60" Woods finish mower question
/ 60" Woods finish mower question #1
buckeyepost
central Ohio
I have an older 60" Woods finish mower like the one pictured below. I know these things aren't meant to go through a lot of grass and I am still learning about them but it seems to bog down really easily. I popped the belt cover off to look at things and there was a lot of dead grass in there so I cleaned it up but since my tractor isn;t running right now I don't know if that fixed it. How tight should the belt be? And, I noticed that on the longest run of the belt (closest to the tractor) between the two furthest pulleys the belt had been flipped over so that it has a twist in it. Is that how it should be?
/ 60" Woods finish mower question #2
I dont own one of these but I would think a flipped belt is wrong. Do a search on the net for a owners manuel, or if there is a near by dealer stop and look at a book. It will show you.
On bogging down - is your tractor pto rated for that size mower? A build up of wet grass in the under deck can cause that also. After mowing a half hour, shut of the tractor and feel the bearing hubs on the mower deck. Warm is OK, hot is not.
/ 60" Woods finish mower question #3
Hi there-
I use a Woods RM59 as one would use a brush hog. It is a light mower for light tractors and it's nice and close to keep the front end of the tractor on the ground. The belt is almost indestructable with less than 30 HP if you pay any attention at all to its tension. There's a tensioner assembly under the end guard 3/4 inch nut if I recall. I regularly reshape the deck backing up to stuff (rocks mostly) to mow over them. Belt routing is on a decal inside the main guard. In general- a handy pc of equipment!
/ 60" Woods finish mower question #4
I used to cut 7 of my 11 acres with a IH Cub and it had a 5 ft Woods belly mower on it, specifically the "L59" mower. The L59 is basically the exact same thing as the RM59, except it's mounted to the belly of the tractor and it's attached to the tractor's rear PTO through a belt and pulley system as opposed to a PTO shaft and the large white tower on the RM59. The belt should be tight enough not to come off, but not so tight that it won't spin properly. If the belt tensioner is working properly than that shouldn't be your problem. On the L59 the belt twist's in ,if I remember correctly, two places. Once when it goes from the rear PTO towards the middle spindle of the deck, and again when it comes back from that middle spindle towards the PTO. That is the correct layout for that mower, and seeing as on the RM59 that the belt starts out on the big pulley in the white tower, it's very possible the twists that you mention would b correct as well.
What condition are the spindles in? do you grease them regularly?, Do you hear the spindles turning when the mower is running, like a big whirlwind or helicopter noise?, or is it quiet? Do the spindles have any play in them?, Can you wiggle them significantly? Do you keep the blades sharp?, dull blades can really bog down a mower. Do you keep the underneath of the deck clean? as in scraping the built up grass clippings off regularly? Blades and under-deck cleanliness are two of the biggest things that can create resistance for a mower. If the spindles are fighting to turn then they could need to be replaced, or simply greased depending on their condition.
/ 60" Woods finish mower question #5
The belt is supposed to be twisted like that. Same way on my RM 48. You can download a manual for yours by going to Woods Equipment Company - Manuals
The manual will show the decal and there is a step-by-step process of installing the belt. My RM 48 has been eating belts this year for some reason. Have broken last year's belt plus 2 new ones. I can't put mine on without looking at the decal. The decal also mentions the twist.
Thanks guys! This is all really good info for a noob :D This forum has really helped me out since I don't really have anyone to turn to for experience/advice on these kind of things. I'm guessing mine is a RM59 then but everything has been painted over gray. Here is another pic if anyone can tell. And I haven't had the main grate/cover off yet so maybe there is something in there to distiguish it.
I haven't done anything with the spindles since I bought it this spring but it does sound like a nice hum, nothing funny about it. I know a few times that I bogged it down b/c I had to raise the deck and cut long grass from the blades but I stopped doing that and it still whined to a stop which makes me think it was all the grass caked around the belt which I just cleaned out. And, I probably do need the blades sharpened since I've been cutting some pretty think stuff. I just didn't know if it mattered since brush hogs are dull.
I'll pop the cover off next time I'm out but thanks again for all the useful info.
/ 60" Woods finish mower question #7
Looks like a RM59 to me. If the spindles have a blatantly noticeable hum than that would be an indication of them needing replacing, ideally they should be virtually silent. If it's only very slightly than that shouldn't be your problem.
