Help flatten our fields!!!
   / Help flatten our fields!!! #11
There are "land levelers" that will flatten/smooth things out.
Two things I've used: drag a section of old chainlink fence with a couple of lengths of telephone pole chained on top of it (cheap solution).
Also, a landscape rake does a good job (better, but not as cheap).
Ken
   / Help flatten our fields!!! #12
I have a similar problem on about 2 acres and dont' have a disc. I was intending to use a box blade to try and cut the ridges down and fill the low spots. Will this work?
   / Help flatten our fields!!! #13
Depends on the soil and your patience.
   / Help flatten our fields!!! #14
Bud I would agree with Ken with one other comment, also depends on what is possibly growing there now. If much of anything you will probably find box blade to be at best slow.
FoxTailsManor, you can use a heavy board, rail road iron or old pump pipe being pulled by chain from the disk. Will not be able to back up with this unless you place the board on the disk. You can also use a real heavy chain hooked to each side of disk making like a loop behind the disk. Also try varying the depth and speed of disking and playing with the depth of front of disk compared to rear of disk. All of that can affect how smooth a surface is left. Also be sure level from left to right side. I like to get a 3 pth disk level on drive way where I know it is level.
   / Help flatten our fields!!! #16
From what I've seen and read a grader scraper should do what your looking for and you can use it to take care of the drive way to. When funds are a little better going to order one from this company. DURA-GRADER spreader/grader You could always try it. They have a 90 day satisfaction guarantee.
   / Help flatten our fields!!! #17
FoxTails, you've gotten good info here.
The same tool that made those ridges/terraces is the tool you need to use to get rid of them.......a disc plow. From your description of the property it sounds like the place may have been "terraced" as some point in the past to control errosion. This has been done for everything from field crops to orchards to control water flow and they use a single-row of disc gangs mounted at an extreme angle to throw as much dirt in toward the center of the plow over continuous passes to build the ridge/terrace.
While you're new owners I'm not sure if you are new to tractors/equipment/farming. Do you understand the way that a tandem disc unit's gangs angle? Most adjust to allow soil to either be pulled-in or thrown out from the plow as you pass over a strip of land. Many of the newer 3pt mounted discs have fixed gangs but most older and especially the pull type units have angling gangs.
To deconstruct these ridges, take your disc and angle the centers of the front set of gangs as far back as the will go. That throws the max amount of dirt out and away from the plow on each pass. Angle the rear gang center's as far as they'll go as well. This throw the least amount of dirt back toward the center of the disc on each pass.
Imagine looking down from above, front to back, and your disc gangs should look like this..........> |......or as close as your disc will allow that. Make pass after pass over each ridge until the ridge is leveled out sufficiently. Once all are reasonably done, set the gangs back to normal and make regular, circular patterns in the field to level the field out.
Hope I didn't get too "Inside Disc Plows" or anything but.....
   / Help flatten our fields!!! #18
... Any ideas??? ...
I had the same problem, but my land had been planted in tobacco. Massive rows a foot or more high spaced at around 6 feet.
They look small in the picture, but my 50HP Kubota straddles one row with a tire in each furrow. I worked a long time with a 20-disk harrow, a landscape rake, a box blade, and various drags. I was able to improve things enough that I could drive the tractor perpendicular to the rows, but no matter what I did I was unable to completely get rid of the ridges. I'd hate to guess how many times I disked or dragged those fields going every different direction. After months of work I had it looking like this, a major improvement, but definitely still not flat:
Anyway, enough about what didn't work and on to what did: I finally ended up using a 3-16 bottom plow to turn the soil. I went perpendicular to the old rows (I don't think that made much difference though).
As you can see, that completely changed the topology. I wish I had done this in the first place. I let it sit for about a month or so after that to help kill the weeds that were there, then I disked it to break up the large dirt clods and level things out. With the ground broken up by the plow, the disk worked much better now.
Finally, I dragged it with a special "implement" that I have. It's a 20-foot wide chunk of a crane boom that was rusting in the woods when I bought the property. It weighs around 1000 pounds and does a great job of smoothing and leveling once the ground is nicely broken up. You can see it sitting in the background of this photo:
I'm sure a good heavy I-beam or a chunk of railroad iron would do just as good a job. If you don't have to deal with the rock hard clay I have here in North Central NC, you may be fine just disking it or maybe going over with a cultipacker or pulverizer.
Anyway, after leveling I planted with a seed drill. You can see how smooth the surface is compared to the rows that used to be there. The ridges from the drill go away after a season of freezing and thawing and raining.
Good luck!
   / Help flatten our fields!!! #19
Anyone else having trouble seeing my pictures above? Only one of them seems to be linking properly. They were working this morning.
If others are having issues too, I'll repost the pics as attachments.
   / Help flatten our fields!!! #20
Only the 1 is showing for Me also jcaron2 . Bob
2012 AMERITRAIL (A55745)
2012 AMERITRAIL...
26120 (A56859)
26120 (A56859)
Towable Dewatering Pump (A59228)
Towable Dewatering...
2020 Utility FS2CDHE 45ft. 35 Ton T/A Drop Deck Flatbed Trailer (A60460)
2020 Utility...
2003 INTERNATIONAL 9900I (INOPERABLE) (A58214)
2003 INTERNATIONAL...
2009 Sterling Acterra Altec DM47TR Insulated Digger Derrick Truck (A60460)
2009 Sterling...
