2007 cummins
/ 2007 cummins #1
kenmac
Super Member
The Heart of Dixie
McCormick CX105 Kubota MX 5100 HST,
Just purchased a 2007 dodge with cummins.. I believe 325 HP 600 lb torque.. can't believe the power of this motor
/ 2007 cummins #2
Hope you have the manual transmission...
The Cummins is a great motor, but Dodge has never produced an automatic transmission that could handle it.
/ 2007 cummins #3
I love my Dodge CTD 2500. Sounds like you also have the 5.9 Cummins, which does good on MPG. The auto will be fine if you don't overheat it or attempt to gain a 100 hp with a tuner. The manual will also encounter problems if you add more hp and tq than the factory specs.
/ 2007 cummins #5
The 6.7 came out in 2007.5 and several 5.9s were made prior to this in early 2007.
/ 2007 cummins #6
Maybe the older 46 & 47 re auto trannys.The newer 48re trannys are doing well.I also get a kick out of folks who do major power upgrades to the motor and complain there trannys take a dump.H,mm go figure.If you want to upgrade your auto tranny look into suncoast.DTT,goerend brothers or HTS.coobie
/ 2007 cummins
It is auto..manual transfer case for 4 wd. I researched on the diesel forums & found /read the auto's are good as long as you don't add power upgrades. I read there are problems with stick if tou up the power too much... It is an 07 with 5.9. 6.7 came in 07.5 models.. I was looking at new 6.7 until I read about all the emission problems.
/ 2007 cummins #10
You did good by getting a 5.9 If the truck holds together I would keep it for a long time.
Chris
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Mini Metal Goat Statue (A55853)
Mini Metal Goat...
2019 Merlo TF42.7 (A60462)
2019 Merlo TF42.7...
SD Lanch 20'x30' All Steel Carport (A60462)
SD Lanch 20'x30'...
2018 FORD TRANSIT 350 SERVICE VAN (A59823)
2018 FORD TRANSIT...
1667 (A57192)
1667 (A57192)
