What tools on your tractor?
/ What tools on your tractor? #2
Hammer.Justable wrench,Pliers,Vise grips,6" folding knife,6 in 1 heavy duty screw driver,Roll electric tape,16" pry bar...all keep in ammo box on Kubota.
/ What tools on your tractor? #3
I carry so zip ties, cotter pins, lynch pins, few bungee cords, adjustable wrench, vise grips, regular and philips screwdriver, and a 20' tow strap.
Chris
/ What tools on your tractor? #5
I know that the "tool boxes" on tractors are not that big, but what tools do you carry when you are on the go?
There are several threads on this very topic.
Do a search and read all about it and ya don't hafta wait on every body to post on this thread to get yer answers.
/ What tools on your tractor? #8
MT - not a problem, just means you need to post more gun pics in the rural section. :D
Of course, if you really have too many, I'd be more than willing to foster parent couple of them to make sure they get enough attention. heh. ;)
/ What tools on your tractor? #9
large slip joing pliers (Channel locks) tape measure...
I use the above to make tilt adjustments to the box blade (I often use the tape measure when I want to make sure the blade is all square/level with the 3pth)
if I had more room I would cary more
I use bungie straps to hold a rake, shovel, hoe etc. across my box blade
/ What tools on your tractor? #11
pins of various sizes and shapes
3 lb hammer
metric cressant wrench
couple pairs of plyers
tape measure
marking paint
/ What tools on your tractor? #13
ya nuts and bolts dont seem to work them self loose but i cant count the times I have lost a pin while working or a keeper. I also keep a few pieces of 9 gage wire in the box in case i have to make a new retainer real quick
/ What tools on your tractor? #14
Good Mornin Rick,
Lots of good suggestions here, but I havent seen anyone mention a fire extinguisher !
You might think of adding one and mount it on a fender. When way out in a field far from your house, is not the time to find out how to put out a fire on your tractor ! ;):)
/ What tools on your tractor? #15
Depends on what I'm doing. The "regular" stuff is, pair of gloves, a couple rags, wire ties, hitch pins, fence pliers, cresent wrench (which doubles as a hammer) a roll of wire, screwdriver, and a couple odd open end wrenches. Used to carry a bottle opener too.
Thanks for the tip on the fire extinguiser, definately intend to do that. A neighbor a few years ago started a fire with his hot muffler. By the time he could get anything to help, it was out of control.
Tried seraching on 'tools' and nothing happened.
/ What tools on your tractor? #17
3 lb hammer
tape measure
marking paint
almost the same - I keep two wrenches, though, and a knife. No paint, though I bet I would if the box were bigger.
Lots of tractor pins, as I always seem to need one.
Chains wrapped around front grill protector - often handy.
/ What tools on your tractor? #18
Not much different than what's already been mentioned. I bought a cheap plastic tea pitcher (I guess that was what it was intended for) from Wal Mart to hold my chain. It fits between the seat and fender of my L2800 and is quite handy. One major addition was a large, 18-inch cresent (sp?) wrench... while shredding not long ago, I noticed one of the 3-pt pins on my bush hog was loose and I didn't have a wrench large enough to tighten it... Grrrr lol
/ What tools on your tractor? #19
workinallthetime - Where does one find a metric crescent wrench? :D
SKIDDED PLAIN/WASTE WATER TANK (A63569)
SKIDDED...
2016 Ford Explorer (A59231)
2016 Ford Explorer...
1988 KENWORTH T800 DUMP TRUCK (A58375)
1988 KENWORTH T800...
SDLD25 Crawler Dumper (A64047)
SDLD25 Crawler...
UNKNOWN  500BBL FRAC TANK (A58214)
UNKNOWN 500BBL...
2014 International Durastar 4300 S/A Dump Truck (A61573)
2014 International...
