99% finished on the 3000
/ 99% finished on the 3000 #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Got her seat back on and fenders and grill and bumper mounted just as the rain was starting.. her 'test' drive was a mad dash tot he bar to get under cover!
soundguy
/ 99% finished on the 3000 #2
Now that turned out real nice! That 3000 will look great with the rest of your collection. Are you going to add lights? Just curious, I didn't see any mounting holes.
Mike
/ 99% finished on the 3000 #3
soundguy
Nice job.
What brand paint did you use?
I'm shopping for Prairie Gold #2 and Cherry Red colors for my 1951 Minneapolis Moline BF that I restoring. I think I'll stick to acrylic enamel.
Nice job.
I used valspar equipment paint, valspar hardner, and naptha as a spray thinner, and mineral spirits for cleanup.
soundguy
Mike
The front nose is brand new and i don't want to drill it for lamp holes, but i may install 2 lamps on the front bumper.. making it look like the units that have the lamps in the grill.. etc. Could have used lamps last night.. it was getting dark and stormy, and I had to pull into my barn real carefully so as not to hit the other tractors...
I have a toolbox for the fender.. but again.. the fenders are new.. and I'm not hot about drilling on them just yet.. :)
soundguy
/ 99% finished on the 3000 #6
soundguy
Looks Great! :)
/ 99% finished on the 3000 #7
Yes sir I am drooling...nice..very nice! :)
/ 99% finished on the 3000 #8
soundguy
Roger.
I used Valspar tractor restoration paint on my 1964 MF-135 diesel. Pretty easy to use and not a bad looking job.
Unfortunately, Valspar doesn't make the MM Prairie Gold #2 and Cherry Red paints that I need. A few years ago TSC carried that color under the BPS label. Since then Valspar bought BPS and decided to drop the MM colors.
NAPA carries the Martin Senuor brand of auto paint, which are pricey. And since the vast majority of auto paint sold today is urethane, guys like me who want acrylic enamel have to special order that type of paint. Urethane is nice, but I don't like the hazard associated with applying that stuff.
Same here.. i stick with acrylic and alkyd paints... more forgiving.. easier to work with.. cheaper.. and decently durable if you apply them correctly and maintaint he machine.
here's my 'finished' 3000 with a kk hog behind her.. just mowed a couple ac with her.
soundguy
/ 99% finished on the 3000 #10
Good Mornin Chris,
That came out very nice !
That tractor is capable of many jobs. Mowing and raking come to mind first, but what a nice inbetween size it is !
Beautiful job, enjoy ! :)
/ 99% finished on the 3000 #11
It seemed that them little Ford deisels had so much more guts than the gassers. I had a 3000 gasser and a 2000 deisel and the 2000 could really outwork the 3000, especially on a plow or bush-hog. Unfortunately, it became ether-addicted and I had to let her go a few years ago at 7000+ hours rather than pouring all the cash into a rebuild. Still, what a tough little tractor and I was able to sell it for a few hundred more than I paid after getting 10 years of nearly touble-free service out of it. To its credit, the 3000 gasser is still going, but not too strong compared to that 2000 deisel in its prime.
Good Mornin Chris,
Yep.. she will be relieving my other tractors with loaders on them from mowing.
it's overkill for my 5' mower.. but more maneuverable than my 850 or 660 with loader.. and way so more than my 5000 or 7610s with large mowers.
soundguy
I had not had a chance to run a 2000/3000 diesel before... this is my first one.. have run plenty of gassers.. and yep.. I almost bought a 2000 gasser when this one came available.. deffinately feels more torquey.. in their defense.. the holley carb on the gassers can be cantankerous if not maintained correctly.. the 2000 I test drove needed choke to richen it up to make it run in high gear... I'm way glad I got the diesel..
soundguy
/ 99% finished on the 3000 #14
Down where you are, you will also not have to worry much about the cold-sarting trouble with some of them older deisels. I never even used mine in the winter for that reason, using my old 8n instead for plowing the snow out of the driveways while the 2000 spent the winter in the barn. That looks like a great job on the restoration.
could always get block rad, oil sump and manifold heaters if needed.. but florida usually don't get that cold but for a handfull of days anyway..
soundguy
/ 99% finished on the 3000 #16
soundguy
I bought a new gas 3000 in '73 to have a good "cold starter" for winter feeding, ect. ..... M.I.S.T.A.K.E. That was the most cold natured, miserably hard starting tractor I ever owned. (Holley carb.....) Later on, I traded it on a diesel 3000. Never failed to start in the coldest weather. It was ALMOST as good of a cold starter as the Perkins diesel in my Massey!!!!! (But not quite;) )
/ 99% finished on the 3000 #17
You did a beautiful job on that 3000! Looks like it just came out of the factory. :cool:
I looked at a 2000 gasser 3cyl before I got this 3000 diesel.. and that holley carb was acting up.. needed lots of choke to start and run smooth.... those holley carbs don't get many good comments.. except for perhaps fuel economy, vs the zenith that get better comments.. except for fuel economy :)
soundguy
/ 99% finished on the 3000 #19
soundguy
Yeah, mine didn't burn much gas at all.....when it wouldn't start....;)
/ 99% finished on the 3000 #20
soundguy
Looks great. You're one quick puppy when it comes to getting your old iron painted and the tractor back in the field.
Seems like it takes me forever to make progress on my restoration projects. Last week the engine for my 1951 Minneapolis Moline BF went to the machine shop (cylinder honing, 0.020" oversize pistons/rings, 0.010" off the crankshaft, 0.010" undersize main and rod bearings, exhaust valves, valve seats for unleaded gas; flywheel, head, block ground flat). Ordered the parts today. Crankshaft machining this week. Hope to have the engine back together late next week. Meanwhile, paint removal work (really boring).
PJ Trailers 84"x15' Roll Off Dumpster (A60462)
PJ Trailers...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
2018 Generac S/A Towable Light Tower (A64194)
2018 Generac S/A...
IH 1486 Tractor (A66285)
IH 1486 Tractor...
2022 EZ-GO ELITE...
