GETTING SOMETHING NEW!
/ GETTING SOMETHING NEW! #31
I checked my CT230 manual last night and shows one two chains in the back attached from the tractor drawbar mount to the back corners of the trailer. One the fron it had the same setup attached to the plate the brush guard is mounted to. Since the chains go to the corners it holds the tractor in both forward/back and side to side. As far the backhoe "only" being held on by two 1" dia pins...do you have any idea what the shear strength of a 1" pin is?!? The chain and trailer mount would bust long before you sheared two 1" pins. fYI a 2" hitch is held into the reciever on your truck with one 1/2" pin.
BTW Real nice tractor!!!
/ GETTING SOMETHING NEW! #32
As far the backhoe "only" being held on by two 1" dia pins...do you have any idea what the shear strength of a 1" pin is?!? The chain and trailer mount would bust long before you sheared two 1" pins. fYI a 2" hitch is held into the receiver on your truck with one 1/2" pin.
Exactly... Thank You!!
/ GETTING SOMETHING NEW! #33
Not fair! :)
Wallace cheated. He knew the answer... knows more than most before hand... not fair!!! :)
Nice tractor and truck and trailer! Although you should change the name of the trailer to "do a lot!".
Have fun - play safe.
Did I mention Wallace cheated... not fair!!!:)
Lloyd
Dmace Re: GETTING SOMETHING NEW!
Quote:
Originally Posted by wallace
Are you done yet?
Nope, I think the way you allow these tractors to leave your yard barely secured to trailers that leave little room in the GVW to spare is dangerous and borderline illegal.
You really think that strapping the attachments alone and having no tie downs on the tractor itself is safe? The local highway patrolman here at the scales surely didn't when I showed him the picture
HEY DMACE,I hope this isnt the picture you showed the highway patrol
Kinda forgot to chain her down legally,oh you shouldnt let those safty chains drag on the ground you might need them in an accident
Oh,forgot to mention it,but its illegal to have your backhoe extending past the side of your trailer,but like you say to each his own...
/ GETTING SOMETHING NEW! #36
First of all, the chains are not touching the ground but are just about 4-5" above. If this was my trailer and not a rental I may make them shorter. Secondly, there are four chains and binders securing the TRACTOR to the trailer via 4 huge D-rings, the chains are barely visible in the picture since they are under the tractor but are there. The straps you see are going across the attachments to keep them from bouncing around as I don't rely on attachments to properly secure a tractor.
Lastly, if you look at a second picture that shows a front view, you will see that the backhoe DOES NOT stick out past the fender.
If only you were as concerned about your own loaded trailer... :rolleyes:
/ GETTING SOMETHING NEW! #37
Enough, no need to start bashing each other, this thread was about a new owner.
Steve
I just wanted to show everyone on the kioti part of this site that i was joining their group.thanks to all who responded,and also to my canadian friends,and to my dealer who has taken unecessary heat.Some people just dont see what its really about ,and we can only feel sorry for them.If anyone can shut this thread down i would appreciate it.
/ GETTING SOMETHING NEW! #39
Congratulations on your new tractor! :) Sold my tractor a couple of years and I am looking forward to the day I get another one!
/ GETTING SOMETHING NEW! #40
Best of luck with your new tractor. The Kioti's are as good as any brand being made, they seem rugged and reliable.
2025 CTRA 4X2 T/A 16FT ENCLOSED TRAILER (A59906)
2025 CTRA 4X2 T/A...
2015 Sealine F380 Flybridge Motor Yacht Boat (A59231)
2015 Sealine F380...
New/Unused Quick Attach Pallet Forks (A61166)
New/Unused Quick...
Case Axial-Flow Combine Wheels NO RESERVE (A61307)
Case Axial-Flow...
2014 FREIGHTLINER CASCADIA T/A 6X4 SLEEPER TRUCK TRACTOR (A59906)
2014 FREIGHTLINER...
2013 CARRY-ON TRAILER 14 T/A DOG HOUSE (A60736)
2013 CARRY-ON...