How are you using this mower? to bush hog very tall grass? or regular finish mowing? Finish mowing is what it was intended for and if you're mowing very tall grass or overgrown areas than that is your problem right there. The gearing that that mower has is intended to give the blades a very high speed to produce a smooth cut over a regularly maintained lawn, not bush hog. A bush hog has a high torque, low gearing setup to give the blade the ability to keep turning when it gets into the rough stuff and not impede it's work. I would suggest that you invest in a bush hog if this is the kind of use this mower is seeing.
If finish mowing is it's main use than that's fine. You'll want to make sure you don't let the grass build up around the spindles underneath the deck, but if the mower is finish mowing than this shouldn't happen anyway. Keeping the blades sharp on a finish mower is ideal. A bush hog more beats the grass than cuts it, where a finish mower cuts it and needs the blades sharp to be able to perform adequately.
I am mowing higher, thicker grass/brush than I should with it but my tractor came with it. AND, if my tractor ran better (or at all) I could mow regularly so the grass/weeds wouldn't have time to grow so tall. I guess I'll just set the deck up high and mow it twice once I do get my Fergie running.
/ 60" Woods finish mower question #9
I just put spindles on my RM 48. Cost me $420.00. Probably didn't need to do it either but I was trying to eliminate a wobble. The new spindles did not change that.
/ 60" Woods finish mower question #10
I clicked the link, but couldn't find the manual for the RM59. I think this is the mower I have, it has been repainted. I am trying to find the belt part number so I can hunt another one down, and I need another tail wheel. Thanks
/ 60" Woods finish mower question #11
when ya click the link. it took me a couple minutes to see it, "finishing mowers"
top row, second from left side.
best suggestion is to take the belt off, and take to a local tractor part store. so they can measure things. if they have to order a belt, make sure you take old belt with you.
if you have ability. go ahead and take belt off, but also just load up the finishing mower and take with you. granted "flingers" near me. those folks know there stuff. but if it has been repainted. hopefully you will get a old timer that been there for years that is also a parts guy. and be able to look things over to find a belt for ya.
there are cheap belts and then normally more expensive belts. normally the more expensive belts can withstand a higher running temperature, and do not stretch at the higher temps and in that last much longer.
there should be a belt tension-er some place on the mower deck, see if it is in operating order as well. and if it will add or remove any amount to over all belt length, when belt tension-er is fully positioned one way or the other way.
/ 60" Woods finish mower question #12
I went there and they didn't have them, but I requested one, and they emailed me one within the hour. When you request one, you need to to which RM59 you have. I have all three, but I don't know if I can post them here. The woods belt part number is 31700
I do have a question. I have a RM59-1, but I get mixed answers on what length belt I need, can anyone confirm what length belt they actually have put on their mower? I am most likely going to NAPA. Thanks.
/ 60" Woods finish mower question #13
The rear of the mower should be 1/2 to 1" higher than the front to avoid cutting the grass twice.
If it is level or the rear is lower than the front a lot more power will be needed.
Also these blades rotate (CW) opposite direction than most if not all other mowers so it is possible you may have blades with the cutting edge on the wrong side. In addition the screws that attach the blade is left hand thread meaning that you turn it clockwise to remove and CCW to attach.
/ 60" Woods finish mower question #14
Time to remove blades from Woods L59 belly mower and sharpen. Had to use large ratchet with cheater bar to remove blades. Upon reinstalling blades, manual calls for 170 ft.lbs. Is that an error??? My torque wrench only goes to 150, and I could not tighten the bolts to that value (150). I was afraid to strip the bolts or spindle threads if going too far. I was working under the mower while still attached to tractor. What a real pain in trying to block the blades with wood while loosening/tightening.
MIRRORS, MARKER LIGHTS, SWITCHES (A64276)
MIRRORS, MARKER...
84in. Skid Steer Bucket (A65640)
84in. Skid Steer...
2007 Chevrolet Suburban Multipurpose Vehicle (MPV), VIN # 3GNGK26K97G305720 (A65563)
2007 Chevrolet...
KMC 3pt 6 Row Peanut Reshaker (A64127)
KMC 3pt 6 Row...
Bobcat Skidsteer Snowplow
Bobcat Skidsteer...
2017 CHEVROLET SILVERADO 2500HD (A65643)
2017 CHEVROLET...
