valve
/ valve #1
welderboy14
Surrey, BC
John Deere 325
hi
i was woundering if there is a hydraulic valve that operates like this
like anormel singel spool valve but the handle also moves side to side to opperat a second spool:confused:
ps. no a joystick will not work for my aplacation
thanks
welderboy14
/ valve #2
I guess I do not understand your question:confused:
That pretty much describes a Typical Joystick Valve to me?
If you describe the application maybe we can give other options...
/ valve #3
If you have two spools, it is not a single spool valve.
No, you can have four operations on a single spool, which are neutral, fwd, rev, and detent. To do what you want requires two spools. Two spool valves, and four spool valves can be adapted to joystick operation.
Maybe you want solenoid valves, operated by a toggle switch.
Like Kenny said, more info is needed, or the rest of the story.
/ valve #4
My Case 580CK FEL control is one handle two valves. Forward and backward on handle will lower and raise the loader, and left to right on the handle will tilt the bucket forward or backward respectively. It is however what would still consider a joy stick although not the same as what a search of joy stick valves would yield now days. Your diagram though appears you wish to control a function with a twisting motion. I do not believe this would possible unless you went with electric solenoid valves and then you might have a time locating the proper switches but it is possible. Anyway I will post a pic of my case set up when I can, in case that might work for you.
Wayne
/ valve
Wayne
Thanks
but i have alredy found a joystick that will work
2008 PETERBILT 365 (A65643)
2008 PETERBILT 365...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
1994 DAKOTA MANUFACTURING CO. / TRAIL-EZE LANDALL TRAILER (A65643)
1994 DAKOTA...
(10) New CATERPILLAR Keys (A65579)
(10) New...
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
2004 Sterling Ambulance Truck, VIN # 2FZACFCS24AM53402 (A65563)
2004 Sterling...
