How much is too much hours?
/ How much is too much hours? #1
hondarider
I'm looking at a used MF 650B skip loader with about 3500 hours. I don't see any leaks anywhere and it starts quickly.
It seems the owner really took great care of it.
How many more hours can this thing go?
/ How much is too much hours? #2
Never heard of one. Had to look up a picture on the net. An industrial appearing machine. Those kind of machines are hard to predict how hard they were used. 3500 hours does not seem high but I am sure it was not babied if used for constuction. The auction prices seemed surprising low for the units I saw on the net.
Where did you see it? It is the same as a Fermec 650b
/ How much is too much hours? #4
The question for how many hours can ___________ machine go is almost an impossible one to answer. There are too many variables that the owner of a used piece of equipment can't imagine, much less control. My thoughts on this pretty much is to look it over and check what your able to check, and if possible have someone with experience (with particular machine) check it out with you.
An old saying.... "You pays your money and you takes your chances!" covers pretty much the whole aspect of buying used equipment. (heck, it even covers new stuff) or the one "buyer beware" might come into play.
The average member on this board would tend to say that my JD2555 is at the end of it's lifespan, with in excess of 7,000 hours on it. However, after listening to it run, and work, almost everyone that has seen the hours meter changes their mind. I knew the guy who maintained this tractor and was given a clean bill of health for the tractor, dispite the hours. Good luck with it,
David from jax
/ How much is too much hours? #5
I just bought a New Holland backhoe in March '09 with 5,500 hours on it. It is in mechanically and cosmetically better condition than most backhoes with 2,000 hours.
The difference is it was over-maintained and stored inside.
3500 hours is nothing for a MF skip loader. That thing could go 10,000 hours with only minor repairs. The older MF, JD, NH machines were very durable.
/ How much is too much hours? #6
I have done a lot of reading about this. For those that take minimal care of the tractor 6,500 hours is a reasonable number before major repairs. For those that take excellent care of the tractor 10,000 + hours is possible. I haven't proven this out. The most hours I have ever put on a tractor is 4,000. But I have seen many a hard worked farm tractor with 8,000 to 9,000 hours that purr like a kitten because they were well taken care of.
/ How much is too much hours? #7
would have to agree its all about the maintenance
/ How much is too much hours? #8
I agree.. usage and maintenance are more of a life indicator than hours... a rent-a-laborer can ruin a 50k$ machine in 1 hr.. while a concerned owner can put 10khrs on a machine with good storage habits, maintenance, and not using it like it was rented.. and still have a good working well used machine.
soundguy
/ How much is too much hours? #9
i have a 71 model john deere 4020 that had a few over 10k hours on it when a liner started leaking coolant into the oil.took it to the dealer & had a inframe overhaul done. i am the second owner & have had the tractor since 1985. it is all about the maintenance.that was a little over 2 years ago & it now has about 11k hours on it.
/ How much is too much hours? #10
I know a guy who has a kubota g-1800 lawnmower with 6000 hours on it....with no major problems
/ How much is too much hours? #11
The interesting question is "Who would want to ride one for 6000 hours?"
/ How much is too much hours? #12
The rule of thumb that I go by on equipment is 8,000 hours is about where problems start to show up. Like the others have mentioned, maintenance has allot to do with it, but just for guestamating how long an engine will last, that's a good number.
Eddie
/ How much is too much hours? #13
Use and abuse coupled with TLC - all make a difference.
I bought a 58 MF65 four years ago that was working with no apparent problems - with just 10,000 hours on it. Today it has just under 11,000 hours on it. I have done only routine maintenance (grease, LO and filter etc) to it, When I first got it I drained and flushed the tranny and then put new oil in. Replaced shifter boots, tie rods, a few belts, plugs (gas engine) and set timing and valves and adjusted clutch and brakes..
The tractor runs with no oil leaks, no fumes or smoke from exhaust or blowby and does very well in the winter (-25F). It is not unusual to find farm tractors with high hours. I expect a large majority of those machines are worked hard and most seem to do well and survive.
Whether or not the new machines will do the same service remains to be seen.
J.
/ How much is too much hours? #14
Could it be assumed that only the fellow who actually owns the equipment and signs the check is not a "Rent A Labourer"?:confused:
2022 CORMIDI C85 STAND-ON MINI DUMPER (A62129)
2022 CORMIDI C85...
UNUSED WOLVERINE GB-11-72W 72" HYD GRAPPLE BUCKET (A62131)
UNUSED WOLVERINE...
NORTON CLIPPER C-139 CONCRETE SAW (A62131)
NORTON CLIPPER...
International Engine (A61568)
International...
2012 VOLVO VNL 6X4 T/A DAY CAB TRUCK TRACTOR (A59909)
2012 VOLVO VNL 6X4...
2017 Ford Expedition SUV (A61569)
2017 Ford...
