuine fuel-station-type nozzles :
These nozzles, when in working order, should hold fuel under pressure, drip-free, indefinitely.
When these hoses and nozzles are connected to a fuel delivery pump, the pump is running the whole time that the lever is up (or button pushed), regardless of whether the handle is squeezed or not; so, the nozzle must be capable of remaining leak-free against the pressure of the pump.
If one has friendly connections at the local bulk-fuel plant, they would probably give you a hose and nozzle that might not hardly be up to their standards, but would work fine for our purposes.
Soccer-moms and otherwise mentally challenged people are forever driving away with the nozzle still in the tank, so they get a lot of discards.
2011 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A58017)
2011 INTERNATIONAL...
Yellow Steel Diamond Plate (A55758)
Yellow Steel...
2017 Toro Z-Master 7000 Series 70in Zero Turn Commercial Mower (A55787)
2017 Toro Z-Master...
2015 Ford Taurus AWD Sedan (A54815)
2015 Ford Taurus...
2018 Deere 323E (A53317)
2018 Deere 323E...
2016 Ford Expedition (A56859)
2016 Ford...
