Kubota B7510 Tiller?
   / Kubota B7510 Tiller? #1
Ezzrider
Kubota B7510
I just saw this Kubota tread - Anyone have a recommendation for a tiller to fit the PTO on a B7510? Place to purchase and price?
   / Kubota B7510 Tiller? #2
I have a B7510 and I have been using the woods gct52 52" and I have had no problems here with the new england rocky soil. I think Kuhn tiller is a stronger tiller, more heavy duty, but more expensive. Mine was $2200. The Kuhn was over $3000. I also have a Wallenstien bx 42 chipper and I am happy with it. Buy it where it's the best price in my opinion. I will never use Iowa farm equipment again because they are not very good business people. Hope this helps. Hope this post works, it's my first one. I have been visiting this web site for about 3 years though, good site.
   / Kubota B7510 Tiller? #3
I have a Yanmar RS1303 that I use on my B7610 (which is basically the same as your B7510, just 2 HP more at PTO).
These are typically available for $300-$500 used, and are a good option if you are looking for something inexepnsive. Just be sure to make sure the tines don't need to be replaced, as a replacement set costs $200. I paid $200 for my RS1303, and put $200 worth if tines into it and a $15 tine shaft seal. It works great.
To use one of these Yanmar tillers on your B7510, you'll need a set of longer (32-35") lift arms to get it to sit at the correct angle, and also to give enough driveline length to be able to put a slip clutch in. If you need to know a source for these, I can look it it for you. I paid about $50 for the pair. They're easy to swap out for the stock ones (which I put back on for anything else that I use on the 3PH). A hydraulic top link is also handy (which I have) for being able to get the right angle.
   / Kubota B7510 Tiller? #4
I'm not advocating one over the other but I have found King Kutter to be a good value. Not a premium brand but well built. No complaints. Unless you plan on a commercial application more expensive brands probably aren't worth the extra $$$ IMO.
Thanks to everyone for your input.
   / Kubota B7510 Tiller? #6
Same here. I used a $300 Yanmar RS1200 on my B7510HST. Worked fine. If the ground was particularly hard, I plowed it first with a King Kutter middle buster and then hit it with the rototiller.
   / Kubota B7510 Tiller? #7
We have a HST B7510 with a 60" Kubota tiller, it does pretty good, if you are tilling new ground it gets the tractor working hard, but it handles it quite well tilling 4-6".
Aaron Z
Unused 2025 CFG MY50R Mini Excavator (A49461)
Unused 2025 CFG...
Flatbed Body for Heavy Truck (A50854)
Flatbed Body for...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2016 Ford F-150 Crew Cab Pickup Truck (A49461)
2016 Ford F-150...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
KENWORTH W900 (A50854)
