New Member
/ New Member #1
mdagron
UM, MD
YT 4500 54"
I have been looking for information on buying a new lawn mower/tractor. I had a ~1998 LT133 JD with a 38" deck that we got from my FIL. After moving to MD, the motor blew up. I found that it is not worth putting in a JD motor. If someone knows of a cheap foreign motor to just bolt in the mower, I can do that. If not I am in the market for a new mower. I have about $2000 to spend on a new mower. I have 2 acres. My wife wants the widest lawn mower there is. I want the widest but does a good mowing job. I found a Ariens 54" with a 25 hp Kohler Courage motor. I can get that for $2000 at HD. Is this mower going to last more than a few hours. What can I get for the money that will last for at least 5 years? Thanks in advance.
/ New Member #3
Welcome to TBN!
Hope you enjoy it here.
/ New Member #4
If you want a motor that lasts a long time buy a lawn tractor with a motor that is water cooled. You may be able to find something used with a water cooled engine. I had a John Deere lawn tractor for a short time (don't remember the model) with a water cooled Kawasaki motor in it. It was the sweetest running gasoline motor that I have ever owned. There are some premium motors out there too. Kawasaki, Kubota, Honda. I don't know if Honda makes a water cooled lawn tractor motor. I also have a Honda generator with a 13HP air cooled gasoline motor. It's an awesome motor also.
/ New Member #5
What kind/degree of lasting are you talkin about?
:confused:
/ New Member
3-5 years. I have looked at the Ariens 54" sold at HD. It has great reviews on HD site. I know-I know. On the other mowers on HD site, there are some bad reviews. It seems that the Cougar motor has some problems. Right now I need a few years of use with no major problems. I have 2 acres with about 500' feet of very steep road ditch (100' with 4-5 passes). So I need some protection from lubricating the engine on this ditch. Will the cougar do OK with this steep mowing. Maybe that is what killed the LT133 engine? I know I need a better mower, but right now I need a reliable cheap mower for the next few years.
/ New Member #7
1*3-5 years. I have looked at the Ariens 54" sold at HD. It has great reviews on HD site. I know-I know. On the other mowers on HD site, there are some bad reviews. It seems that the Cougar motor has some problems. Right now I need a few years of use with no major problems. I have 2 acres with about 500' feet of very steep road ditch (100' with 4-5 passes). So I need some protection from lubricating the engine on this ditch. Will the cougar do OK with this steep mowing. Maybe that is what killed the LT133 engine? I know I need a better mower, but right now I need a reliable cheap mower for the next few years.
My Cheap $1300 BBS mower lasted 10 years and so did the constant battle to keep it running .
It Was made BY CC labeled PowrKraft and sold at wards.
This is what I meant by asking What kind/degree of lasting are you talkin about?
/ New Member #8
Welcome to TBN...enjoy. :)
/ New Member #9
If the engine has forced lubrication (oil pump) it will do just fine on a slope. Ariens is a good name brand and has been around for a while.
