Need a new toilet. What is the best choice?
/ Need a new toilet. What is the best choice? #1
EddieWalker
Epic Contributor
Tyler, Texas
Several, all used and abused.
A couple years ago, I bought what I thought was a very good toilet for my house. It's an American Standard that had some good reviews with a new type of flushing system. It was over $300 at Lowes, and it worked great. I mean, it really cleaned out the bowl nicely. It went upstairs in the kids bathroom. Later, as I finished the downstairs, I bought the same toilet for that bathroom.
It worked good too, but soon startedt to leak and run all the time. I spent months replacing seals and then the entire insides of the tank. I even replaced the tank, but it never got any better. About a year after installing it, I read about a fix using parts from an Eljer toilet to stop the leak. It appears that American Standard created a real lemon with this toilet and there are websites talking all about it. Great to know after buying two of them! :mad:
Steph and the kids will be house sitting this week and I'm here on my own. It's a perfect time to replace the tile in the bathroom and buy a new toilet. I've done some looking online, and read allot of good reviews on Toto and Gerber toilets. I've never owned either, or know of anybody who does. I want a one piece toilet this time around and I'm willing to spend whatever it takes to get a toilet that flushes the bowl clean and doesn't need a plunger or a scrub brush after you use it!!!!!!!!!
As a remodeler, I install allot of toilets. Probably a dozen a year on a a slow year. Of the box store brands, Kohler is OK and Jacuzzi seems to be another brand that my clients like. I tell them that all toilets are junk and it's hit or miss in what we get. I've played games with putting them in and taking them out until we find one that works. Even then, it's really up to the client in what they can live with and what they can afford. I've had budgets that limit it to the very bottom end, and others who will pay more. They've done their research and I've installed what they wanted. I haven't used any of them, but haven't had any glowing reviews either. It's just something that they all seem to realize is a problem and due to the limits on the amount of water allowed in a toilet, we have to deal with as part of life.
I don't want to deal with this anymore. I've scrubbed my last toilet and want one that I can be proud of!!! :D
Who has a good toilet that you can recomend?
Does anybody have a toilet that has a pressure assisted flush?
This is something that I'm going to purchase next week, and I'm relying on reviews that I'm reading online. I'd sure like to hear some personal experiences from those who actually have a quality toilet.
Thank you,
Eddie
/ Need a new toilet. What is the best choice? #2
Toto - but be prepared for sticker shock. My neighbor turned me onto that when I needed to replace mine. I don't know how it does it but I have never, in over 2 years, had to double flush.
I have lost the sites that carried comparison reviews but Toto won hands down on all sites.
Harry K
/ Need a new toilet. What is the best choice? #3
We have a better grade Kohler; it works well.
On a previous unit, we had the jet assist. It was great, but woke the whole house up when used at 2am. When we had some well issues a coule years ago, we did not have constant pressure good enough for it to work. That was a bummer... When my brother(plumber) put one in at his house, my S-I-L immediately told him to remove it because of the LOUD jet action at 3am.
In both bathrooms, and in the granny flat, we replaced everything with ADA tall toilets. I will never have a standard height toilet again. Even my M-I-L, who is 5-3, would not have a standard height again.
/ Need a new toilet. What is the best choice? #4
Eddie, could the leaking in your American Standard (and additional replacement valves) be associated with your water? I know you buy water from your local utility, but you could have high calcium or lime deposits. Have you noticed that on shower heads and such?
We have American Standard elongated toilets and the only problem we ever have is that the flapper valve will develop a slow leak and the float valve will cycle from time-to-time. The problem with a complete flush seems to be the 1.6 gpf ratings forced by law. I can only think of two times we have ever needed a plunger, but a bowl brush is needed to keep the bowl spotless. The need for that varies widely with the contents of the "movement," or so it seems. One reason we have such good flushing is that our toilets are on the second and third floor with good roof venting. I think sufficient venting is probably the most important factor for getting a toilet to flush.
/ Need a new toilet. What is the best choice? #5
We had an American Standard leak. Caused floor damage. It was not noticable, until I noticed grout discoloration in the tile.
The toilet had a leak up inside the casting. When they cast these things, there is a ~1" hole up under the casting. They actually cast the toilet, and then put a plug in that hole. That plug had a tiny leak. A year later, I was replacing sub floor...
When my brother(plumber) installs a toilet, he does not caulk all the way around the back of the toilet. If there is a leak, it should show up as water behind the toilet...
/ Need a new toilet. What is the best choice? #6
I never heard of Toto, and not sure I ever heard of Gerber. I'd probably try to avoid American Standard, perhaps because I called them once about a question about a kitchen faucet and the lady told me flat out that they don't answer questions unless the product is still in warranty.
I'm not sure how old our toilets are because we've only been here 4 years, in a house that was built in 1991, and had kitchen appliances and HVAC system replaced in 1999. I don't know whether toilets were replaced then or not, but at least they're new enough to be 1.6 gallon per flush models. But in the 4 years we've been here, I've replaced one leaking flapper valve in one of the two elongated Kohler toilets. I think I'd probably stay with Kohler. I've not seen any problem with the flushing, but I know Margaret does use a brush on them periodically.
/ Need a new toilet. What is the best choice? #7
I've used American Standard Cadet IIs for years. They were OK, a bit inconsistent and not fancy by any means. Last toilet I bought was an AS low flush. I was expecting low water usage but what I got was high water usage and low probabilty of a flush.
BIL has a low flush Crane. It's impressive in every way.
/ Need a new toilet. What is the best choice? #8
I recently put in a new Crane low flush and also had good results. And I have heard nothing but good about Toto also.
For my new house, I had a Roca 1-piece toilet installed. I bought it new in a box 20 years ago (off the back of a truck, but that's another story :D), moved with me 3 times when I moved and kept it stored in garages everywhere, then finally had it installed here. The plumber who did the install said it was very high-end, and so far so good. Never seen them for sale anywhere else, but I love it (as much as one can love a toilet).
/ Need a new toilet. What is the best choice? #9
Too bad about the problems with the american standards. Maybe i got the one good one, but its been leak free for going on 2 years and always gives a good flush. Mines a Cadet, low flow.
As far as Toto, ive heard great things. Someday id love to have one of those fancy ones, complete with the washer and air dryer. And the lid closer! One of those and the GF would have nothing to complain about :D Pretty high tech with a price to match.
SALTYS MANFUFACTURING 500BBL FRAC TANK (A58214)
SALTYS...
2014 FORD F-550 XL SUPER DUTY SERVICE TRUCK (A59823)
2014 FORD F-550 XL...
20in Digging Tooth Bucket Excavator Attachment (A60352)
20in Digging Tooth...
2014 Ag Spray Schaben Sidedresser (A56438)
2014 Ag Spray...
CATERPILLAR CB24B DOUBLE DRUM ROLLER (A52707)
CATERPILLAR CB24B...
2013 Ford F-250 Pickup Truck (A55973)
2013 Ford F-250...
